    What would you charge for this?
    46 Posts 8 Posters 8.3k Views 8 Watching
    • JQLJ
      JQL
      @roland joseph said:
      I would have to ask you at this point to post an image that you feel is worth 600 Canadian.
      That way I know if we are in the ballpark.
      Roland I don't produce images for other architects. In fact I only did it once and I used those images to buy Thea. It was a job done in a very short time and I only knew Kerkythea at that time. This was made in a couple of days and it was the first time I rendered something with Thea. The price, was more or less the price we're talking about.
      (You made me loose some time unzipping/finding the archived image.)
      I wouldn't like to repeat something like this project as I didn't like the end result. But I learnt a zillion things and it was the first time I created my own HQ textures. (Stone on the floor). I wouldn't mind one of your storefronts though... maybe two if I wasn't happy with the first.
      Sometimes a quote gives away a persons ability...i.e. Solo might quote 50 bucks on a job because it is something he can do in seconds...the next guy quotes the same job at 200 dollars because it takes him 400% longer to complete the job so he feels he should get his rate.....to bad he will never see it.
      There's no job that I accept where I haven't got to learn a lot of stuff for it to be acomplished. Usually that is what keeps me interested in working on architecture.
      What I charge always takes that into consideration and I see that as a plus for my clients. I learn with them, they learn with me and in the end the job is very rewarding for both.
      However with the above images I worked twice the time I charged because I knew there were a lot of guys capable of doing that better than me. However, that was a chance for me to learn and I was being paid on top of learning.
      “if they pay 25 images up front.”
      Frankly I would feel insulted if you asked me as a customer for a retainer There is no need for it (unless you are litigating) unless you are short of money to buy food. It sets a tone of mistrust. Create an image...cut an invoive...simple. If you do a good and timely job you will get paid the same way.
      You're absolutely right! But I talked about this IF negotiation would happen. Basically, discounts are annoying. I don't like how people seem to only want our work if they get a discount. Other people raise their fees to a point they can lower with discounts. I always negotiate the discounts. I cut them a deal if they offer something in return. If I don't mind loosing the job I can still give a discount if the conditions are good or very good.
      For me, this would be a boring job, wich wouldn't mean I wouldn't accept it gladly, under certain very good conditions.
      “create better images than those” This is the quality that the customer asked for...no more...no less.
      I knew it! You're perfectly capable of more than that but you won't. This is the thing I can't pull of. This is where I always fail.
      I never do what the client asks.
      Even if I start from what the client asks me, I always do what I think it's right and feels interesting. If they'd ask me something like that I would push it to the limits. In the end I would have learnt something and the client would be surprised and much happier than before. This is what I strive for... always. (even on that render above the guy was with a smile on his face when he saw the image)
      If the job isn't interesting, we can make it interesting and I bet that's why you talk about yourself as an uncreative person, wich is something that doesn't exist.
      I also think that if the next guy will do it better for the same price, I loose the client. So I always do the best I can, wich is always better than before. I'm pretty sure I could do a better image than those, though I only tried this kind of job once (image above) and I didn't know all the stuff I do now.
      But based on your comment I would want to see an image from your recent work that is better, just to see what better means to you. ( but be careful...if you set my expectation with an image that takes you hours to complete, I will expect that level of quality for every shot. You might be digging a rather large hole for yourself.
      In the case of your store fronts, the first image would be hard to achieve and would take hours, after the procedure would be set, it wouldn't take that much time.
      But unfortunately I have no storefront to show you. I also almost have no images to show you that can relate to this kind of images as I'm not selling images, I deal with projects even if in that process I do produce our project's images and they have the purpose of selling.
      What I mean is the images I produce are good for their objective but not perfect for yours. They are actually very flawed with basic flaws like toilet proxies falling off the wall, or floating trees, but in the middle of all the stuff that happens in one of our presetations or project meetings they are very good. So images are all good if they convey the message. It's just as you say
      The purpose of our images is to test space, I don't need them perfect but I need to see absolutely physical correct lighting pouring inside the building. Perfect material textures and colors that really show what is going to be built and that's why I only use Thea.
