    Upholstered furniture
    328 Posts 54 Posters 169.6k Views 54 Watching
    • alvisA Offline
      alvis
      @solo said:
      Alvis, these are amazing you are truly the furniture master.
      What is the "Fractal Terrain Eroder plugin"? I know of an Erode plugin by Eronoth, is it the same?
      Thank you. I think this is the same plugin.
      • alvisA Offline
        alvis
        Pascal armchair
        [edg3d:3bgmjc20]IpobOyi9fOUn8o5[/edg3d:3bgmjc20]
        • jo-keJ Offline
          jo-ke
          thank you for sharing your workflow. It gets a little more transparent for me to follow.
          You are a real master. I wish I had your skills.
          http://www.zz7.de
          • alvisA Offline
            alvis
            Thank JOKE.
            Next - Riverside Exposed Frame Chair
            [edg3d:1cma5k7h]LhoMc8BcRMMqyat[/edg3d:1cma5k7h]
              kagealita
              Alvis,
              Thank you so much for the step-step instructions & the quick response, your are my guru. Do you mind tell me the plug-in you had used for the above two chairs? I'm using Sketchup 2016.
              Alita
              • alvisA Offline
                alvis
                I think the main plugin is your brain.
                All other things being just a tool that helps you. Besides the main Sketchup tools (Line, Arc, Intersect ...), I use a this plugins. They are the best for such a task.
                  Cool plugins indeed! 😎
                  @Alvis
                  Does the flag Blue, White, Red under your avatar is the French one
                  or it's other thing? πŸ˜„
                  • alvisA Offline
                    alvis
                    @Alvis
                    So it was a french motive of my solidarity. If seriously, what happening in other parts of the world (you know what I mean), my heart hurts is also.
                      @Alvis
                      Thx for the explanation and the solidarity! 😎
                      Have you try the Free Su TGI3D ?
                      Seems it's can be used for tortured furnitures! πŸ˜„
                      Manual
                      So crazzy things about Components! 😎
                      http://s6.postimg.org/rcdynmgpd/GIF_instanc.gif
                      • alvisA Offline
                        alvis
                        Chesterfield sofa.
                        chester segment.zip
                        • jo-keJ Offline
                          jo-ke
                          Thank you, makes things better to understand
                          http://www.zz7.de
                          • marked001M Offline
                            marked001
                            I love this thread. Even with the instructions, I still don't know how you do it.
                            http://www.revision21vis.com
                            instagram: revi21on
                            • alvisA Offline
                              alvis
                              Contuor sofa
                              • alvisA Offline
                                alvis
                                Simple tufted lounge workflow
                                  Sems very cumfortable! 😎
                                  No armrests ?
                                  • alvisA Offline
                                    alvis
                                    Thanks Pilou. Yes, no armrest. And here final result
                                    • cottyC Offline
                                      cotty
                                      Perfect!
                                      (If you need an address to send an example realisation to someone let me know)
                                      my SketchUp gallery
                                      • alvisA Offline
                                        alvis
                                        Leather Club armchair
                                        [edg3d:zbcgnkts]MuZedwo7zZA5V5n[/edg3d:zbcgnkts]
                                        • Bryan KB Offline
                                          Just stunning!
                                          And thanks for posting some screen shots from your workflow. I just got Artisan re-installed and this is great information on how to make the first forms!
                                            cuttingedge
                                            You're a certified master for upholstered furniture Alvis. Do you prefer working in non quads over quads?.. do you see advantage of one over the other?
                                            • 16
                                            • 17
                                            • 2 / 17
