    Need New Computer Advice Please
    23 Posts 5 Posters 6.1k Views 5 Watching
    • Joe WoodJ
      Joe Wood
      Yeah Baz, that's a good start! I'll start looking around!
      where would you go to look for a stock computer with these specs, online, or at a local electronics computer place?
      Joe Wood
      woodsshop.com/
      • bazB
        baz
        You might find a stock computer with the right setup, I would be looking at 'Business' style puters.
        But I have found the small techies or retail shops provide good value and support.
        Personally not keen on getting a whole puter online, cos I get nervous about warranties and support. Others here would probly disagree, but I like to see the whites of their eyes before I part with the cash ๐Ÿ˜„
        Suggest you take my list in, (but pretend its yours) and get a couple of written quotes.
        Watch out for up selling tho. F'instance its easy to spend 500 on a graphics card but you really dont need it, likewise the CPU. You dont need an i7, i5 will be fine.
        And make sure its Nvidea for the card as per SU support recommendation.
        Let us know how you go, esp interested in how prices compare to us in OZ.
        Baz
        • Joe WoodJ
          Joe Wood
          OK folks just starting to look around. I've been getting conflicting advice about which OS to get. I have win 8.something on my laptop and don't like it at all, probably because I haven't spent that much time on it.
          so going from XP, which OS would you recommend? I've heard win 10 has the Start menu back and that's what I'm familiar with having.
          Joe Wood
          woodsshop.com/
          • bazB
            baz
            I have no experience with Win 10, hopefully someone will chime in. As said before, I'm on win 7 and will stick with it as long as I can.
            • jujuJ
              juju
              I always delay upgrading to a new OS (especially if it is the latest) as long as possible and only after making sure my mission critical software and drivers are supported and working well.
              • G
                Glenn at home
                I have Win10 on all of my personal PCs and it has been great. I use Win7 on my work PC and Win8.1 on my work laptop so I get a look at all of them. I did a clean install of 10 on my home SketchUp PC and so far no issues what so ever. I use SU15 Make and Maxwell for personal stuff and again no issues at all. It is an older Dell with an AMD Athlon II X4, 8 gb of ram, 256 gb ssd and a GTX650 graphics card. I added the SSD drive and the used GTX when I did the 10 upgrade and these changes have made my older PC seem brand new in terms of speed/performance. It runs my AutoCAD '15/'16 copies from work as well. I think MS did a great job with 10 imho.
                • Joe WoodJ
                  Joe Wood
                  OK, I've found two that fit the specs Baz gave me, I think,
                  here's one for $799
                  http://www.frys.com/search?search_type=regular%26amp;sqxts=1%26amp;cat=%26amp;query_string=8356627
                  and another at $849
                  http://www.frys.com/search?search_type=regular%26amp;sqxts=1%26amp;cat=%26amp;query_string=8656990
                  then, I have a local computer guy who can build this one for scratch for $704. Here's what would be included-
                  OK here are the parts I have for sale
                  1.:ASUS Intel socket 1150 (core i5 & i7 compatible) Motherboard. It has 2 pcie video card slots for running 2 video cards which means you can use at least 4 monitors at the same time. 4 memory slots that are dual channel compatible. You can use up to 16Gb of DDR-3 SDRAM at BUS speeds of up to 3200mhz.
                  It has SATA3 and SATA6 with up to 6 devices that can be install like 4 hard drives and 2 DVDRW drives.
                  It has both USB 2.0 and USB 3.0 with 8 USB ports on the back. It has Surround Sound 7.1 with Subwoofer out Front, Rear, and Center channel outputs. Digital sound out.
                  This is a high end Motherboard I paid $149
                  2. Western Digital 2 terabyte Black Series 7200 rpm Server grade Hard Drive.
                  This is WD's top of the line Hard Drive with 6mb cache buffer these drives have 5 year warranty's where the rest of the WD Models have 2 and 3 year warranty's This Hard Drive Drive . This drive cost $269 new and even though the price of hard drives has come down a lot in the last year , this drive still sells for $169 new today.
