    Pre Save Observer
    4 Posts 2 Posters 1.3k Views 2 Watching
    • K
      ktkoh
      I am trying to implement a pre save observer. This is an example of the file. This works on the current model if I load the file after the model is open. However if I bring up a new model and then save it this observer does not see the save operation. Suggestions on how to make it work on each model I save??
      Keith
      require 'sketchup.rb'
      # This is an example of an observer that watches the
      # model save event.
      module K2WS
      class MyModelObserver < Sketchup;;ModelObserver
      def onPreSaveModel(model)
      UI.messagebox("PreSaveObserver")
      # Attach the observer.
      Sketchup.active_model.add_observer(MyModelObserver.new)
      end # K2WS
        Jim
        When you start a new model, or open a model the existing model - the one with the observer attached is destroyed.
        You need to attach an observer to the new model. Use an AppObserver to be notified when you open a model, or when you start a new model.
        • K
          ktkoh
          Thanks. That was just what I needed.
          Keith
            Jim
            I'm glad it helped.
            What I said is true on Windows because there is ever only one Model.
            On a Mac you can have more than one model opened. But you still probably need to attach your observers when new models are created.
