    From AutoLisp to Ruby
    14 Posts 5 Posters 2.4k Views 5 Watching
      Deanby7
      Having written many AutoLisp routines over the years, I've recently turned my hand to Sketchup Ruby. I must admit to finding it a bit more difficult to grasp the object orientated computing than I imagined. Maybe it's my age! Hopefully, slowly but surely I'll get the hang of it, with the help from you guys in this forum.
      I was hoping to find some "recipes" for achieving tasks, but my search on the Internet has not been successful. If anyone knows of such useful code snippets, I would grateful.
      Example:- get the user to pick one or two points on screen and store these as variables. In Lisp, this one maybe two lines of code but looking at line.rb as an example this looks to be very complicated for a ruby newbie! Could anyone assist with the basics?
      I have other questions, but I won't bombard the forum all at once!! : )
      Any help with the above would be most appreciated.
        sdmitch
        @deanby7 said:
        The bare minimum required in Sketchup Ruby.
        class Pick_Two
          def initialize
            @ipt = Sketchup;;InputPoint.new
            @pts = []
          def onLButtonDown(flags,x,y,view)
            @ipt.pick view,x,y
            @pts << @ipt.position
            if @pts.length==2
              UI.messagebox "Point1=#{@pts[0]}\nPoint2=#{@pts[1]}"
              @pts=[]
        Sketchup.active_model.select_tool Pick_Two.new
        http://sdmitch.blogspot.com/
          driven
          expanding on Sam's example, if you want something more flexible...
          module SaM # namespace it so it doesn't clash
          class Pick_Points
            def initialize(n)
              @@pts = []
              @count = n
              @tally = 0
                @ipt.pick view,x,y
                @@pts << @ipt.position.to_a
                p @tally  += 1
              if @@pts.length == @count
                p 'done'
                Sketchup.active_model.select_tool(nil)
          and run it from your code with..
          n = 5 # any number
          Sketchup.active_model.select_tool SaM;;Pick_Points.new(n)
          then retrieve it's values with...
          SaM;;Pick_Points.class_variable_get(;@@pts)
            Deanby7
            Many thanks to both of you
              Deanby7
              I think I am not understanding something as I'm getting an error....
              Error: #<NoMethodError: private method `class_variable_get' called for SaM::Pick_Points:Class>
              This is my test code.....
              require('sketchup.rb')
              def pick
              n = 2
              Sketchup.active_model.select_tool SaM::Pick_Points.new(n)
              SaM::Pick_Points.class_variable_get(:@@pts)
              puts @@pts[0]
              puts @@pts[1]
              class Pick_Points
              def initialize(n)
              @ipt = Sketchup::InputPoint.new
              @@pts = []
              @count = n
              @tally = 0
                @ipt.pick view,x,y
                p @tally  += 1
                p 'done'
              if (not file_loaded?("dbpick.rb"))
              UI.menu("Plugins").add_item("dbpick") { pick }
              file_loaded("dbpick.rb")
                Deanby7
                Is the code to have the pick points snapping to geometry and inferencing involve a lot more code?
                  driven
                  you have a few things going wrong there and it's easier for me to add some note to one that works...
                  the main one is you need to get your own copy of the class variable and ruby doesn't wait when you call the tool, so you have to...
                  this one adds a timer, and adds your method into the same namespace as the class...
                  module BbN # namespace it so it doesn't clash
                    extend self
                    # avoid common names for methods
                  	def bd_pick
                  	n = 5
                  	# call the tool
                  	Sketchup.active_model.select_tool BbN;;Pick_Points.new(n)
                  	# get it's id
                  	tool_id = Sketchup.active_model.tools.active_tool_id
                  	#create a timer and use the id to know if it's finnished
                  	wait_for_tool = UI.start_timer(1.0, true) do
                  		if Sketchup.active_model.tools.active_tool_id == tool_id
                  		else
                  		  # this is the 'pop' back, we retrieve the values from the @@var
                  			result = (BbN;;Pick_Points.class_variable_get(;@@pts))
                  			# I prefer p over puts as it shows a usable array
                  			p result[0]
                  			p result[1]
                  			# clean up
                  			UI.stop_timer(wait_for_tool)
                  	class Pick_Points
                  		def initialize(n)
                  			@@pts = []
                  			@count = n
                  			@tally = 0
                  			@ipt.pick view,x,y
                  			p @tally += 1
                  				p 'done'
                  	# add menu , toolbar or shortcut key cmd
                  	unless  file_loaded?("dbpick.rb")
                  	  cmd = UI;;Command.new(BbN;;bd_pick)
                      UI.menu("Plugins").add_item("dbpick") {cmd}
                  also, use code blocks in the forum, it's in the toolbar...
                    Deanby7
                    Sorry John
                    With the above code I'm getting......
                    Error Loading File dbpick.rb
                    Unrecognized command id
                    I'm running Version 8 Sketchup.
                    Dean
                      Garry K
                      Dean - why don't you study linetool.rb
                      It comes with sketchup 8 and is in your plugins folder.
                      linetool.rb gives a pretty good example of what is possible. It is missing a few features that you might want such as setting up a tool bar.
                        driven
                        @deanby7 said:
                        ...I'm running Version 8 Sketchup
                        Sketchup.active_model.tools.active_tool_id has been around since v6?
                        try it in Ruby Console after a tool change, does it fail there?
                        but, I agree with Garry on linetool.rb, I made a few tools based on it...
                          Deanby7
                          The menu item does not appear in the plugin drop down, but the script is obviously running because the ruby console is repeating an error message! I never thought picking two points on the screen could be so difficult!!
                            driven
                            Sam's was the basic that you should get working first...
                            mine was an elaboration to show passing the the pts to something else...
                            have a look at the query tool in the examples folder as well...
                              Deanby7
                              I now have the two pick points working from sdmitch's code. I will study the linetool.rb script to fathom getting the cursor to snap to geometry! Something tells me this will be easy task! 😕
                                Dan Rathbun
                                ... which runs Ruby v1.8.6-p287 on PC, and v1.8.5-p0 on OSX.
                                Error: #<NoMethodError: private methodclass_variable_get' called for SaM::Pick_Points:Class>`
                                For some reason Ruby 1.8 had made class_variable_get() and class_variable_set() to be private methods.
                                In SketchUp v14+ using Ruby 2.0+, they were changed to be public methods.
                                I'm not here much anymore.