                  1. Nvidia Geforce GTX 260 video card what makes this one of the best video cards is it's bit rate . everything under $150 has no more than 128 bit look a the bit rate in the specs below. This is what gives you a fast sharp picture. This one has 448 bit processing! This card will do everything you need it to do and more! I paid about $275 for it
                  2. DVDRW drive LG SATA drive fast burn speed and can do bother DVD-R and DVD+R format. I paid $29
                  3. Thermal take Desktop case
                    This case has easy drive install and removal and lots of fans plus the power supply mounts at the bottom of the case . I paid $65
                    7.Windows 7 Ultimate 64 bit Operating system fresh install will be done. That $49.99 with an image copy placed on a separate partition on the hard drive
                  GPU Engine Specs
                  CUDA Cores1
                  192
                  Graphics Clock (MHz)
                  576MHz
                  Processor Clock (MHz)
                  1242MHz
                  Texture Fill Rate (billion/sec)
                  36.9
                  Memory Specs
                  Memory Clock
                  999MHz
                  Standard Memory Config
                  896MB
                  Memory Interface Width
                  448-bit
                  Memory Bandwidth (GB/sec)
                  111.9
                  Feature Support
                  OpenGL
                  2.1
                  Supported Technologies2
                  SLI, CUDA, 3D Vision, PhysX
                  SLI Options3
                  2-way
                  3-way
                  Display Support
                  Multi Monitor
                  Yes
                  Maximum Digital Resolution
                  2560x1600
                  Maximum VGA Resolution
                  2048x1536
                  Standard Display Connectors
                  Dual Link DVI
                  HDTV
                  HDMI
                  Yes
                  Standard Graphics Card Dimensions
                  Length
                  10.5 inches (267 mm)
                  Height
                  4.376 inches (111 mm)
                  Width
                  Dual-slot
                  Thermal and Power Specs
                  Maximum GPU Temperature (in C)
                  105 C
                  Maximum Graphics Card Power (W)
                  182 W
                  Minimum System Power Requirement (W)
                  500 W
                  Supplementary Power Connectors
                  6-pin x2
                  Audio Input for HDMI
                  SPDIF
                  1 - The number of processor cores may vary by model.
                  2 - Certain GeForce GPUs ship with hardware support for NVIDIA PhysX technology. NVIDIA PhysX drivers are required to experience in-game GPU PhysX acceleration. Refer towww.nvidia.com/PhysX for more information.
                  3 - NVIDIA SLI certified versions of GeForce PCI Express GPUs only. A GeForce GPU must be paired with an identical GPU, regardless of graphics card manufacturer. SLI requires sufficient system cooling and a compatible power supply. Visit the SLI Zone for more information and a listing of SLI-Certified components.
                  4. Intel Core i5 2500k Processor this is the second fastest i5 processor you can buy and faster than some i7 CPU's I paid $249 and they still sell for $199
                  You will need a power supply $45
                  My price without these two items is $550 and that includes building the system and installing Windows 7 Ultimate 64 bit
                  And a 250gb SSD for $109 you can buy along with a 700 watt power supply for $45
                  Darn that's a long list!
                  So which one should I get?? Also from what I'm hearing Win 7 is the OS I should get?
                  Joe Wood
                  woodsshop.com/
                  • bazB
                    baz
                    Joe, bit hard to work out exactly what the local guy is offering, but it sounds pretty good.
                    I can't see what Ram he is offering, should be 12GB at least.
                    I would ask him to redo his list with just the parts he proposes using with prices and any other costs, assembly etc.
                    Also what sort of warranty and whether he offers on-site repairs.
                    The others look ok, but not as much bang for your buck.
                    Cheers
                    Baz
                    • Joe WoodJ
                      Joe Wood
                      Baz, thanks mate really appreciate the help with this,
                      here's what he said-
                      I just did this pricing with just the parts I have for sale $550 including installation of all the parts, and windows 7 ultimate 64 bit all for $550.
                      As far as the amount of memory the cost to ad 4 GB more RAM to make a total of 12 GB is $23 just priced it at Fry's
                      As far as the parts are concerned I will give you 30 days on the parts. They are used parts after all.
