    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 424.6k Views 109 Watching
    • JQLJ Offline
      JQL
      Hi Sam,
      I changed it but it only worked if I multiplied it with "0". Does this make sense to you?
      if (face.bounds.diagonal >= dmax*0); # make sure the rectangle is big enough to sub-divide
      Anyway thanks again... it's working perfectly now!
      www.casca.pt
      Visit us on facebook!
      • sdmitchS Offline
        sdmitch
        @jql said:
        Hi Sam,
        By multiplying by 0 you have eliminated the test totally as the face diagonal will always be greater than 0. It should have worked as it was as long as you didn't enter a length that was longer than the face diagonal. Maybe that wasn't efficient because the size of the faces picked was constantly changing.
        http://sdmitch.blogspot.com/
        • JQLJ Offline
          JQL
          Do you think I'm runining something in the long run if I keep it like this?
          www.casca.pt
          • sdmitchS Offline
            sdmitch
            No, I don't thing it should hurt anything but, if the pattern is bigger than the face, nothing is going to happen.
            • JQLJ Offline
              JQL
              I just tested it. If it's bigger than the face it just bevels the face and creates the set gaps to the border edges... Pretty cool if you ask me...
              All these tests made me want a new request but maybe I'm pushing my luck too far! πŸ˜•
              Here goes nothing:
              When we set a gap depth floor generator creates all it's coolness but it raises the floor area as much as the gap depth. It also removes the material from the original face and renders it with default material.
              1 - Would I be completely annoying if I'd request the floor top to match the level of the chosen face?
              2 - And what if the new face would receive the same material it had before Floor generation, or one of the materials currently being applied (random from folder or current).
              3 - Could it also be possible if the face material would be selecteable as the texture being applied? It could work as "current material" does right now...
              Now I'm going back to my hole...
              www.casca.pt
              • sdmitchS Offline
                sdmitch
                Here goes nothing:
                Yes but easily doable
                Also easily doable. Since all faces on the XY plane are created front down, I would assume the back_material is to be used.
                The soon to be released FINAL version, Random Texture source can be a folder or the model. You can choose one or several to be applied randomly.
                • JQLJ Offline
                  JQL
                  It's true sketchup does that (why it does it, it's another story) but most users reverse that face to be facing the side they need.
                  I believe that would be the case if you'd apply a floor on top of a slab. Probably the slab would be something that came out of a push pull if it would be like that, this "thick" slab would have the front face on top and the material would be applied on the front face.
                  I also believe most users using these detailed floors created by Floor generator, are already advanced users and most of us are using it for render purposes. Those kind of users usually don't apply materials to backfaces because of all the troubles that can lead to (rendering, SU solids, etc...)
                  www.casca.pt
                  • JQLJ Offline
                    JQL
                    @sdmitch said:
                    1. A new option, 'Create Below Face', moves the created pattern down so that the top of the pattern is at the level of the original face picked. If you are curious as to why ask JQL.
                    Well I use Floor generator at the end of my projects, until then the face where it's being applied to is the face that represents the floor level. This option allows for maintaining that level. I hope this makes sense... πŸ˜•
                    @sdmitch said:
                    I have posted the FINAL version of FloorGenerator. Sorry but no more changes and/or additions.
                    One more word just to thank you for this wonderful plugin... I understand it's popularity can cause you headaches, but it just seems FINAL is so definitive and it makes me feel a bit sad!
                    www.casca.pt
                    • deaneauD Offline
                      deaneau
                      from me too
                      however i have seen that you have remove the feature, that all Bricks etc in own groups.
                      i would wish me you could insert an option to choose the feature on or off. i mean bricks in own group or not. this would be wonderful.
                      bricks (etc) in own groups is good for animation or sketchup physics.
                        TaylorConway
                        ❓ Everyone can heip me undertant about them.
                          πŸ˜„
                          • sdmitchS Offline
                            sdmitch
                            @deaneau said:
                            from me too
                            That was a special version that I created just for you. It was never posted or given to anyone else. I will PM you a 'group' version when I have it.
                            Anyone else want individual groups?
                              Why not, after I will forget! πŸ˜„
                              Maybe that will funny with Explode view!
                              • deaneauD Offline
                                deaneau
                                @ sdmitch πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                @pilou you tell what i think
                                • JQLJ Offline
                                  JQL
                                  Let's blow up some SP bricks!
                                  www.casca.pt
                                    Ben Ritter
                                    sdmitch,
                                    Awesome and a big thank you for sharing.
                                    • PixeroP Offline
                                      Pixero
                                      It would be a great feature if one could chose to use components and it would create components from the different tile sizes and/or textures and use them to build the floor/wall.
                                      I still want to be able to do it the way it is now too.
                                        Use SDmitch FloorGenerator
                                        then FredoScale for have a lot of interesting perspective patches! 😎
                                        CloseUp!
                                        • sdmitchS Offline
                                          sdmitch
                                          I have posted the FINAL version of FloorGenerator. Sorry but no more changes and/or additions. Some of the major changes are
                                          1. The Current Material option now uses the Material on the front or back of the face picked. If the picked face doesn't have a material applied then the current material is used as before.
                                          2. The Rand_Tex Material option can specify a folder or the model as the source of the materials to be applied randomly. A Material Picker window will list the names of all the Materials available in the selected source. This a multiple selection window allowing you to 'Select' one, all or any combination using the Shift and Ctrl keys. A new 'Source' button, which appears when the Rand_Tex option is selected, allows you to change the source of the random materials at any time.
                                          3. The Irregular Polygon option now uses MattC's VoronoiXY and delauney3 plugins to create them. A density value ranging from 0.1 to 1.0 determines how many random points/sqft are generated and thus the relative size of the polygons created. Don't expect this to work on small or highly irregular shapes with holes.
                                          4. A new option, 'Create Behind Face', moves the created pattern so that the 'top' of the pattern is on the original face picked. Use this option if the picked face represents the finished floor or wall.
                                          5. A new option, 'Create Individual Groups' makes each Brick, Tile, etc. a group inside the Pattern group.
                                          • deaneauD Offline
                                            deaneau
                                            @ pilou you are a creative funny guy πŸ˜„
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
