    Run auto completion for Sketch up API in RubyMine
    6 Posts 2 Posters 1.4k Views 2 Watching
    • O
      omda2000
      I need help to run auto completion for sketchup API in RubyMine .
        Working on a tutorial for this.
        Meanwhile the gist of it is:
        Get a copy of Jim's SketchUp Ruby API Docs on GitHub: https://github.com/jimfoltz/SketchUp-Ruby-API-Doc
        They will act as stubs. (Missing some argument info. I tend to fill that in and send back pull requests.)
        Then add the lib folder to the Project;
        • O
          omda2000
          is there any way to connect sketchup debugger to sublime to include the API in the intellisense . same like Rubymine for example
            hmm?
            Not sure about the intellisense. Unsure how Sublime handle that.
            As for the debugger, I think it should work if you can find a package that let you set up remote debugging.
            • O
              omda2000
              I added the LIB folder into the project folder , but still Sketchup API autocomplete is not working . Can you advise ?
              thans
                RubyMine only need to know/care about the lib folder in that repo. You can tell it to ignore the other folders.
                As for the auto-complete, I'm having some issues right now myself. Maybe something changed with RubyMine... I'm not sure. Looking into it.
