    Component search, select and zoom. Howto?
    6 Posts 3 Posters 351 Views 3 Watching
      philbx1
      Hi all,
      I started looking for Ruby examples on menu driven searching for components (with filters),
      then zooming to the selected component - pretty much like a scene selection.
      Failed big time...
      I don't expect any replies to this message, but thought I'd throw it out there as an idea.
      Any thoughts fine SK people?
      • sdmitchS Offline
        sdmitch
        @philbx1 said:
        Hi all,
        Failed big time...
        Here's a start
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        vue = mod.active_view
        cmp_names = mod.definitions.map{|cd|cd.name}
        ctf = UI.inputbox(["Find;"],[cmp_names[0]],[cmp_names.join("|")],"Find Component Instances")
        if ctf
         mod.definitions[ctf[0]].instances.each{|ci|
          vue.zoom ci;
          break if UI.messagebox("Keep Searching?",MB_YESNO) == 7
        http://sdmitch.blogspot.com/
          pcmoor
          @sdmitch said:
          Here's a start
          Hi Sam (sdmitch)
          I notice you use some sort of dialog or tool bar to execute the selected code from a dropdown. May I know its name and availability?
          Philip (pcmoor)
            philbx1
            Hey sdmitch,
            Thanks much for the reply. much appreciated.
            This will give me a good start as after looking at the SU Ruby API
            docs left me fairly confused.
            Similar to what pcmoor has stated, I now also need to find examples of menus etc.
            Hey, very nice web page BTW 😄
            Cheers,
            Phil.
            @sdmitch said:
            Here's a start
            > sel = mod.selection
            > if ctf
            >   vue.zoom ci;
            > end
              philbx1
              Hey Sam,
              Just looking through your nice plugins and thought I'd get the main SDM Tools required dependancy plugin to check them out.
              Well, I failed again as I can't seem to locate the 'main' plugin as yet.
              Maybe I'm not looking hard enough...
              Thanks again,
              Phil B.
              • sdmitchS Offline
                sdmitch
                @pcmoor said:
                @sdmitch said:
                Here's a start
                Hi Sam (sdmitch)
                Philip (pcmoor)
                The tool bar is Ruby Web Console, the original of several currently available, by Jim Foltz. It allows you to type in code snippets and execute them in the model. The code I posted was created and tested in this manner.
