    [RESOLVED] Guide-Points in Groups or Components
    5 Posts 2 Posters 513 Views 2 Watching
      I want each Guide-point as a Component!
      I have something named Convert in Single Components (or Groups)
      but alas that convert only one Guide-Point from a selection of guide-points in Component! (or group)
      So not each guide-point as Component! ๐Ÿ˜ฒ
      You must relaunch for a new conversion (and again only one) so not very practical! ๐Ÿ˜ฎ
      Loose to groups curioulsly gives also only guide-point as group! ๐Ÿ˜ฎ
      If you have some ideas don't hesitate! ๐Ÿ˜„
      • sdmitchS Offline
        sdmitch
        Select Guide Points. Right click on anyone of them. Choose "Guide Points to Components"
        unless file_loaded?((__FILE__))
         UI.add_context_menu_handler do |menu|
          if Sketchup.active_model.selection.first.is_a?(Sketchup;;ConstructionPoint)
           menu.add_separator
           menu.add_item('Guide Points to Components') {
            Sketchup.active_model.start_operation "Guide Points to Components"
            cps = Sketchup.active_model.selection.grep(Sketchup;;ConstructionPoint)
            cps.each{|cp|
             grp = Sketchup.active_model.active_entities.add_group(cp)
             grp.to_component
            Sketchup.active_model.commit_operation
         file_loaded((__FILE__))
        http://sdmitch.blogspot.com/
          Cool that's works! ๐Ÿ‘
          So with your fabulous Component Random Replacement! ๐Ÿ˜‰
          Here Guides-Points are 8 vertices of a box! ๐Ÿค“
          PS Can we have a little rb file for have it in the SDM Tools Menu ?
          • sdmitchS Offline
            sdmitch
            Usage: Plugins>SDM Tools>CorG Tool>Guide Point to Component
            Works from the Plugins menu or by Right click.
            Guide Point to Component.rb
              Excellent! ๐Ÿ˜Ž ๐Ÿ‘
