    Get a list of File names on the input box
    9 Posts 4 Posters 1.2k Views 4 Watching
      davesexcel
      The code
      Dir.new('C:\\TestFolder\\').each { |file| puts file } Will print out all the file names in the console.
      Is there a way to get that loop to populate the dropdown input box?
      ` ents=Sketchup.active_model.active_entities
      #Dir.new('C:\TestFolder\').each { |file| puts file }
      prompts = ["Find a file?"]
      defaults = [""]
      list=[Dir.new('C:\TestFolder\').each { |file| puts file }]
      input = UI.inputbox prompts, defaults,list, "File Name"
      a=input
      puts a`
      • fredo6F
        You should use
        list = Dir["C:/Testfolder/*.*"].join("|")
        • Dan RathbunD
          Dan Rathbun
          (1) Ruby file and directory operations work best with paths using "/" which is defined as File::SEPARATOR.
          This statement will replace each occurrence of "\" OR "" OR "//" with "/":
          path.gsub(/\\\\|\\|\/\//,'/')
          Wrap it up in a utility method:
          def slashify(path)
          (2) If you wish only the filenames, without the path prepended to every filename, use:
          Dir.entries("C:/TestFolder/")[2..-1].join('|')
          The [2..-1] sub-range ignores the first two members ( 2 is the third member) which are "." and "..". The -1 means the last member.
          (3) The preferred means is (because this is how the user is used to choosing files):
          # In the Constant definitions at top of class or module;
          WIN =(Sketchup;;platform == ;platform_win rescue RUBY_PLATFORM !~ /darwin/i)
          # Later on in some method of your code;
          chosen = UI.openpanel(
            'Choose a file...',
            'C;/TestFolder',
            WIN ? 'All files|*.*||' ; '*.*'
          if chosen # nil if user cancels openpanel
            # chosen is an good absolute filepath
            # On PC, the paths will have backslashes
            # so "slashify" them after UI.openpanel();
            path = slashify(chosen)
          I'm not here much anymore.
            davesexcel
            ListBoxThank you both for the answers,
            Both
            and
            They list all the files, but all on one line and the list ends up in the title with a blank textbox.
            def slashify(path)
            path.gsub(/\\|\|///,'/')
            defaults = ["a"]
            list = Dir.entries("C:/TestFolder/")[2..-1].join('|')
            a=input
            puts a
            puts list`
            • sdmitchS
              sdmitch
              @davesexcel said:
              [attachment=0:i9zhoo1z]<!-- ia0 -->FileListRuby.jpg<!-- ia0 -->[/attachment:i9zhoo1z]Thank you both for the answers,
              Both
              and
              def slashify(path)
              defaults = ["a"]
              a=input
              puts a
              puts list`
              list, like prompts and defaults, must be an array
              prompts = ["Find a File"]
              defaults = ["a"]
              list = [Dir.entries('c;/users/public/test')[2..-1].join("|")]
              input = UI.inputbox(prompts,defaults,list,"File Name")
              http://sdmitch.blogspot.com/
                davesexcel
                The list works very well, but the workbook is not opening, I narrowed it down to it not recognizing "s" as a string.
                def slashify(path)
                defaults = ["a"]
                list = [Dir.entries("C:/TestFolder/Doit with Sketchup/")[2..-1].join('|')]
                j=input
                puts j
                #j = j.gsub(/[^a-zA-Z0-9-." "]/,"")
                puts j
                   s='C:/TestFolder/Doit with Sketchup/' + j
                puts s
                excel = WIN32OLE.new('Excel.Application')
                excel.Visible = true
                #number_of_sheets = excel.SheetsInNewWorkbook
                #excel.SheetsInNewWorkbook = 1
                excel.Workbooks.Open(s)
                #workbook = excel.Workbooks.Add
                #excel.SheetsInNewWorkbook = number_of_sheets
                ws = excel.Worksheets(1)`
                • Dan RathbunD
                  Dan Rathbun
                  Dave, make it easier on yourself and e1-else.
                  Use [ code ] tags:
                  [code]
                    # Ruby program goes here ...
                    Indent works
                  [/code]
                  • Dan RathbunD
                    Dan Rathbun
                    You might try:
                    s = File.join('C:/TestFolder/Doit with Sketchup/', j)
                    • Dan RathbunD
                      Dan Rathbun
                      OH! I see your booboo: inputbox always returns an array (except when the user cancels it returns false. So always check the result boolean-wise.)
                      input = UI.inputbox prompts, defaults,list, "File Name" return unless input j = input[0]