      However I would be able to use it to produce images with the same purpose as yours and I do think they would turn out better looking than those.
      But I've got something for you! The recent images I have that have similarities to yours are from a small house project we have been working on. It uses matchphoto but it has an "housefront"... no "storefront".
      It obviously took a lot of time to create as I had to design the whole project first...
      The matchphoto was fast enough but it's absolutely precise as I will use it for city hall aproval... It certainly took longer than yours.
      Rendering with Thea and my laptop takes hours, not minutes or even seconds... Of course if I was rendering a scene like yours, the laptop would be capable of doing it fast. However I have my whole project detailed photorealistically in 3d to the smallest point. I want to hit the render button in any place of the model and know that will be perfect when built. That is, for people who render scenes, stupid.
      In the end I change the project because I don't like the amount of light I see, or because the reflections take away the warmy feeling. Or because that was not, after all, the rigth shade of white. That's what a render is used for, in my case... So not only it takes ages but I have to often restart it and I never create a clear render (with this puny laptop I wouldn't be able to work for days if I cleared my images). I stop working on the render when I know what's going to be built is perfect.
      Cheers!
      Definetely Cheers! Keep it up as I'm learning a lot here!
      www.casca.pt
      Visit us on facebook!
        roland joseph
        "they learn with me and in the end the job is very rewarding for both. "
        I don't take creative licence except for hobby. Most of the time I have been given very detailed specifications. Right down to Latin names for vegetation.
        There is no flat ground anywhere in my province but I am expected even with the retail units to geo-locate and scale accurately. The projects are sponsored by the government/townships and so the workflow is very formal.
        I think in many ways we are alike but just in different stages of our career....we want to learn, we want to produce work, we want our clients to be happy and impressed.
        We want to be paid because we are skillful and we have some hard earned knowledge.
        I've learned that keeping healthy requires that I keep busy.
        I will never turn away the opportunity to build a model....for example here is one from a week or so ago....ha...does that look like architecture to you.
        [img]
        http://www.ibuildmodels.com/images/filter_water_3.jpg[/img]
        As far as the technical work goes. I have a very fast workstation. I have very powerful and very quick software. I have amazing speed with models that require a lot of rectangles... 😄 lol.
        I have rendering software that cuts hundreds of images by the minute if necessary so I don't render in a classic ray-trace fashion at all.
        The quality I acquire is not ray-trace but with a little handiwork it can look close enough for the average person..... as in the example above of the water filter.
        Because of those things I gain a lot of time per unit depending on my competition by a full order of magnitude. That gives me a very large margin.
        It takes about 100$ of my time to put together a retail front. I mark that up to 200. It is then the property of the Architect for what ever purpose.
        You see as you know JQL, you are an Architect/Artist...I am an image factory.
        My life isn't all that boring here is an on-going...the developer has just made the land purchase. I will be doing all the exteriors and interiors in this park. These image are from the first set I made when investment was being sought.
        http://www.ibuildmodels.com/images/splash_2.jpg
        http://www.ibuildmodels.com/images/plan1_22.jpg
        http://www.ibuildmodels.com/images/skate_2_water2.jpg
        http://www.ibuildmodels.com/images/400_North.jpg
        http://www.ibuildmodels.com/images/poolwaves_3_water3.jpg
          roland joseph
          I don't take creative licence except for hobby. Most of the time I have been given very detailed specifications. Right down to latin names for vegetation.
          I think in many ways we are alike but just in different stages of our career....we want to learn, we wamt to produce work, we want our clients to be happy and impressed.
          We want to be payed because we are skillful and we have some hard earned knowledge.
          As far as the technical work goes. I have a very fast workstation. I have very powerful and very quick software. I have amazing speed with models that require a lot of rectangles...lol.
          I have rendering software that cuts hundreds of images by the minute if nesessary so I don't render in a classic raytrace fashion at all.
