    Scrambler issue
    31 Posts 3 Posters 4.5k Views 3 Watching
    • WhyDiW Offline
      WhyDi
      Hi all
      I also learnt here http://sketchucation.com/forums/viewtopic.php?t=39094 that FILE and LINE do not work with 2014 previous versions but none of these keywords in the script.
      Sketchup 8.0.16846 installed on another PC and test on both.
      Max line length is 1276 and reduced to 1000 gives BugSplat at start time. 750 then 500 the same and finally 250 with no change. BugSplat as ever. I give up decreasing! It doesn't make any sense.
      So I've reached the dead end!
      After hours and hours of labour to preserve backward compatibility down to SU8 and just before releasing our extension the baby blows out! we are now unable to reach our purpose. I will send the bug plast but the answer will come to late if any.
      From one hand the scrambler does not allow for 8 and 2013 version.
      On the other hand using C doesn't look enough secure. Although I need to know more on C extension I think it's very probably all about dlls which means call from the main script and some bad eval() has to appear at some point in the ruby script. This also means that anyone can 'puts' the return of the dll call into the sketchup console easily. No more sense than above!
      It's clear that without some ongoing miracle : Really the dead end.
      I almost forgot to thank you for your time
      Best Regards
      the devil is in the detail
        Have you identified the file that crashes?
        I would load them manually, or put a tracing puts statement in them. To find which one crashes. Then strip away half the file until you find the section that crashes.
        Just to be sure that this is a long-line crash - have you tried removing lines that are longer than a couple of hounded characters?
        I'm still puzzled by your line length - what isn't that cannot be broken down? I don't think I ever have seen a line of code that had to be 1000+ chars long.
        Can you post one of these lines - just as an example so we can fully understand what is going on?
        But the key point here is the need to identify what file/line crashes.
        • WhyDiW Offline
          WhyDi
          Unfortunately they all and each crash.
          under development we use 8 files encompassing roughly 50 classes, 500 functions, 7500 lines and 300k ruby only code out of of comment.
          Each of these scrambled file loaded separately - meaning the others loaded as .rb - ends up with the BugSplat
          After gathering them I got the same outcome
          No doubt there is something wrong somewhere but what and where ?
          I don't have time to read what a 'puts' can yield! running the scrambled script pauses about one second then close SU8 and finally shows the bug splat window. Nothing else than that. I'm never at hand to do anything!
          What may I do? nothing!
          the file with shortest (longest)line is 120. no html string into .rbs they are in the main module.rb
          here is one of these numerous lines we have. delivered as is!
          if (@keep_prj_skp_file_last != Mdl;;prj_skp_file_last) or
            (@keep_olt_user_filter != str_flt_cmp) or
            (@keep_olt_user_filter_layer != Mdl;;olt_user_filter_layer) or
            (@keep_fps_make != Mdl;;fps_make) or
            (@keep_anim_wait != Mdl;;anim_wait) or
            (@keep_dialog_collapse_at_runtime != @dialog_collapse_at_runtime) or
            (@keep_do_mode != Mdl;;do_mode) or
            (@keep_anim_restore_shot != Mdl;;anim_restore_shot) or
            (@keep_anim_save_shot != Mdl;;anim_save_shot) or
            (@keep_anim_save_model != Mdl;;anim_save_model) or
            (@keep_anim_restore_cam != Mdl;;anim_restore_cam) or
            (@keep_anim_save_cam != Mdl;;anim_save_cam) or
            (@keep_anim_restore_lay != Mdl;;anim_restore_lay)
              return true
          What's wrong in such code?
          Remember that all works perfectly without scrambling, even the gathered file with LineFeed or Semicolon at each end of line. All that works.
          Is it worth to decrease line length under 256 chars? I have my doubts in such context
          • WhyDiW Offline
            WhyDi
            You know what? today we have made a decision founded on
            • Either our way of writing ruby script doesn't please SketchUp Scrambler
            • Or the scrambler is not suitable for us.
            Binary choice as any developer knows in its life and I'm inclined to think that the first one is likely to prove. My team doesn't like that but it's now the only way to go out this dead end. This may turn out as most of us have a strong MS background with c# or VB.net as I do. For who knows a bit about VB I like that 'redim preserve' and always works with OptionExplict and OptionStrict and OptionInfer. The compiler doesn't tolerate anything but nearly no error at runtime and intelliSense makes the remaining. This could lead to bad habits with ruby script - I never feel easy with its syntax and its way to auto-type variables as instance.
