    [Plugin] Project Beam (Update)
    18 Posts 6 Posters 16.4k Views 6 Watching
    • sdmitchS Offline
      sdmitch
      g_wilson, Please download and try the new version. When I created the plugin, I tested it only to satisfy the criterior of the requestor. The new version corrects the problem caused by non-parallel faces. The only problem that I'm aware of at the moment is when the selected face only partially falls on the face projected to.
      boiling, yes I am constantly re-inventing the wheel. Case in point TIG's Extrude Edges by Vector and Extrude Edges by Vector to Object.
      http://forums.sketchucation.com/viewtopic.php?t=25362
      http://sdmitch.blogspot.com/
      • pbacotP Offline
        Both end faces of the final shape will be parallel to the original face that is extruded. I don't find a restriction on the orientation to axes so far.
        I think the direction the edge is drawn (away from the face) is the direction the beam is made.
          g_wilson
          Congratulations Sir. It works without fail.
          All previous problems gone. Even tried - two faces at some compound angle two each other with one face "square" to the world and with edge at some compound angle - it works no matter which face you start from. Nastiest example I can manage - two faces both nonplanar to each other and the world and edge at some random angle in all planes- it still works. One little oddity cropped up - using a hexagon it works but tells you that it can't match opposite face,will draw to length given by edge - no problem. But with a circle it DOES cope into the finishing face as long as the edge is within some small angle to one plane (XYZ) - just bloody wonderful if working with pipe or similar!! Great job !! Thank you !!
          • sdmitchS Offline
            sdmitch
            g_, the message you mentioned should only occur if the projected face does not completely fall on the face being projected to. It's an all or none.
              boilingsnow
              We should thank you as all the other authors here for creating useful plugins and share them with us.
              I also tried to download all your plugins on your website.
              But I find a problem as well. Did anyone tell you that you uploaded the video tutorial for "snappoint" twice and forgot to upload the plugin itself?
              • sdmitchS Offline
                sdmitch
                No you're the first. Thanks.
                  raineysky
                  Awesome plugin!!! Thank You Sam
                  Please keep, "re-inventing the wheel". Your plugins are great.
                    raineysky
                    Sam,
                    I've been using this plugin a lot lately and it's wonderful. A problem I've run into is projecting the I-beam to a curved surface. Does that work or am I doing something wrong?
                    Thank You,
                    Paul
                    • sdmitchS Offline
                      sdmitch
                      @raineysky said:
                      Sam,
                      Thank You,
                      Paul
                      Sorry but no since the projected corners of the selected face will not be co-planar due to the curved face being projected to.
                        raineysky
                        Sam,
                        Thanks for the quick reply and thanks for the great plugin. It has really sped up my workflow. I'll find a work-around for the curved surface.
                        Paul
                        • sdmitchS Offline
                          sdmitch
                          @raineysky said:
                          Sam,
                          Paul
                          Does the projected beam have to be a solid? If not, commenting out one statement will allow it to work.