          The quality I aquire is not raytrace but with a little handywork it can look close enough for the average person..... as in the example above of the water filter.
          http://www.ibuildmodels.com/images/wave_long-1266x580.jpg
          http://www.ibuildmodels.com/images/wave_long_2_water-1266x693.jpg
            roland joseph
            Sorry guys...I can't edit that mess....!!
            • JQLJ
              JQL
              Please don't get me wrong Roland, I think your job is very well achieved and very to the point. I miss that solidity some times. If I wouldn't have the luck of doing what I do, I wish I could do what you do...
              Certainly I would do it differently, but my concerns would be very close to yours.
              www.casca.pt
                roland joseph
                @solo said:
                8 - I'd try to find the right man for the job later
                I'm available 💚
                I could use the help. If you are between projects let me know. I have 12 of these left to complete. To tell you the truth I'm a little burnt out.
                Ill put you in touch with the architects and you can take it from there. I have worked for them for years. They will pay you immediately for your work.
                Solo, let me know if you are serious so I can explain what is needed and we can establish a cost per store front.
                • soloS
                  I sent you an email.
                  • andybotA
                    andybot
                    How did I miss this thread! - great discussion JQL & Bruce. Working on your own certainly requires a fine balance between having enough artistic interest in your work, satisfying clients, and paying the bills 😄
                      roland joseph
                      I take on all projects with a lot of enthusiasm. This year I took on a job that amounted to building 100 store fronts. The first 10 I was learning, The next 20 I had the workflow down, the juices were flowing and I was making good time. The next twenty I was hoping the barn door was coming up soon. The next twenty I felt like I was on kilometer 30 of 40k. I only made it to 80 or so. The last 10 just about killed me. I was seeing double and all the colors and shapes seemed to be melding. I had to force my hands to the keyboard.
                      It is a good project....I just lost my mind with it. I reached a threshold of repetition that I could no longer cope with.
                      Thankfully someone here has taken over the project and he is doing a great job of bailing me out of trouble.....I won't mention a name. 😒
                      • JQLJ
                        JQL
                        And yet it seems we keep finding a lot of things in common!
                        That is the sort of feeling I get at 80% of project completeness when I have to map all doors, windows, closets and bathrooms of a project... It is plainly boring and it looks like that work, wich should be dead easy, is taking as long as the whole design of the building. I just can't focus...
                        www.casca.pt
                          roland joseph
                          plainly boring
                          I just try to remember that I am lucky to have a job and that many others have jobs that are worse. Could you imagine being a pilot in the twilight of your career. Falling asleep would not be an option. 😮
                          • pbacotP
                            JQL. Boy I'm with you on that one! As much as possible organize that work to be more automatic (that i, you just group those repetitive tasks, put on some music and click away). And of course "boiler-plate" development pays off at the end of projects. I have never had just boiler plate sheets, but now I am tempted to put all those notes I keep pasting in here and there (and the plan checker looks for ) on a sheet and forget about it, except to update.
                            I have had the privilege to do menial work of the physical kind and this still beats that--but it IS easier to get sleepy.
                            • JQLJ
                              JQL
                              I know there's worse... but that IS bad! Fortunatelly it is just a small part of the job... the rest of it is really great!
                              www.casca.pt
                              • B
                                BeeBoy
                                Looking for Sketchup freelance people to come onboard out team to model Set Builds for a Tv Drama Filming in London this autumn. Work to Start asap. you need : Fast, organised with layers, good understanding of London period architecture, THIS IS A LONDON BASED POSITION WORKING FROM OUR OFFICE ONLY....
                                This is for a Main tv Channel and a very interesting Project we are Working in new ways embracing what is possible with Sketchup and Our Existing Techniques. (THIS IS OBVIOUSLY A PAID POSITION, RATE TO BE DISCUSSED)
                                Email Any Work Examples or Questions To CV@sionclarke.co.uk
                                  roland joseph
                                  Why is that?
                                  • 3 / 3
