    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 646.5k Views 71 Watching
    • G
      Garry K
      I am working on porting CutMaster and DxfConfig to a more current C++ compiler. CutMaster reports will now be available in 6 formats
      1. Screen
      2. Printer
      3. PDF
      4. HTML
      5. CSV
      6. RTF
      • G
        Garry K
        Porting CutMaster and DxfConfig to a more current compiler took longer than I had hoped. However, I also changed the database driver. We are still using SQLite database but no longer need to install a 3rd part ODBC driver. The Data Grids now work better than ever before.
        I recommend that you either use metric or decimal inches for the DXF features. Fractional inches is not close enough for European hardware. It is best if you work with metric but decimal inches should be ok.
        Version 2.0.1.26 of CutMaster and DxfConfig are now available on my web site. CabMaker Gold version 1.0.57 is intended to work with CutMaster Gold.
        Anyone who has expired trials for CutMaster and DxfConfig and who wishes to try out the new programs please email me from my web site and I'll reset your accounts.
        Cutmaster still requires some work - but it is close enough to get a good feel for it.
        To Do:
        1. Update documentation
        2. Complete tall cabinet sides
        3. Enable multiple Dxf Configuration files
        • G
          Garry K
          I guess you can never do enough testing. I have found a few bugs and am working quickly to fix them.
          Bugs:
          1. In cabmaker if you leave the description blank then CutMaster Imports the parts incorrectly and the fields shift. This is now fixed. The current work around is to not leave the description blank.
          2. Side panels have some discrepancies in CutMaster as compared to DxfConfig. DxfConfig is correct. I'm currently working on figuring out why the difference.
          Users are welcome to discuss anything that they are finding.
          • G
            Garry K
            1. Kick Joinery is one of the bugs. Turns out it wasn't hooked up. Fixed.
            2. Also Full Dado wasn't hooked up. It is now fixed.
            There are a couple more discrepancies. I will fix them and put out a new version.
            • G
              Garry K
              1. The drawer box backs and fronts were switched. It's an issue when notching for undermount drawer slides. Fixed in CabMaker
              2. Right and Left Doors were reversed. Fixed in CabMaker and in CutMaster
              3. Holes for cup hinges now aligned. Doors need to be a multiple of 32 mm plus or minus a fixed amount.
              Working on multiple rules. If you have a rule defined in CabMaker then you can set up a corresponding rule (same name) in Cutmaster. If the CabMaker rule doesn't exist in CutMaster then CutMaster's default rule "default" will be applied.
              • G
                Garry K
                1. Drawer Stretchers were not aligning. Fixed
                2. Drawer Slide holes in sides were missing. Fixed
                3. Drawer Box Front and Backs reversed. Fixed
                4. Enabled multiple Dxf Configuration files. These line up with Rules in CabMaker
                5. Licensing not working for some users. I believe this is now fixed.
                Version 2.0.1.27 of CutMaster now available on my web site
                Version 2.o.1.27 of DxfConfig now available on my web site
                Also CabMaker 1.0.58 is now available. Part of the fixes just mentioned were on CabMaker side.
                • G
                  Garry K
                  Back to CabMaker
                  Working on Version 1.0.60
                  • Added more context help graphics. You can now see the handle choice when you mouseover 1 of 7 controls that let you specify handles.
                  • Added a new vanity that has been requested. It has 2 small drawers and the sink is centered. You can also set this up for standard cabinets. In this case it isn`t a sink front it is an actual 3rd drawer.
                  • Working on angled end cabinets next.
                  • G
                    Garry K
                    1. Added Angled End cabinets for uppers and base cabinets
                    2. Added Cabinet (Description in Web Dialog) to Labels
                    3. You can know start a label run with a partial sheet. Just enter in the number of skipped labels.
                    • G
                      Garry K
                      I've also added support for labels using an A4 format. These labels will be slightly larger and will have 24 labels per sheet instead of 30.
                      • G
                        Garry K
                        I'm now supporting A4 and letter for CutMaster Reports.
                        I've also finished the Angled End Cabinets
                        • G
                          Garry K
                          CabMaker version 1.0.60 is now ready for download
                          CutMaster version 2.0.30 is now ready for download
                          DxfConfig version 2.0.30 is now ready for download
                          • G
                            Garry K
                            Now working on Version 1.0.61
                            Here is a return cabinet and an angled cabinet with different depths
                            • G
                              Garry K
                              I imported all the parts into cutmaster and then created the dxf file. Then I imported the dxf file back into sketchup to check the accuracy.
                              The trickiest part is the angled corner top and bottom panels lining up properly with the sides. I set up for 3 mm edging and wanted a 400 mm finished side and for all the drilling to line up.
                              The setup includes system holes at 37 mm from the finished edge and drilling for rafix 32 mm from back and front edges 400 mm - 64 mm = 336 mm. So accuracy is there.
                              • G
                                Garry K
                                CabMaker version 1.0.61 is now available from my web site.
                                1. corner cabinets with different depths (left side and right side)
                                2. import dxf now defaults to where cutmaster places the dxf files.
                                3. fixed a couple of bugs for reporting of parts_list_2
                                • G
                                  Garry K
                                  DxfConfig and CutMaster versions 2.0.1.31 are now available from my web site.
                                  They both now support Corner Tops, Bottoms and Shelves which have different depths for each side.
                                  • G
                                    Garry K
                                    New versions are now available.
                                    • Cutmaster now supports adjusting connectors for angled end cabinets tops and bottoms.
                                    • Cutmaster now allows you to set up labels for A4 printers as 24 or 30
                                    • Added a reload feature to dxfConfig so you can modify samples.ini and reload without having to restart dxfConfig.
                                    • CabMaker synchronized with CutMaster
                                    • Added support for edge all edges for angled shelves
                                    • G
                                      Garry K
                                      I'm working on CabMaker 1.0.63
                                      • Added blind partition for drawer hardware as an optional rule for Frameless construction.
                                      • Fixed bug with for corner cabinet shelves where brace width is 0.
                                      • Fixed bug with Fillers for corner cabinets. The Right filler was not positioned correctly
                                      • Blind cabinet fillers now positioned between the blind panel and the cabinet butting up to the Blind Cabinet.
                                      • Added Double Filler for frameless overlay construction as an option.
                                      New version available shortly.
                                      • G
                                        Garry K
                                        Version 1.0.63 of CabMaker now available.
                                        Also Version 2.0.1.33 of DxfConfig and CutMaster now available on my website.
                                        Merry Christmas
                                        • FrederikF
                                          Frederik
                                          Merry Christmas, Garry!
                                          http://www.kerkythea.net/users/Frederik/Anim-Icons/xmas.gif
                                          Cheers
                                          Kim Frederik
                                          • G
                                            Garry K
                                            I've added a strategy for users who like to work with templates and fixed sizes. Templates are in library folders and have file extensions of .txt
                                            So if you have a base sink cabinet with 2 doors you could name it somethiing like BSD This means there will be a file named BSD.txt If you want to provide a number of widths then you simply create a text file called BSD.dat and in it you would have 1 line:
                                            widths=30|36|42|48
                                            I'm also supporting heights and depths
                                            Now CabMaker will give you a drop down list with these 4 widths for template BSD. All other templates that do not have a corresponding file with a line for widths will give you a text box and you enter a width.
                                            I've also added a parameter that allows you to override the insertion height for upper cabinets (or leave as -1 to use the height in the rules)
                                            There have been several requests to set drawer box heights. I am now working on this feature that will override the drawer box adjustment in the rules.
                                            With your input, this post could be even better šŸ’—
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 31
                                            • 32
                                            • 17 / 32
