    STEP file converter
    15 Posts 9 Posters 104.4k Views 9 Watching
    • chriC Offline
      chri
      %(#0040FF)[hello MALAISE
      Please , take a look on the next file , it was something i have explain in french forum]
      %(#FF0000)[It's possible to convert file in IGES STEP SKP STL with free soft and plugins .
      STEP file is import with FreeCAD
      a backup is done in STL
      STL is import in SKETCHUP 8 with plugin jf_stl_importer.rb / Jim Foltz /
      cleaning is done with plugin deletecoplanaredges.rb]
      %(#008000)[des conversions sont possibles entre IGES STEP SKP STL
      ( EN UTILISANT DES LOGICIELS OU PLUGINS GRATUITS )]
      PREMIER TEST
      LES BASES :
      J'avais Autodesk 123D Beta
      je viens aussi de télécharger FreeCAD comme me l'a suggéré PILOU .
      DETAIL DU TEST EFFECTUE
      dessin d'une piéce avec Autodesk 123D Beta
      sauvegarde en STEP
      ( possible directement en STL et IGES )
      Import du STEP dans FreeCAD
      export en STL
      ( ce logiciel autorise de nombreuses extensions en import et en export )
      import du STL dans SKETCHUP 8
      ( plugin jf_stl_importer.rb de Jim Foltz )
      nettoyage
      ( plugin deletecoplanaredges.rb )
      Le résultat est NICKEL
      Le seul souci comme évoqué par PILOU étant la segmentation des cercles et arcs .
      BONS TESTS A TOUS
      • kenK Offline
        ken
        I use SimLab Composer. I have tried the rest, Alibre, ViaCad, 123D beta and others programs, and Simlab does the best conversions. But to be honest, nothing is going to turn a high poly model into something that Sketchup is not going to choke on.
        Ken
        • MALAISEM Offline
          MALAISE
          Great explanation Chri!
          Exactly what I was looking for 👍
          Pierre
            lansd
            This would be an incorrect comment due to lack of knowledge and experience, which is common on SketchUp forums since 2010. As I and the original SketchUp developer worked together to write the main CAD -> SketchUp conversion system in 2005 before he sold off the company, I'll point you to the proper methods to get any sized CAD file into SketchUp with good efficiency:
            Okino Computer Graphics - Professional 3D File Conversion Software
            Okino PolyTrans & NuGraf, the primary 3D CAD, VR/AR and DCC/Animation conversion + optimization products on the market for well over 30 years.
            Okino Computer Graphics (www.okino.com)
            • E Offline
              emartingr
              @pilou said:
              Use Free-CAD
              Import / Export!
              STEP, IGES, OBJ, DXF, SVG, STL, DAE, IFC or OFF
              Seems you can use some one for SU 😉
              Or Moment of inspiration but it's not the same price! 😉
              But you can send me the file in MP 😉
              The free 123D also 😉
              123D can IMPORT (Open) 123D, SKP, SAT,OBJ, DWG (3D solids), STP, 123C (Mesh content).
              123D can export (Save As): STL, SAT, DWG, STP and its native 123D. you can also publish an image.
              Thanks pilou,
              FreCad would be great to convert 3D files to or from SU. The Collada format opens directly in SU. But I found it difficult to load the required conversion plugins into FreeCad. To import/export collada files from SU, the pycollada plugin is required and this involves installing Python, numpy and setuptools (http://www.freecadweb.org/wiki/index.php?title=Extra_python_modules#Installation_3).
              I could not make it work -yet-, perhaps because there are many different versions of each. If someone has already done it, I would appreciate getting the information. If I manage to install it, I will send the detail method.
                Jim
                I can not get the COLLADA export to work yet either.
                However, the .stl export does work. What's better is that FreeCAD does not need to be running to convert a .step to .stl. The FreeCAD Python API can be used to convert the file and a plugin can be made to import .step as an .stl from SketchUp.
                The python script I am testing is very simple:
                # conv.py
                FREECAD = 'C;\\Program Files (x86)\\FreeCAD 0.14\\bin'
                import sys
                sys.path.append(FREECAD)
                import FreeCAD
                import Part
                part = Part.read("C;/Users/Jim/Downloads/545424.STEP")
                part.exportStl('C;/users/jim/part.stl')
                In addition, you do not need to install Python. I was able to use FreeCAD's embedded Python to run the script:
                "c;\Program Files (x86)\FreeCAD 0.14\bin\python.exe" conv.py
                That's it. It will probably take SketchUp longer to import the .stl than FreeCAD takes to perform the conversion.
                So there you have it with a little more work, a poor-man's .step import.
                  Aroundthebend
                  @malaise said:
                  Thanks Pilou,
                  I'll test freecad and then convert the file. 👍
                  Pierre
                  Hi MALAISE, did you have any luck using Freecad to import STEP files i.e.:
                  Step into Freecad export as .stl >import into Sketchup.
                  cheers
                    It's that we can say a very good article! 👍
                      Aroundthebend
                      Thanks pilou. I now know what I need (once I read the article a few times!). Yes a very good article 👍 .
                      • hsmyersH Offline
                        hsmyers
                        Slight improvement, tested and working:
                        # step2stl.py
                        FREECAD = 'C;\\Program Files\\FreeCAD 0.15\\bin'
                        import sys
                        import FreeCAD
                        import Part
                        part = Part.read(str(sys.argv[1]))
                        part.exportStl(str(sys.argv[2]))
                        Late to the dance, but just ran into the problem 😞 => 😄 Thanks Jim !!
                          Aroundthebend
                          Hi all, I've been looking at this problem for some time. I've now started using Afanche3D Pro (£29'ish) which is a 3D file viewer. It can import STEP files (and others) and export to DAE (and other formats). I've found it very us usfull.
                          The STEP files I receive are usually in mm so I've set Afanche3D Pro System Length Unit to mm and the Default File Importing Length Unit to cm (these setting are found in the Options (Grey cog in tools above work area). This is so it enlarges by 10. I then export as a DAE and import this into SketchUp. Because the units in my SU are set as mm the DAE file will import at x10 (that makes it x1000 the original model size).
                          Afanche do some other viewers that only open one file type (i.e. STEP viewer £23)
