    [code] reset webdialog and toolbars .bat file
    15 Posts 4 Posters 4.1k Views 4 Watching
      Jim
      Toolbars were easier since there is an entry in the Summary that tells yo how many Toolbars there are in the registry. And since the toolbars are numbered in order, it's easy to reconstruct their key and remove them.
      There isn't any summary information for WebDialogs, so you need to find them by name.
      The other thing i do is sometimes is completely remove the Sketchu7 section, but sometimes I am only interested in resetting toolbars and dialogs in order to test the "first opening" experience.
        I found that on one of my systems the count and number of entries didn't match. I had more entries than the count.
        Can't the values be enumerated?
        Not sure how it works with .bat files, but with the Win32::Registry you can iterate over a registry path's keys and values.
          @gavvy said:
          reg query "HKEY_CURRENT_USER\Software\Google\SketchUp7" /s|find "WebDialog"
          reg delete "HKEY_CURRENT_USER\Software\Google\SketchUp7" /s /f
          Jim, did this work?
          When I run reg query "HKEY_CURRENT_USER\Software\Google\SketchUp7" /s|find "WebDialog" in a command prompt it does list all the entries, but I've yet to try the delete command. I don't understand how it would know what to delete. does it reference to the previous query command?
            Jim
            I am at the same point as you.
              Looking at http://technet.microsoft.com/en-us/library/bb490984.aspx
              reg delete KeyName [{/v EntryName|/ve|/va}] [/f]
              I see no /s argument. And /f seem to suppress all prompts. I wonder if that command nukes the whole Sketchup section...
                Jim
                I came up with this:
                reg query "HKEY_CURRENT_USER\Software\Google\SketchUp7" | find "WebDialog_" > reg_keys.txt
                reg query "HKEY_CURRENT_USER\Software\Google\SketchUp7" | find "ToolbarsUser" >> reg_keys.txt
                for /f %%k in (reg_keys.txt) do (
                    reg delete %%k /f
                  >     reg delete %%k /f
                  This snippet just saved my day.
                  I'd been working on a plugin where I ran into errors in the code that created toolbars - and that cause Toolbar Shuffle. Eventually I noticed that the SU window became very sluggish - when opening, resizing, focusing etc.
                  I'd experienced this before - had to reinstall SU.
                  This time I checked the registry .... 1600+ ToolbarsUser items!!! 😲 Pluss double in the backups which SU8 makes.
                  Running that snippet of yours cleaned up the system. SU is as snappy as anything again.
                  Another point scored for Toolbar Shuffle....
                    Jim
                    It's really screwed up. It seems if you turn off a plugin via the Extensions dialog, the next time it is enabled, any Toolbars are treated as new and new Registry entries created.
                    It's sort of killing my idea for a pre-launch extensions manager because toolbars are reset whenever an Extensions is re-enabled.
                      I wish SU would get a brand spanking new Toolbar system. 😒
                        mumbus
                        > >     reg delete %%k /f
                        Dumb question. Does this get entered at the CMD prompt? I get errors.
                        %%k was unexpected at this time
                        Error: Invalid key name.
                          Jim
                          Unless you're still using SketchUp 7 or 8, you don't need this; and even if your are, you still probably don't need it.
                          What problem do you wish to solve by running this code?
