Bowling ball roll
Win 8.1, 32 bit, sketchy physics, SU Make 2016
Have bowling alley (dwg) with ramp to start bowling ball. Ball rolls about half way then peters out.
File attached. What factor must be changed to cause ball to keep rolling?
Hi drafter i had play with your model and to get the strike power u need
i added a servo with hammer strike lever (both can be hidden from view)
press (S key) for strike and tweak strength and acceleration for your needs
BowlingAlley2
https://file.town/download/iwjof9w8wlcpdse8tsibdo53hHope it helps
Tez -
BowlingAlley2
TezThank you much. Are there other keyboard shortcuts you can share?
all scripts below go in controller panel
motor joints
key('z')-key('x') .........left/right
(0.5-rightx) ........left/right arrow keys
(0.5-righty) ........up/down arrow keysservo joints
one for your bowling alley model automatic strike at frame 300
[0,1][(frame/300)%2] ....set servo min to -0.00
(rightx) ........left/right arrow keys
key('z')-key('x') .........left/right....set servo min to -0.00
oscillator(300) .......left/right...automaticon joypad sticks or W,A,S,D keys
(joyLX) .....left to right / leftstick
(joyLY) .....up/down / leftstick(joyRY) .....left to right / rightstick
(joyRX) .....up/down / rightstickmake sure u plug in joypad before u startup sketchup
BowlingAlley2
When I open this "revised" dwg, Controllers are absent. I don't know why.
Hi mate don't understand what u mean by "Controllers are absent"
this may help u out
Tez
When I his "start", A blank panel, where you expect to find controllers for such things as servos, is "Blank".
this may help u out
Tez
Hold the phone!!
Tried it again and it works fine.
What threw me off was the letter "S" is the keyboard short-cut for SCALE. So the icon for scale kept appearing. So I deleted the short-cut.............And ALL is well.
Thank you for your time.
