    Just 3d silhouette, outer surfaces, shell only
    2 Posts 2 Posters 611 Views 2 Watching
    • K
      kekec1313
      I have a complex object imported with a lot of inner geometry, of course as always object is not solid. It tooks 4M memory in file and CPU time to manipulate.
      But all I need is only outer dimensions, simplified surfaces, 3D silhouette without all this inner geometry.
      I tried solid tools but there is a problem with "not solid". I tried to find all these gaps but it is not so easy. Deleting lines, etc. time consuming.
      Is there any plugin to do this job?
      Problematic object
      • G
        glro
        @kekec1313 said:
        maybe this one can help you
        http://sketchucation.com/forums/viewtopic.php?t=31908
        but you will probably have to explode everything before using it
