    Deck build. SU to real.
    21 Posts 9 Posters 4.7k Views 9 Watching
      davidheim1
      Excellent work, baz. Both the model and the real deck look great.
      • bazB Offline
        baz
        Thanks David
        • Joe WoodJ Offline
          Joe Wood
          Boy that's the craziest way to frame a deck I've ever seen! Are those round poles standard for the posts down there? How are they attached to the footing?
          Then those 4 big joists over the 6 beams is way different then anything I've seen.
          how did you build the curved gray rims? Full length laminated, or shorter segmented pieces?
          How tall will that top step be? That's some nice looking decking!
          I love seeing different methods of building, looking foreword to seeing it complete!
          Joe Wood
          woodsshop.com/
          • bazB Offline
            baz
            Hey Joe, not sure whether 'crazy' is a compliment, I fear not.
            Funnily enuf I almost contacted you about the design in the early stages but was happy that I'd nutted it out.
            No - round posts not standard but here they provide good bearing surfaces for the lams.
            The beams are positioned that way to support the posts laterally.
            Rims are 2.4mtr strips of 9mm ply x 3 lams screwed and glued.
            Step is standard 180mm high. Decking is 70 x 19 Spotted Gum, (Corymbia maculata).
            Posts are sitting on pavers which are on packed sand.
            For me it's just a big piece of furniture attached to a wall. With some extra 'legs' instead of the wall plate, you could move it around πŸ˜„
            • Joe WoodJ Offline
              Joe Wood
              Oh I Love crazy methods Baz, and man it turned out nice, great job!
              Joe Wood
              woodsshop.com/
              • bazB Offline
                baz
                Whew! Thought I was going to get blasted there.
                If you have time, I would love to see how you would tackle this sort of thing...
                • cottyC Offline
                  cotty
                  I always love those "from model to real" projects, especially when they are so appealing. πŸ‘
                  my SketchUp gallery
                    Nice work Barry.
                    • tuna1957T Offline
                      tuna1957
                      Cool model, cool result.... only problem I see is you'd play hell getting the design past the inspectors in most of the places I've worked here in the states.
                      • bazB Offline
                        baz
                        Thanks guys.
                          Real to SU! 😎
                          • utilerU Offline
                            utiler
                            Neat little project, Baz. How big was the bucket? πŸ˜‰
                            Just Curious...
                            • bazB Offline
                              baz
                              A Bees' dick larger than the bum. πŸ‘
                              • pbacotP Offline
                                although many places like my area, a structure less than 30" high doesn't need a permit. If however you built it with the house, they'd inspect the steps and all per code.
                                Nice looking deck. What are the deck boards?
                                • bazB Offline
                                  baz
                                  Thanks. Step is standard 180mm high. Decking is 70 x 19 Spotted Gum, (Corymbia maculata).
                                  • Joe WoodJ Offline
                                    Joe Wood
                                    Well, the way I usually get the curves is by keeping it simple, cantilevering the joists out over the beams, running them long, and then using a nice long flexible thin piece of hardwood that bends well (I have a 3/4 x 1" x 16' piece) we bend it around over the tops of the joists, into the curve we want, clamp it off to the joists, and run a 10" circular saw along it over the tops of the joists, trimming all the ends of the joists on a nice fare curve.
                                    I buy 20' pressure treated 2x6s, and have my lumber yard split them in two on a big bandsaw, to 5/8 x 5.5", and bend those around the curve, usually three pieces, screwing the lams together, glued with a poly glue.
                                    Then cover the Lamination with a finish facia, composite facia boards bend easy when they're warm.
                                    This is a lot different then yours Baz but you see how to get some nice curves now and Crazy is one of my highest compliments πŸ™‚
                                    Joe Wood
                                    woodsshop.com/
                                    • Joe WoodJ Offline
                                      Joe Wood
                                      From SUp To Build πŸ™‚
                                      Joe Wood
                                      woodsshop.com/
                                      • bazB Offline
                                        baz
                                        @joe wood said:
                                        From SUp To Build πŸ˜„
                                        I see, thanks Joe. Bit hard to see how the beams are arranged, but I get the idea.
                                        Though with my job the step complicated things muchly.
                                        • Joe WoodJ Offline
                                          Joe Wood
                                          This is how the beams were laid out on that one, I've done two curved steps projects sort of like yours but can't find any pics, they both were so long ago.
                                          Joe Wood
                                          woodsshop.com/
                                          • bazB Offline
                                            baz
                                            Aha πŸ‘