            But let's get back to the point. So some times ago a script developer asked us to integrate our group. I've just called him. He comes tomorrow with a clear purpose. His mission is to rewrite one of our file its own way. If his way succeeds - meaning the file can go through the scrambler and works - he integrates.
            Outcomes tomorrow
              Is the crash also happening on SU2013 as well?
              Is your extension already available in some form? (I was wondering if I could run it on my SU8 version which is the latest. You mentioned you where using an older version - maybe that has a particular bug in it...)
              (Or if you could provide even just one of these RBS files for testing - you can PM it to me if you want.)
              The way the Ruby is written shouldn't really matter - it's only that old bug with long lines that I know of. (Though we're talking about SU8 here - might be some old bug that I never ran into. I no longer write for these old versions.)
              Oh, and just to be sure it's not an issue with an old version of the scrambler - have you tried using this page to scramble? https://extensions.sketchup.com/en/developer_center/extension_signature
              • WhyDiW Offline
                WhyDi
                Hi all
                You're right one more time thomthom writing style doesn't matter. Only my mistake!
                Right now I've only focused SU8 both version and SU16. You anticipate my post as regard tests!
                Please tell me what means 'PM' in ...you can PM it...?
                So following my previous post. He integrates!
                not because of his way of coding but he instantly pointed out my mistake. He doesn't start to write the first word of code. Indeed there was three lines of code I missed to check in our files. attr_reader and attr_writer and attr_accessor. In each file one of these lines is too long leading to crash.
                Aiming to please you I spent some time to determinate the exact number of characters sketchUp.Scrambler can deal with.
                the following assumes the start line right against the left edge and the cursor at the end of the line.
                1016 characters are ok
                1017 characters runs the bug splat window
                once more thanks you very much. You are very nice guys.
                I really hope to meet you soon once more. In fact I'm wondering about three beta versions some smart guys like you might run on their computer. but I'm afraid to ask for too much!
                I guess thomthom is Windows user but as far as I remember driven likes OSX.
                Am I right?
                have a good week end
                  PM = Private Message (in case you wanted to share files you didn't want to run publicly.)
                  So your extension runs under SU8 now?
                    driven
                    you can PM like this...
                    and yes I use mac's, but I don't work for Trimble like Thomas does...
                    are you registered as a developer?
                    • WhyDiW Offline
                      WhyDi
                      Hi all,
                      Thanks both for the meaning of PM.
                      Hopefully each and the gathered scripts work correctly under SU8 and SU16. I feel relieved after that previous week of stress. I can tell you now that despite the scrambler limits I'm fully aware of we had made the decision to publish nothing if we were not able to overcome that first issue. There is another one making me ill at ease which is all about license key but I won't talk about on public thread. If any of you have experience to share with me I will appreciate. PM contact please.
                      So it's very likely we release the free version after going through beta tests of course. At the time there is still more work.
                      As for the two others and as ever said the release is related to acceptable license key making.
                      But it may be time you to know a bit more about the (futur) extension itself. You may find the whole thing here www.SUalive.com
                      Please let me know. What do you think about the concept and our way to look at animation in sketchUp? Feel free to ask any question.
                      I've just filled the register form about developer. The way you ask me let me think that's an essential thing.
                      I suspected you thomthom to work for Trimble as along my searches I noticed your 'sketchup team' status right underneath your login in some posts. I have no problem with that and think that Trimble made a great SketchUp version 2016 with its LayOut-style tray. There is a very annoying bug but I hope it to quickly disappear. So I'm a SU2016 pro user.
                      ...I no longer write for these old versions...
                      If you want to know why we develop for this old version I can explain and your team might take benefit from. Don't worry. As you may have understood I like Trimble work and the story can be public. It's all about 'the devil is in the detail'. This only explains my current signature. As you wish...
                      Have a good week
                      WhyDi
                        driven
                        that's looking promising...
                        have you got mac version working yet?
                        there may be less mac SU users, but most will pay for a useful plugin...
                        • WhyDiW Offline
                          WhyDi
                          Hi Driven
                          Mac version has always been in the tube but at the very bottom of the stack. Each time we talk about we decrease its rank. what a shame!
                          As you said the user number led us at first but you've just added an argument that might change our mind. On the other hand I would have liked to make you pleased. My thought also goes to slbaumgartner who helped me in the past (I think he also is Mac user). Mac users are so kind to help us and we haven't done much four you. So I'm ready to get even more involved although I know hardly anything about OSX.
                          We meet next Friday evening and If you wish I may fight a bit so that Mac version raises at the top of the pile.
                          Would you?
                          I think I could achieve to persuade from these two arguments.
                          • 2 / 2
