    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 536.2k Views 71 Watching
      Garry K
      I've got the plugin working in metric and in imperial units.
      Question - those of you who work in fractional inches - do you want to see the csv reports displaying fractions or decimals?
        Garry K
        I am ready to start testing. Anyone interested? I'd like a Mac user as I do develop in Windows.
        If anyone is interested then please contact me.
        I still have to:
        1. Integrate Doors - for cabinet testing there is only 1 style of door
        2. Create a help file
        3. Complete the language translations
          jtri
          Great work! Our cabinets are assembled with confirmat screws and dowels. Finished ends are a loose panel. The base cabinets are on leg levelers. Are you considering these options for the program?
            Garry K
            I will consider all options.
            Right now you can add finished panels if you wish - that is how I used to build cabinets. A lot of advantages doing it this way.
            I have built cabinets with dowels using 8mm construction holes. Mostly 8 X 30 fluted beech dowels.
            I have also used 50 mm confirmats for 7mm head and 5 mm end boring.
            I don't see a big need to show these holes in the model - but when it comes to dxf output doweling is certainly 1 of the options.
            Here is a dxf file for nested cnc. CutMasterPro reads in the parts list, optimizes it for cnc routing and creates dxf files.
              Garry K
              I should ask you. Were you wanting to see leg levelers in the hardware report? Also dowel amounts and confirmat amounts?
              Currently the model does not show drilling for adjustable shelves or drilling for handles, hinges or drawer slides.
              What are your thoughts on all of this?
                jtri
                For our use I was thinking that your program would be a great way for us to quickly produce better presentation models. We currently do all our shop drawings in Auto Cad 2d, then our CNC engineer programs all the parts with all the function and assembly holes. While it would be great to by pass the 2d drawings I do not see that happening in our shop as we do mostly commercial work with an enormous range of very odd cabinets. It seems lately that every designer is reinventing the wheel every day!
                  Garry K
                  Then you would be looking at the designer version and wouldn't really need parts lists etc. I'd be interested in seeing what your 2D drawings look like. There may be a way of generating DXF files that you could import into Auto Cad 2d
                  You will be able to store any number of rule files, material files and cabinet library files. I've been thinking that it will be useful in allowing multiple folders for library files. You would then just set the configuration library to a folder before running the plugin. This would effectively filter reducing clutter in the library drop down.
                    Garry K
                    CabMaker is very close.
                    Still Todo:
                    1. Finish adding all the door styles
                    2. Complete the library feature. This is where you ask cabmaker to create a folder and use it for saving or retrieving your own library cabinets.
                    3. Documentation
                      db11
                      Garry — nice job on this plugin. Looks very comprehensive, flexible and well thought-out, and makes me wish that it was available back when I was still working as a cabinetmaker. Congrats.
                        Garry K
                        Thanks for the kind words !!
                        Any suggestions or requests would be most welcomed !!
                          Garry K
                          I've added a bunch of door styles into cab maker plugin.
                          Plain Panel
                          Shaker - flat panel
                          Square - flat or raised panel
                          Arch - flat or raised panel
                          Double Arch - flat or raised panel
                          Cathedral - flat or raised panel
                          Double Cathedral - flat or raised panel
                          Mitered - flat or raised panel
                          Half Round - flat or raised panel
                          All of these door styles also come with glass or mirror
                          Here is a picture showing 3 door styles
                          1. Double Cathedral - raised panel
                          2. Half Round - raised panel
                          3. Double Arch - raised panel
                          I'm now working on a new embossed door style
                          • Phillip HP Offline
                            Phillip H
                            Garry, this is amazing work. Your attention to detail is impressive.
                            My father was a builder/developer, mainly in residential construction. As a kid I was allowed to sit quietly as he met with architects, designers, vendors etc. I remember vividly him sharing his drawings and notes with me long before the advent of personal computers. He would have been delighted with this.
