    [REQ] Export a specified series of scenes
    30 Posts 6 Posters 4.0k Views 6 Watching
    • sdmitchS Offline
      sdmitch
      @numerobis said:
      Is there a plugin that lets you export a specified (selected) series of scenes as images?
      I have to export a series of images for a shadow analysis. Three different designs, two viewpoints and maybe 30 different time settings. This is a LOT of images to export, so a plugin to automate this process would really helpful.
      I sent, via personal message, a plugin for you to try.
      http://sdmitch.blogspot.com/
      • JQLJ Offline
        JQL
        sdmitch strikes again! 👍
        www.casca.pt
        Visit us on facebook!
        • sdmitchS Offline
          sdmitch
          @numerobis said:
          @sdmitch
          Is it possible that the script is not working if only the shadow setting is stored in a scene? I only get 0KB files without file extension. I have no idea.
          Btw. would it be possible to make the selection dialog larger or scalable. Right now i can only see three or four of maybe 30 scenes which makes it a bit laborious to select them.
          Yes you can set a size or number of entries to be displayed. I will PM you a copy with the size set to 30
          • N Offline
            numerobis
            Much better with the bigger window!
            @sdmitch said:
            I have no idea.
            So is each view working separately or is it based on the previous view? Would it be possible to let it act like the normal SU scene switch?
            • sdmitchS Offline
              sdmitch
              Seperately I think.
              Do you mean with a "transition"? If so the answer is no because the plugin doesn't wait.
              • N Offline
                numerobis
                No, i mean that i can specify a camera position and layer setting, etc. in one scene that i select first and the export multiple scenes that have only the sun position stored.
                • sdmitchS Offline
                  sdmitch
                  Sorry I can't answer that. I'm just a simple coder.
                  • JQLJ Offline
                    JQL
                    What this means is that sdmitch doesn't use sketchup, just likes coding.
                    www.casca.pt
                    • sdmitchS Offline
                      sdmitch
                      As JQL said, since I don't use Sketchup in any meaningful way, it is hard for me to quickly grasp what it is you want. After thinking more about it, it seems to me now that you want to take a "base" scene and then add "sun" layers one at a time and export that image.
                      Am I getting closer? It would be most helpful if you could send me a sample model illustrating what you a striving for.
                      • N Offline
                        numerobis
                        Sure, here is a simple demo scene.
                        I just separated the camera position(s) and the sun settings to be able to control them separately and maintain the same camera position.
                        I simply have one or more scenes that contain all camera and style settings and then i have multiple scenes that define only different sun positions (date and time). So i first select the camera defining "base"-scene and then after that i cycle through the scenes with the sun positions one by one and export the resulting images.
                        scene_export.skp
                        • sdmitchS Offline
                          sdmitch
                          Ok, I think I finally get it. Please check Personal Messages for latest version.
                          • N Offline
                            numerobis
                            @sdmitch
                            Wow! That's great. Thanks for your effort! 😎
                            I have a "base scene" without sun angle and then many different scenes defining only date and time. So i select the "base" scene and then cycle through the "time" scenes and save them.
                            I have to say that i already bought the SceneExporterPro now and it seems to have the same problem.
                            • N Offline
                              numerobis
                              Yes, you're right, it's working great now! Thank you very much! 😎 👍
                              Do you have some donation account so that i can at least pay you the same $10 that i payed for the "useless" SceneExporterPro? 😳
                              • sdmitchS Offline
                                sdmitch
                                No I am strictly a non-profit organization!!!!!!
                                • N Offline
                                  numerobis
                                  Ok. Then once again: Thank you very much! 😄
                                  • JQLJ Offline
                                    JQL
                                    LOL!
                                    www.casca.pt
                                    • N Offline
                                      numerobis
                                      Sorry, but I just needed a quick solution for a project, that was why I bought your plugin. It didn't work for me.
                                      I posted this in your forum and got no reply - you answered almost 4 days later, but without offering a solution. Without the help of sdmitch i would have had to export the scenes manually, since I had to finish the project.
                                      I don't know if it's a "glitch" in SU, but it seems to be possible to deal with it, as the solution of sdmitch is showing. And I'm using v2015, so even if it is a SU problem it's not a new one. And regarding your workaround... so you're saying, everything is working ok, I just have to change the scene settings every time I switch the camera? Really? Yes, i tried it and it's working, but it's not very practical when I have to do this every time I switch the camera when I have several dozen scenes - and this is why I bought your plugin. And seriously... this is your solution?
                                      Anyway... $10 payed - lesson learned.
                                        RickW
                                        That's an unfair accusation. This is a glitch within SketchUp, not a problem with SceneExporterPro. You also didn't contact me through our contact page as I requested so I could get more information from you to resolve the problem.
                                        I checked your file and saw what you described - top-down views being exported. But that is not the problem - it is only a symptom of the problem. The problem is that a top-down view was assigned to the scenes and was overriding the "no camera location" setting during export. I selected the three "date and time" scenes in the Scenes dialog, checked the "Camera Location" box, then unchecked it, and exports were successful using either "camera 1" or "camera 2" (edit: with no further action required from the user).
                                        So please, before posting unfair accusations, let the author get to the root issue.
                                        RickW
                                        www.smustard.com
                                          RickW
                                          We have a contact page for a reason - fast, direct customer service. The forum is for community discussion, and you posted on a weekend (when I focus my time on my family). More on my reply below, but the short answer is that you didn't give me enough detail to provide more than a cursory response and a workaround.
                                          Since the solution you received was purpose-built for your specific need, and the author had the benefit of your sample model to work with, I would expect a working solution. The challenge of providing for a broader use case and not (initially) having the benefit of your sample model for testing against means a solution may take more time.
                                          Incidentally, if you have a series of steps that you can present to replicate this particular situation, please share them so I can send it to the SU dev team.
                                          Just because it's not new doesn't make it prevalent. Yours is the first case I've seen of it since I developed SceneExporter (and I use it regularly for my own work).
                                          A workaround is a temporary "solution" until a more satisfactory solution is identified. Since you didn't contact me through the contact page as I requested to get more information about your particular problem (since my test couldn't replicate your issue), and since you didn't post a sample file in your initial post, all I could do was offer a workaround.
                                          Once I had more information, I was able to present a more workable solution - a one-time-only select all "shadow" scenes, check and un-check the "camera location" box that clears out the "rogue" information created by the SU bug. That 6-second solution for an obscure bug was adequate while I worked out a solution (and that solution is now available).
                                          Anyway, since I refunded your payment, I'm wondering what lesson you think you learned. The first lesson should be that we want to help you, not take advantage of you. The second lesson should be to provide adequate information for a help request through appropriate communications channels, and to help those trying to help you. We (all the developers) want our products to work for you, and we want to help you when there are problems.
                                          Though I don't like how things have transpired, I'm thankful that you made me aware of this obscure SU bug, and that you (inadvertently, perhaps?) helped me make SceneExporterPro better.
                                          RickW
                                          www.smustard.com
                                          • N Offline
                                            numerobis
                                            Thanks for the refund!
                                            But concerning your comment
                                            @rickw said:
                                            "since I refunded your payment, I'm wondering what lesson you think you learned."
                                            I think you know this is nonsense since my comment is from Nov. 26 and I received your refund on Nov. 28.
                                            And regarding your repeating "contact page" statement... I posted on your forum because I thought this would be its purpose and I wasn't aware of your contact page. Your first post about the contact page was on wednesday in your first reply to my forum post.
                                            I think I already described the steps since there is nothing more involved than creating new scenes - with and without camera information.
