    A gentle breeze & a relaxed flight - Sph WIP
    13 Posts 4 Posters 11.8k Views 4 Watching
    • F Offline
      faust07
      @ ntxdave: Thank You! The plane is completely modelled in SketchUp with SketchyPhysics (plugin).
      And here is a short solution for a path following plane. I think it is a bit complicated and that there are simplier solutions for a calculation of the direction vector. If anyone has ideas ... I'd like to replace the forward flying cube and the LookAt function by a Rubi-formula in the script of the plane.
      The model is a simple double-decker from the warehouse without Physics. I have it relatively heavily rebuilt and have added physical properties. The scripts are used from earlier SketchyPhysics posts about camera curves and path following object by Mr.K. and other authors and are also slightly modified.
      simple SketchUp
      my attempt
      how it works
      • F Offline
        faust07
        A short flight around Matilda's castle...
        the castle
        the short flight around
          Anton_S
          Very epic! 😎
            Very poetic fly! 😎
            • F Offline
              faust07
              In German I would say: "Ich trinke nie mehr Osterwasser!"
              And after the Google translation:
              I never drink more water Easter!...
              My text on the banner of the plane is nonsense and no one can understand it...
              Drinking "Osterwasser" means in Germany, to take in friendly company relaxed a little bit high-proof alcohol. But Easter's now long gone ...
              • F Offline
                faust07
                fly (fight) with the birds - not so relaxed...
                flight attendants
                air accident
                not so relaxed...
                • F Offline
                  faust07
                  "The visitor from China" - the lanterns of the 2400 years old tricycle (designed by BryanK) fit very well into the dark scenery. Relax and fly...
                  Enjoy the full video here: http://youtu.be/TDv1Xu1rr-I
                  • F Offline
                    faust07
                    I beg you Physics Master for a solution to the following problem to improve the driver's movements. I want to synchronize the movement of the upper body with the pedaling. However, this should not be solved by a "mechanical" connection, but via an evaluation of the pedal position in a script. Unfortunately, for that my mathematical, geometric and programming skills are not enough. ... Please help (model in the post).
                    SPh_WinderPendulTest_AT_01_SU8.skp
                    • F Offline
                      faust07
                      Have found the solution ...
                      • F Offline
                        faust07
                        Spring Awakening ... πŸ˜‰
                        I've tested a video overlay of a rendered animation (Twilight) with SketchUp colors and lines to soften the dark shadows of Twilights animation setting "Preview Object Animation" (others are to time consuming) and to get a little SketchUp-style feeling.
                        Animated with SketchyPhysics: clouds, birds, airplane, houses, smoke, trees, water, pedestrian and camera.
                        Twilight rendering took about 15 days, because the system has broken down every 30 to 60 frames from the first third of the entire animation. Fortunately a restart of Physics rendering from a selected time is possible.
                        Please watch the full one minute video on YouTube here: SpringAwakening