                            HP EliteBook 8440p IntelĀ® Dual Coreā„¢ i7 M620@ 2.67 4GB RAM
                            NVIDIA NVS 3100, 512 MB
                            WindowsĀ® 8.1 64 bit
                            SketchUp Pro 2015 version 15.3.331 64-bit
                              Garry K
                              Version 1.0.6 Beta is now available for download from my web site.
                              I suggest you run this with the ruby console open. This way when you can copy and paste errors.
                              Thanks for your help.
                              My web site is at www://cabmaker32.com
                              • FrederikF Offline
                                Frederik
                                Thanks for the option to beta-test your plugin... šŸ‘
                                Please note that you seem to have an issue with the login page...
                                It's impossible to see the name and pw you enter...
                                I succeeded at last, but it wasn't easy...
                                Cheers
                                Kim Frederik
                                  Garry K
                                  I will dig into that.
                                  For now anyone having trouble can use this - but only if they have a userid and password already.
                                  http://cabmaker32.com/wp-login.php
                                  Alternatively - send me a private message with the userID you would like and I can set you up with an account and a temporary password which you can change by loggin in and change it yourself.
                                  Hope this helps.
                                    Phillip H
                                    Ditto on the thanks, Garry. I consider it a privilege. Registered and downloaded the beta last night. No issues with either.
                                    Have a long day ahead but will try and put it through its paces starting this evening. I'll be working in feet, inches and fractions thereof, so it should be interesting. Anything pops it the Ruby console and I'll forward it along.
                                    Phillip
                                      Garry K
                                      I have tested it with feet and inches. The translation is only approximate so I suggest that you edit various sizes.
                                      Here is what I see when I set the units to Fractional inches with a precision of 1/64"
                                      For instance 768 mm converts to ~ 31 1/2"
                                      For easy math you might want a drawer bank with 4 - 8" drawers. So set your cabinet height to 32"
                                      Sketchup converts the mm to fractional inches and you get the following
                                      Edit and remove the tilde '~' and it will work better for you.
                                        Phillip H
                                        Thanks for the heads up. I certainly don't mind making the change, but in the US market, I can see how that might be a problem. Since you are already aware, I presume you already have something in mind.
                                          Garry K
                                          If you stay in fractional inches then you only have to edit and save these forms once!
                                          I'm pretty sure that if you use decimal inches then there is only a problem if your precision isn't set fine enough.
                                          A precision of 0.0001 is sufficient.
                                          In the future I can provide a set of templates that are set up in fractional inches. But why go to all that trouble when users are going to edit material thickness, rules etc.. anyway!!
                                          So - is it really an issue?
                                          Up here in Canada our building trades have always worked in feet and inches. When I built stairs and cabinets I measured up the building using feet and inches. I also quoted jobs using feet and inches. It was when I got to shop drawings that everything goes to metric.
                                          Say I have a 14 riser stair and the total rise is 9' 1 5/8". Say you want 1/32" precision each rise would be 7 27/32". This gives you a total error of 3/16". This might not seem like much but it does throw off a circular stair.
                                          This is equal to 2784.475 mm which works out to 198.9 mm rise per step. This gives me a total error of .125 mm which is negligable.
                                          With cabinets my work flow would include the use of a micrometer to check the thickness of the panels. I would then make an adjustment to the material form and perform a batch edit. The entire material list would then adjust automatically.
                                          Each to there own. Just showing you the flexibility of this plugin design.
                                          One thought I have is to include an automatic parser like I do with my C / C++ programming.
                                          So you could enter formulas like (95 5/8") / 5
                                          and let the software do the calculation for you. Over the years I certainly found this approach very useful.
                                            Phillip H
                                            When I said, "I presume you already have something in mind.", I was sure you had already thought it through. You don't disappoint. I all sounds good. šŸ‘
                                            With your input, this post could be even better šŸ’—
                                            • 31
                                            • 32
                                            • 2 / 32
