    OFFICEBLOK - Prefab office pod
    30 Posts 13 Posters 6.0k Views 13 Watching
    • RichardR Offline
      Richard
      @mike amos said:
      Looking good. Have you thought of using a shower base type roof setup for collecting rainwater? It would of course depend on where the install was to be located of course.
      Thanks as always Mike! Mate the roof is to be done akin to a shower base, as a one piece vacuum molded insert, roof water collection though wont likely be installed as it's such a small volume of runoff that could be collected.
      Here is a shot of the proposed insert, the form was proposed as being able to rotate through 180deg to drain either to the front left or rear right so if install near the boundary, drainage isn't directed toward the neighbour. After install the tub / wall meeting at the top is capped with an aluminium channel.
      BUILTBRAND.COM.AU
      • RichardR Offline
        Richard
        @pbacot said:
        Your models and presentation are always top-notch! Good work. I hope this project suceeds for you. Can these typically be installed without permits or planning approval(or maybe an electrical permit)in Aus. cities?
        To you too mate again thanks as always!
        In some states here it may be installed without planning approval and in others with just the minimum as complying development. Part of the challenge is ensuring it is within a $20k budget so as to not require a building permit, warranty insurance, and that it can be installed by a tradesman without a builder's license. An electrical permit isn't required but MUST be connected by a licensed electrician.
        BUILTBRAND.COM.AU
        • RichardR Offline
          Richard
          @cotty said:
          I love the style of your models (and I don't need to see the text to recocnize them as your work πŸ˜‰
          Thanks mate!!! As always I reckon cleanliness in next to godliness!
          BUILTBRAND.COM.AU
          • GubermenschG Offline
            Gubermensch
            Cool project, great presentation! Prefabricated, modular homes have always fascinated me. I wonder why they're not more prevalent. You'd think people would prefer housing that didn't lead to significant indebtedness and without that burden, allowed them to build over time as their family or needs grow. Perhaps it's just inconvenient, or a red-tape-hindered kind of thing?
            http://www.jacobgubler.com/
              Sorry Richard I failed to get across the point as usual. The runoff would be logical and I did not mean to suggest you had not thought of it, as usual your projects are extremely well thought out. The point I failed to make was that if there was a method of having a small amount of residual water in that area, it could be useful to reduce the temperature inside the unit by cooling air at ceiling height. It would need to have some sort of lip on the drain side to keep a low level of water in place.
              • BoxB Offline
                Richard, I'm finally living back in Sydney, let me know if you need any local assistance.
                • bazB Offline
                  baz
                  Not a good idea Mike, perfect incubation for mosquito larvae. In any case one would assume high spec insulation everywhere.
                    It's a fair cop, I should have thought of that point at least.
                    • daleD Offline
                      dale
                      Wow Richard
                      Always in awe at how you manage to translate simple ideas into straightforward, clean, appealing concept while still being able to keep them ..... well so damned simple.
                      Cudo's
                      • jo-keJ Offline
                        jo-ke
                        You are really a master. I like your clean renderings.
                        http://www.zz7.de
                        • RichardR Offline
                          Richard
                          Got ya! Although I agree with Baz about the Mozzie issue, and my own concerns about getting water away quickly so as to reduce any longer term issues, there is something there to consider about natural cooling!!! Although the space is small, add a body and a few electrical devices and the space could heat up! Considering some passive way to cool through the use of collected water is worthy of some thought!
                          Thanks mate!
                          BUILTBRAND.COM.AU
                          • RichardR Offline
                            Richard
                            Very cool mate! At the least BEER sounds in order!
                            BUILTBRAND.COM.AU
                            • RichardR Offline
                              Richard
                              I'm not sure Mike's ideal is all that bad, certainly something to consider though mozzies are a huge issue.
                              Baz you're right, there is to be 100mm EPS insulation to the walls, 200mm to the floor and roof. Certainly the floor / roof insulation may seem massive overkill but more about achieving dimensions to simplify the build and create desired proportions. The roof thinkness is to reduce the draw depth of the plastic roof tub so the medium doesn't thin out too much on molding.
                              The overall structural build makes use of simple sandwich panel (cold store panel) as it's quick to assemble, just pop riveted together. The lining and cladding is then simply glued on for a fixing free finish.
                              The sliding door is proposed as double glazed with venetian blind in the cavity.
                              BUILTBRAND.COM.AU
                              • RichardR Offline
                                Richard
                                Mate we are on the same page there, I love prefab as a method. For the most though it seems the final build / delivery and install price (here at least) tends to be higher than site built projects. I may well be missing the obvious but I cant see why! Except for the delivery, install and maybe the overhead on the factory, EVERYTHING else seems to be in favor.
                                Mind you, HYBRID is where I think progress is to be made!
                                BUILTBRAND.COM.AU
                                • RichardR Offline
                                  Richard
                                  @dale said:
                                  Wow Richard
                                  Cudo's
                                  Thanks Dale! Mate the nice thing with this project, it itself is so simple it almost forces simplicity. Would be hard to make it anything else!
                                  BUILTBRAND.COM.AU
                                  • RichardR Offline
                                    Richard
                                    That makes two! πŸ˜„
                                    BUILTBRAND.COM.AU
                                    • Bryan KB Offline
                                      Very cool. Great idea!
                                      • BoxB Offline
                                        I know it's the other side but I'll be meeting with someone in Bondi in the early arvo wednesday and then testing the local amber nectar distributors before rolling back to balmain on the last possible ferry. Anything fit in there?
                                        • RichardR Offline
                                          Richard
                                          Darn, not gonna make it today mate. 😞 commitment made for this afternoon delivery of a revised home design for Perth.
                                          BUILTBRAND.COM.AU
                                          • BoxB Offline
                                            Not to worry Richard, ended up driving there and didn't finish until after nine so didn't get to sample the local wares.
                                            Is there a ferry wharf near you?
