    Bowling ball roll
    8 Posts 2 Posters 10.4k Views 2 Watching
      drafter
      Win 8.1, 32 bit, sketchy physics, SU Make 2016
      Have bowling alley (dwg) with ramp to start bowling ball. Ball rolls about half way then peters out.
      File attached. What factor must be changed to cause ball to keep rolling?
      Make 2016
        SketchyPhysicsNutt
        Hi drafter i had play with your model and to get the strike power u need
        i added a servo with hammer strike lever (both can be hidden from view)
        press (S key) for strike and tweak strength and acceleration for your needs
        BowlingAlley2
        https://file.town/download/iwjof9w8wlcpdse8tsibdo53h
        Hope it helps
        Tez
          drafter
          BowlingAlley2
          Hope it helps
          Tez
          Thank you much. Are there other keyboard shortcuts you can share?
            SketchyPhysicsNutt
            all scripts below go in controller panel
            motor joints
            key('z')-key('x') .........left/right
            (0.5-rightx) ........left/right arrow keys
            (0.5-righty) ........up/down arrow keys
            servo joints
            one for your bowling alley model automatic strike at frame 300
            [0,1][(frame/300)%2] ....set servo min to -0.00
            (rightx) ........left/right arrow keys
            key('z')-key('x') .........left/right....set servo min to -0.00
            oscillator(300) .......left/right...automatic
            on joypad sticks or W,A,S,D keys
            (joyLX) .....left to right / leftstick
            (joyLY) .....up/down / leftstick
            (joyRY) .....left to right / rightstick
            (joyRX) .....up/down / rightstick
            make sure u plug in joypad before u startup sketchup
              drafter
              BowlingAlley2
              Hope it helps
              Tez
              When I open this "revised" dwg, Controllers are absent. I don't know why.
                SketchyPhysicsNutt
                Hi mate don't understand what u mean by "Controllers are absent"
                this may help u out
                http://s28.postimg.org/cr964g5jh/B_alley.png
                Tez
                  drafter
                  this may help u out
                  Tez
                  When I his "start", A blank panel, where you expect to find controllers for such things as servos, is "Blank".
                    drafter
                    this may help u out
                    Tez
                    Hold the phone!!
                    Tried it again and it works fine.
                    What threw me off was the letter "S" is the keyboard short-cut for SCALE. So the icon for scale kept appearing. So I deleted the short-cut.............And ALL is well.
                    Thank you for your time.
