    Problems with PickHelper
    14 Posts 3 Posters 1.5k Views 3 Watching
    • hsmyersH Offline
      hsmyers
      I'm trying to allow the user to pick two objects with the intent to align the second selection with the first. I'll allow embroidery regarding axis and points later. With that in mind I thought this was a good chance to use PickHelper. So I created a small class as follows:
      class HSM_Picker
        def activate
          @@picks = []
          Sketchup.set_status_text('Select an object', SB_PROMPT)
        def deactivate(view)
          view.invalidate
        def onLButtonUp(_flags, x, y, view)
          ph = view.pick_helper(x, y)
          ph.do_pick(x, y)
          @@picks << ph.best_picked
          if @@picks.length == 2
            p 'done'
            Sketchup.active_model.select_tool(nil)
        def onCancel(_flag, _view)
          Sketchup.send_action('selectSelectionTool;')
      end # class HSM_Picker
      This for reasons unknown to me does not work. In my effort to debug I wrote the following snippet in the console:
      x = y = 0
      view = mod.active_view
      ph.do_pick(x, y)
      best_entity = ph.best_picked
      As you might guess this did not work either. 😞
      So what am I doing wrong? Efforts to amend my abysmal ignorance will be deeply appreciated!!
        Can you elaborate to what didn't work and what you expected to see happening?
        • hsmyersH Offline
          hsmyers
          Never having used PickHelper, I really didn't have any expectations other than a vague notion of some indication that the code was in control of the 'pick' process but I saw no such indication during testing. I noticed that what I was printing to the console didn't appear which suggests an error of some sort...which I foolishly failed to save, I clear the console with each run head slap I'm not even all that clear on how I should integrate what I need with the tool under development—roll it into the tool or separate class within?
          • sdmitchS Offline
            sdmitch
            In the API the ph = view.pick_helper statement does not does not have variables passed to it. Taking off the (x,y) made it work for me.
            class HSM_Picker
              def activate
                @@picks = []
                view.invalidate
                ph.do_pick(x, y)
                  p 'done'
            Sketchup.active_model.select_tool HSM_Picker.new
            http://sdmitch.blogspot.com/
            • hsmyersH Offline
              hsmyers
              class HSM_Picker
              >   def activate
              >     @@picks = []
              >   end
              >     view.invalidate
              >   end
              >     ph.do_pick(x, y)
              >       p 'done'
              >     end
              >   end
              >   end
              Ah! On such screw-ups as this are founded the bugs that plague us! 👍 👍 👍 😄 Much and many thanks sir.
              • hsmyersH Offline
                hsmyers
                Back to debugging... The following appears to run without error—or actually without doing anything other than returning "[]"!
                mod = Sketchup.active_model # Open model
                ent = mod.entities # All entities in model
                sel = mod.selection # Current selection
                SKETCHUP_CONSOLE.clear
                class HSM_Picker
                  @@picks = []
                  def activate
                    @@picks = []
                    view.invalidate
                    ph.do_pick(x, y)
                      p 'done'
                  def picks
                    @@picks
                pk = HSM_Picker.new()
                ets = pk.picks
                Implication clearly being that I don't know what I'm doing (certainly true!) So once again begging for clues here... 😞 In line with previous I had expected
                ph.do_pick(x, y)
                to politely wait for the user to make a selection (or two) and then be available for interrogation but I fear that may have been naive. My initial understanding ( or miss in this case ) is often warped by my expectations based on years of building APIs more sigh 😞 😞
                  What is the value you get from .best_picked?
                  That should only return an entity - so I wouldn't expect @@picks.length to work. (Unless you accidentally picked an edge - in which case you are getting the length of the edge.)
                  • hsmyersH Offline
                    hsmyers
                    Don't know, will find out...oh the joys of print statements! 😄
                    • sdmitchS Offline
                      sdmitch
                      The class HSM_Picker works as a Tool but must be envoked by Sketchup.active_model.select_tool HSM_Picker.new. The problem is getting the two selected entities returned since the normal return is the model object.
                        Try the debugger: https://github.com/SketchUp/sketchup-ruby-debugger
                        I prefer RubyMine for debugging: http://forums.sketchup.com/t/please-help-me-to-setup-de-debugger-on-rubymine-for-mac/289
                        • hsmyersH Offline
                          hsmyers
                          Hmmm...haven't used any, could be interesting...
                            So much nicer to debug - no more editing files to add print statements and reloading.
                            • hsmyersH Offline
                              hsmyers
                              As is often the case the problem is simple—code in question works much better if properly invoked:
                              mod.select_tool(pk)
                              Thanks all, sorry for the stupidity 😞
                                No worries - we all learn. Thanks for posting back your solution.
