    From AutoLisp to Ruby
    14 Posts 5 Posters 2.5k Views 5 Watching
      Deanby7
      Many thanks to both of you
        Deanby7
        I think I am not understanding something as I'm getting an error....
        Error: #<NoMethodError: private method `class_variable_get' called for SaM::Pick_Points:Class>
        This is my test code.....
        require('sketchup.rb')
        def pick
        n = 2
        Sketchup.active_model.select_tool SaM::Pick_Points.new(n)
        SaM::Pick_Points.class_variable_get(:@@pts)
        puts @@pts[0]
        puts @@pts[1]
        module SaM # namespace it so it doesn't clash
        class Pick_Points
        def initialize(n)
        @ipt = Sketchup::InputPoint.new
        @@pts = []
        @count = n
        @tally = 0
        def onLButtonDown(flags,x,y,view)
          @ipt.pick view,x,y
          @@pts << @ipt.position.to_a
          p @tally  += 1
        if @@pts.length == @count
          p 'done'
          Sketchup.active_model.select_tool(nil)
        if (not file_loaded?("dbpick.rb"))
        UI.menu("Plugins").add_item("dbpick") { pick }
        file_loaded("dbpick.rb")
          Deanby7
          Is the code to have the pick points snapping to geometry and inferencing involve a lot more code?
            driven
            you have a few things going wrong there and it's easier for me to add some note to one that works...
            the main one is you need to get your own copy of the class variable and ruby doesn't wait when you call the tool, so you have to...
            this one adds a timer, and adds your method into the same namespace as the class...
            module BbN # namespace it so it doesn't clash
              extend self
              # avoid common names for methods
            	def bd_pick
            	n = 5
            	# call the tool
            	Sketchup.active_model.select_tool BbN;;Pick_Points.new(n)
            	# get it's id
            	tool_id = Sketchup.active_model.tools.active_tool_id
            	#create a timer and use the id to know if it's finnished
            	wait_for_tool = UI.start_timer(1.0, true) do
            		if Sketchup.active_model.tools.active_tool_id == tool_id
            		else
            		  # this is the 'pop' back, we retrieve the values from the @@var
            			result = (BbN;;Pick_Points.class_variable_get(;@@pts))
            			# I prefer p over puts as it shows a usable array
            			p result[0]
            			p result[1]
            			# clean up
            			UI.stop_timer(wait_for_tool)
            	class Pick_Points
            		def initialize(n)
            			@ipt = Sketchup;;InputPoint.new
            			@@pts = []
            			@count = n
            			@tally = 0
            			@ipt.pick view,x,y
            			p @tally += 1
            				p 'done'
            	# add menu , toolbar or shortcut key cmd
            	unless  file_loaded?("dbpick.rb")
            	  cmd = UI;;Command.new(BbN;;bd_pick)
                UI.menu("Plugins").add_item("dbpick") {cmd}
            also, use code blocks in the forum, it's in the toolbar...
              Deanby7
              Sorry John
              With the above code I'm getting......
              Error Loading File dbpick.rb
              Unrecognized command id
              I'm running Version 8 Sketchup.
              Dean
              • G
                Garry K
                Dean - why don't you study linetool.rb
                It comes with sketchup 8 and is in your plugins folder.
                linetool.rb gives a pretty good example of what is possible. It is missing a few features that you might want such as setting up a tool bar.
                  driven
                  @deanby7 said:
                  ...I'm running Version 8 Sketchup
                  Sketchup.active_model.tools.active_tool_id has been around since v6?
                  try it in Ruby Console after a tool change, does it fail there?
                  but, I agree with Garry on linetool.rb, I made a few tools based on it...
                    Deanby7
                    The menu item does not appear in the plugin drop down, but the script is obviously running because the ruby console is repeating an error message! I never thought picking two points on the screen could be so difficult!!
                      driven
                      Sam's was the basic that you should get working first...
                      mine was an elaboration to show passing the the pts to something else...
                      have a look at the query tool in the examples folder as well...
                        Deanby7
                        I now have the two pick points working from sdmitch's code. I will study the linetool.rb script to fathom getting the cursor to snap to geometry! Something tells me this will be easy task! 😕
                        • Dan RathbunD
                          Dan Rathbun
                          ... which runs Ruby v1.8.6-p287 on PC, and v1.8.5-p0 on OSX.
                          Error: #<NoMethodError: private methodclass_variable_get' called for SaM::Pick_Points:Class>`
                          For some reason Ruby 1.8 had made class_variable_get() and class_variable_set() to be private methods.
                          In SketchUp v14+ using Ruby 2.0+, they were changed to be public methods.
                          I'm not here much anymore.
