    GIS SOFTWARE recommendation reqd.
    7 Posts 4 Posters 5.6k Views 4 Watching
    • john2J Offline
      john2
      I need to generate slope analysis of a site very quickly using some GIS software. I am a novice when it comes to GIS. Google earth and grabbing a terrain in sketchup is the only thing that I have ever touched upon. These are some samples that I got.
      I don't want a heavy duty bulky intimidating software. I just need to do this task. Kindly suggest a suitable solution for me. Moreover, that mesh is a vector linework that was generated.
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        cemyapca
        There was a plug-in for Sketchup that did just that - try searching "Color by Slope". I haven't used it recently though. It paints surfaces according to their slopes. There is also a "Color by Height" variant. These might work for you.
        • john2J Offline
          john2
          I have tried sketchup but it never works out. Here, http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=57167
          • U Offline
            unearthed
            Try this and read it in depth (It's Chris' ColorBySlope tool)
            http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=56825%26amp;p=516133%26amp;hilit=+slope+analysis+#p516133
            vid howto
            http://www.sargeantillustration.com/tutorial-slope-analysis-in-sketchup/
            Subdividing your mesh will help produce a better blur effect but dramatically increase processing time.
            You will always get some sort of tiling effect (but turning linework OFF will help a lot) but you can always blur/smudge in photoshop/gimp/fotosketcher
            QGIS is the other viable approach but if you know nothing about GIS it's a lot to take on board in an afternoon! QGIS will get you there tho
            http://www.qgis.org/en/site/
            But it's not quick to explain - WELL worth learning tho' for another time.
            Growplan - People ∩ Plants ∩ Place
            windows 7 64b, 4GB RAM, SU 8.0.16846
            Gimp, QGIS, Vectorworks 12, Bricscad 11
            • pbacotP Offline
              My wife has been working in GIS for years, with ESRI. She recommends qGIS and thinks someone like me (with CAD background) might pick it up OK.
              • U Offline
                unearthed
                Re QGIS - I'm self-taught in GIS and tend to use it for simple things like converting tiff file data (look like a monochrome image file, but each pixel contains for instance height data) into dxfs and so getting a contour file. Currently am working on using it to produce variable-width setbacks for waterway protection - which IS pretty difficult, but like this place there are great communities to ask questions.
                • john2J Offline
                  john2
                  Thanks I will try this with qGIS. πŸ˜„
