    Subtract Shape...Simple Solution?
    Scheduled Pinned Locked Moved Organic Modelling
    9 Posts 3 Posters 13.9k Views 3 Watching
      studioarts
      I am trying to model the skin of an internally illuminated sign that requires up to 296 circular cut-outs in the skin. I have used the solid tools "subtract" function which only addresses one cut-out at at a time and by the time I got to what you see in the attached image, it takes 30-40 seconds per application and does not always work as evidenced by the random odd pucks still showing in the cut-out area.
      Trying to select all and subtract locks up the program. The computer is an i7 HP with Nvidia GeForce GTX 750 Ti grahics card so I don't think its that - but could be I need more RAM.
      Thoughts? Suggestions? Plugins?
      • cottyC Offline
        cotty
        I would start with a much smaller part and use a repeated copy of a component here...
        my SketchUp gallery
          studioarts
          Great idea - and it worked smoothly until I exploded all 37 components to eliminate the lines between each and it has locked up again. Did you just hide the join lines?
            studioarts
            I hid the top/bottom lines -works fine. Thanks for the help.
            • cottyC Offline
              cotty
              If you modeled the component as a solid, you can combine them with one click with the solid tools...
              click to animate
              my SketchUp gallery
                studioarts
                Good to know - thank you.
                  studioarts
                  Ok, SU says that the "skin" model is not a solid ( true I guess as it is made up of 30+ components - none of which SU thinks are solids). Question is this: can the "non-solid be converted to a solid or would any latent straggler geometry make that a no-go?
                  Next I need to subtract the multi-piece letters from the skin. Solid Tools not working due to the "solid" issue...thoughts?
                  I made the skin from a very clean 300 segment circle with simple square tube cuts at the side reveals - should be very clean.
                    For boolean operations and for 3D Print you must have real "solid"!
                    Use Solid Inspector by Thomthom & Solid Solver by TIG for repare your volumes! πŸ˜‰
                      studioarts
                      Thank you - I will try these in the morning.
