    Get the coordinates of the corners of the viewport
    31 Posts 6 Posters 4.7k Views 6 Watching
      dacastror
      I'm realizing I have to create a kind of observer of the size and position of the viewport, so that my webdialog is maintained in the corner when the user changes the size or position of the window Sketchup, for now the only option I see is do something with UI.start_timer and UI.stop_timer
        driven
        simple question,...
        what do you want to 'put' in the webdialog?
        adding observers has a cost to performance and can be very hard to debug when they go wrong...
        just curious...
          Anton_S
          @dacastror said:
          I have a question about owner = GetWindow.call (active, 4) I do not quite know who does this
          The code has two parts to it:
          active = GetActiveWindow.call() owner = GetWindow.call(active, 4) MAIN_HWND = owner == 0 ? active : owner
          When SU starts, we get active window. The active window could return a handle to SU window or a handle to a webdialog belonging to SU window. To make sure that we get SU window, and not a webdialog, we use the GetWindow with a GW_OWNER command.
          Yes, a timer would be an easy way to go. However, my AMS Library, has such observers (EDIT: But, they don't rely on timer. They rely on actual messages coming from SU window procedure). You can see documentation here, in case you are interested: AMS::SketchupObserver.#swo_on_size_move
            dacastror
            Anton thank you very much for your explanation and links.
            you have many observers available it is awesome, I have two versions of your library,1.0.9 and 2.2.0, I'm trying to understand how you manage to observe changes in the windows but I can not understand how you do, What is the basis of your observers? Is it a timer that question every so often? or does it work differently? Anton sorry for asking so much, It is that I am interested in the mechanisms behind the clock.
            I want to keep as a surprise, when I finish you will understand why I needed this, however I will seriously consider your points.
              dacastror
              I want to keep as a surprise, When I finish you will understand why I needed this, however I will seriously Consider Your points.
              it seems that is no longer available the info in this link
              We're sorry, the page you requested cannot be found.
              you could give me another clue to study this?
                Anton_S
                Here is window procedure I'm using to monitor window events: [Window Procedure](https://msdn.microsoft.com/en-us/library/windows/desktop/ms633573(v)
                Here is more info about window procedures and how to use them: https://msdn.microsoft.com/en-us/library/windows/desktop/ms632593(v=vs.85).aspx
                  Anton_S
                  My observers work by intersecting into SU window procedure and monitoring its messages. That is, too, possible with Windows API. No timers are needed. I have it all integrated in my C++ extension of AMS Library. You can read here about window procedure: https://msdn.microsoft.com/en-us/library/windows/desktop/ms633573(v=vs.85).aspx
                    dacastror
                    Anton thank you very much, I'll get to study this šŸ¤“
                      Anton_S
                      Your welcome, dacastror. Window Procedure is a callback function. Win32API has no feature to create callbacks. You could use Ruby Fiddle (available as standard lib in SU2014+) or Win32-API (A more advanced win32 API by Daniel J Berger), but they could endup very performance consuming if you try to monitor SU WindowProc through Ruby. You might want to consider writing a C/C++ extension.
                      Hey, I will make a little C++ extension for you as you mentioned your not very familiar with C and how to use it in SU. All you'll need is Visual Studio (VS2010 preferred).
                        dacastror
                        Anton you're great, I will be attentive to what you show me to make a extension.
                          Anton_S
                          Okay, I finished it!
                          Extract dacastror.zip into your plugins folder, run SU, and see what happens.
                          This dacastror extension works under Ruby version 1.8.6 and up, which means it will work in SU8 and up. To make it work in SU6 and SU7, you'll need to update SU Ruby interpreter. Do that by copying msvcrt-ruby18.dll from SU8 or SU2013 path and pasting it in SU6/7 path (overwriting outdated ruby interpreter). Something else can be done with the C++ extension itself, to make it work under SU6/7, but I don't find it necessary as old SU versions are "deprecated" anyway.
                          The C++ extension works with visual studio (2010 preferred). I omitted several unused mac libraries and removed Swig, from original Github download, and just left the necessary parts. This reduced size significantly. Do the following to compile and use your c++ extension:
                          1. Extract SketchUp Ruby C++ Extensions.zip
                          2. Run SketchUp Ruby C++ Extensions/SketchUp Ruby C++ Extensions.sln
                          3. Select Solution Configurations box to preferred Ruby version, Release (2.0) is there by default.
                          4. Select Solution Platforms box to preferred platform, x64 is there by default.
                          5. Open Solution Explorer, right-click on dacastror project, and select Build.
                          6. Navigate to SketchUp Ruby C++ Extensions/Release x.y/... and get your .so library from there.
                          7. For you plugin, you will need 3 builds: Release 1.8 Win32, Release 2.0 Win32, and Release 2.0 x64.
                          8. Copy/Move dacastror.so to it desired folder in Plugins/dacastror/win[32/64]/[1.8/2.0]/
                          Your dacastror plugin already has all compiled so libraries. I added this as a guide so you could use it whenever you want to modify your C++ extension.
                          Oh and by the way, your dacastror.so contains the following functions:
                          • Dacastror::Windows.get_main_handle
                          • Dacastror::Windows.get_viewport_handle
                          • Dacastror::Windows.get_viewport_rect
                          • Dacastror::Windows.add_observer(object)
                          • Dacastror::Windows.remove_observer(object)`
                            See Plugins/dacastror/main.rb for more info.
                            You can also generate documentation of your C++ extension. Read more about it in SketchUp Ruby C++ Extensions/Dacastror/src/How To Generate Doc.txt
                          Dacastror sample plugin. Place in plugins folder.
                          Dacastror C++ extension. You'll need visual studio to use it.
                            dacastror
                            ā˜€ šŸ˜ Anton thank you very much, this is great, Christmas had never come so early for me, I am very happy. I am examining every part of this and I'm downloading "visual studio 2010," I'm trying to absorb all this.
                              dacastror
                              I just installed extesion and open sketchup, works great !!
                              these observers are perfectly suited to my need šŸ˜„
                                Anton_S
                                Gurait! That c++ extension you have is my latest masterpiece. I'm pretty sure I'll have to improve my old AMS Library šŸ˜„.
                                  dacastror
                                  where you learn to do these wonderful things?
                                    Anton_S
                                    By examining other extensions and stuff I learned how to use C++. Now, I take CS162 at college and C++ becomes an easy language to use. My knowledge of Windows API is all from my long experience using it. It took some effort developing useful methods and optimizing them over time. It was all worth it though šŸ˜Ž.
                                    • tt_suT
                                      tt_su
                                      C++11 yum yum!
                                        Anton_S
                                        I'm not sure if I used any C++ 11 syntax in that C++ extension, but Ruby C++ extensions as a whole give so much opportunities to writing great plugins in SU. I'm amazed that SU team chose Ruby over all available programming languages. Back then, when SU was first released, Ruby wasn't even popular, but SU team bypassed popularity and chose Ruby because Ruby was both simple and powerful due to a feature in supporting C extensions. Today, Ruby is becoming popular and is improving in performance and in features. Something tells me that SU had and still has really great minds behind it because choosing Ruby was the best path SU team could ever take. Imagine if they chose python or any other high level, limited programming language. SU would have been a totally different story from what it is today. Huge thanks goes to SU team for making SU a very great software for writing powerful plugins.
                                        With your input, this post could be even better šŸ’—
                                        • 2 / 2
