    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 89.6k Views 41 Watching
    • eneroth3E Offline
      eneroth3
      Dean is right! 0.1.19 has been mixed up with an older version 😲 😲 😲 😲 but it's now corrected and the current version in the pluginstore should be the correct one.
      My website: http://julia-christina-eneroth.se/
        driven
        hi,
        track.rb is saved with Central European (Windows Latin 2) encoding and causes invalid byte sequence in UTF-8 error [at least on a mac]
        I haven't checked any others yet...
        • deaneauD Offline
          deaneau
          oh ok..
          • eneroth3E Offline
            eneroth3
            @driven said:
            hi,
            Ooops, I had written an ä in a Swedish word in a comment since I didn't know the English term at the time. Now it's fixed and version 0.1.20 published.
              Ralle
              Hallo there...
              It´s a great plugin at all. Big thanks vor this. It saves a lot of work.
              But i have a question. I can not get the additional Streets working. I put them
              into the Tracksfolder. The only things i got are the leadinglines and SU2015 starts crashing. All the othes stuff works fine.
              Greetings
              Ralph
              • eneroth3E Offline
                eneroth3
                @ralle said:
                Hallo there...
                Greetings
                Ralph
                Hi Ralph
                Those tracks are for an older version of the plugin but if you place their folders in "tracks/" directly in the template's folder (NOT "templates/tracks/"), open the ruby console and run "EneRailroad::Templates.convert_old" (without quotes) they should be converted to the new format.
                On what page did you find them? I could update them in case anyone else wants to download them.
                  Ralle
                  Hallo Eneroth.
                  Now that I'm back from a bad cold the last weeks, i'm follow your instructions.
                  But without a good result, with exeption, SU doesn't crash anymore after useing
                  the streets. How ever, i don't have any primitves of the streets, only the leadinglines.
                  Greetings ..
                  Ralph
                  • eneroth3E Offline
                    eneroth3
                    Finally there's a new version published. Version 0.1.21 adds back the translation support. It also has a completely new feature for listing certain parts of structure (for now the pillars of the JPods structures) and lets users reposition them accurately. This feature is found under Extensions > Eneroth Plugin System > Structure Part Info. There's also a security notification added when models load if they contain potentially harmful executable code used by the balise feature. Finally there are some bugfixes regarding how missing templates are handled.
                    Download
                    • eneroth3E Offline
                      eneroth3
                      @ralle said:
                      Hallo Eneroth.
                      Greetings ..
                      Ralph
                      That's odd. Can you send me a zipped copy of the streets' track folders?
                        Anton_S
                        Thank you for an update, eneroth3 😄
                        • deaneauD Offline
                          deaneau
                          0.1.21 crash some times if i layout tracks.
                          steam locos jumps when i try to drive.
                          Page Not Found
                          Web word processing, presentations and spreadsheets
                          (drive.google.com)
                          sketchup make 2015
                          • deaneauD Offline
                            deaneau
                            Is ths project dead?
                            or is revit and rhino now your favorite? 😉
                            dean aka yellowdoor/deaneau
                            • Lemoyne ArchitectL Offline
                              Lemoyne Architect
                              Simply incredible! Now I have to resist the urge to play with this instead of working on my clients’ projects today. 😄
                                Like_Quo20
                                Hi all!
                                Can someone please explain to me where I can find and add roads to the plugin?
                                I like it a lot, very useful!
                                Best regards,
                                Koen Schreurs
                                  Like_Quo20
                                  Can someone please explain me how to add trains or where to get them from?
                                  I have been trying to add a train with the option in the plugin but that doesn't work proparly.
                                  I hope someone can help 😄
                                  Best regards,
                                  Koen Schreurs
                                  • OxerO Offline
                                    Oxer
                                    The plugin includes the Documentation, go to Plugins>Eneroth Railroad System>Documentation
                                      Like_Quo20
                                      Hi, thanks for replying! I really don't know anything about programming or stuff like that.
                                      You mean all those roads are already somewhere on my laptop? Or do I need to download them somewhere. I mean the tracks which has the figure of the roads for cars and stuffs.
                                      • OxerO Offline
                                        Oxer
                                        Please, read the first entries of this post, you can see two videos about how to use the plugin or search in youtube about Eneroth Railroad System.
                                        • deaneauD Offline
                                          deaneau
                                          When I´m right Eneroth develope actually in the rare free time the Eneroth Townhouse System (ETS)
                                            martinovic
                                            Hi!
                                            I am building an railroad with town, but is there any possibility to export it to Lumion?
                                            Thank You all!
                                            • 11
                                            • 18
                                            • 19
                                            • 9 / 19