                      I can assure you that they haven't been used that much and all parts worked perfect last time they were used. They only have about 6 months of use on them if that. But if one or all fail due to defect and not misuse or accident I will either fix replace or refund a prorated amount for what the part is worth used
                      I will also give you a 90 day warranty on my labor. If something is not put together right or comes lose due to my labor I will fix it at no cost to you.
                      So to add it all up
                      I am charging $550 for these items
                      ASUS ,1150 core i5 Motherboard.
                      Nvidia Geforce GTX ,260 Video Card.
                      8 GB of DDR-3 memory running at 1600mhz high performance clock rates.
                      Western Digital Black series 2 TB 7200 rpm SATA 6mb cache Hard Drive The Best they make!
                      Intelยฎ Coreโ„ข i5-2500K Processor
                      (6M Cache, up to 3.70 GHz)
                      (Quad-Core processing)
                      Normal running speed 3.3 GHz
                      Thermaltake computer case V3 Black nice case good air flow see attached pictured.
                      DVDRW SATA Optical drive name brand but don't remember what brand.
                      Windows 7 ultimate 64 bit
                      All this including the installation of all the parts and Windows 7 Ultimate 64 bit
                      Price $550
                      So if you want to buy it do it in the next few days cause I have 3 big security camera jobs a coming up starting next week and could take as long as a month before I could build your computer.
                      Joe Wood
                      woodsshop.com/
                      • bazB
                        baz
                        Look good, sounds like he will take care of you well and a very good price.
                        I would still want a backup drive tho, either internal or better, external. Better cos its independent of the main computer and God forbid you have to run from the house, you can take it with you easily! Might be good to get the techie to set up windows backup for you. Mine is set for daily at dinner time.
                        30 days on parts and 90 days labour seems about right. I would spring for the extra ram, but see how you go, easy to add it later.
                        I reckon go for it.
                        • Joe WoodJ
                          Joe Wood
                          Man! I feel like a teenager who just got his first hot rod ๐Ÿ™‚ Just got it all up and Running two days ago.
                          I click on a .skp file and it's open before I finish the click!
                          I can orbit with shadows on ๐Ÿ™‚ I'm going to like this.
                          thanks baz, I got a great setup for a real good price, thanks for the hand holding!
                          Joe Wood
                          woodsshop.com/
                          • bazB
                            baz
                            Glad I could help Joe.
                            • Joe WoodJ
                              Joe Wood
                              I haven't had to tweak SUps settings for so long I forget how to!
                              when I use the tape tool and double click, it doesn't set a guideline, and when I click and drag it doesn't show a guide,
                              same with protractor tool, it doesn't leave a guideline when I click and set.
                              I've been playing with my open gl and it hasn't helped. Then in my NVidia setting it says "Let the 3d decide".
                              Joe Wood
                              woodsshop.com/
                              • bazB
                                baz
                                Do you have 'Guides' ticked in 'View' menu?
                                • Joe WoodJ
                                  Joe Wood
                                  Hhmmm, I don't have Guides in the View menu Baz, nor anywhere else ..
                                  I'm using SUp 5 if that matters?
                                  Joe Wood
                                  woodsshop.com/
                                  • bazB
                                    baz
                                    SU5 is going back a bit ๐Ÿ˜„
                                    But there must have been an option to show/hide guides somewhere.
                                    You might have to consult the documentation.
                                    • Joe WoodJ
                                      Joe Wood
                                      Yeah it was @Last software, I recently downloaded Ver 5 for this new computer and now it's called google SUp :-),
                                      Joe Wood
                                      woodsshop.com/
                                      • Joe WoodJ
                                        Joe Wood
                                        So where can I find the documentation? In SUp 5 when I go to Help, all those links point to dead pages.
                                        I need to get this tape measure tool issue resolved, I can do workarounds but what a hassle.
                                        Joe Wood
                                        woodsshop.com/
                                        • bazB
                                          baz
                                          Joe, suggest you start a new thread, one of the veterans will surely be able to help.
