    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 136.8k Views 13 Watching
      You can try also something who is between SU and Moi3D (it's free and has SKP export) ๐Ÿ˜‰
      DesignSpark 64 Bits (who is formerly SpaceClaim light) so Sketchup on Steroรฏds! ๐Ÿ˜„
      You can load Billions of Free Objects or create from zero! ๐Ÿ˜ฒ
      Here an Object that I have loaded then you can modify it to the infinite!
      Then reloaded in Su after modifications! ๐Ÿ˜„
      • JQLJ Offline
        JQL
        Thanks Pilou
        I also seen you post that one. It seems very good for components that you can model independently from your sketchup model. However I really have to model most stuff inside SU as my models are architectural. It's another one wich feels like having all the right modelling tools but lack all the juice one needs.
        It might be worth the look as it's got a very inteligent push/pull tool. I don't understand why sketchup developers don't put a greater effort towards developing existing tools. It's not that pushpull is not a cool 3D starting method, it's just that the only advanced thing you can do with it is duplicating a face (wich gets a lot of reversed face errors by the way).
        MOI and that one really are examples to follow and I do believe that if they'd have half the popularity of Sketchup... Maybe Trimble won't let it Tremble.
        www.casca.pt
        Visit us on facebook!
          Function Split by Max Smirnov
          http://s6.postimg.org/7dyja993l/gag.gif
            by Ed Ferguson
            http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=e3358757e8569e8c7300d00c02fefb0c&filename=boombox4.png
            http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=f10df25f6686331be0a0ab0ad734347a&filename=boombox1.png
              New function Scale and Split accepts Ngons !
              By Max Smirnov
              A trick for the sSplit : don't select only the volume, but select the volume then use the Browser for select faces!
              http://s6.postimg.org/5ssg9xdn5/split2.gif
                Teasing! ๐Ÿ˜„
                  Split edges releaded ๐Ÿ˜‰
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/323333_orig.gif
                  Knife is implicite!
                  A simple Boolean Diff make the trick ๐Ÿ˜„
                  http://s6.postimg.org/kp06903td/knife.gif
                  http://s6.postimg.org/krk1vu7gx/knife1.gif
                    new version sSplit โ˜€
                      By James Elliott
                      http://moi3d.com/gallery/images/JamesElliotRichardIIITomb2_sized.jpg
                      http://moi3d.com/gallery/images/JamesElliotRichardIIITomb3_sized.jpg
                      http://moi3d.com/gallery/images/JamesElliotRichardIIITomb1_sized.jpg
                        UI & model modรจle by Chippwalters
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/947054949.jpg
                        This render inside Sketchup with free Visualizer 1.3!
                        http://dl.dropboxusercontent.com/u/3788438/3D/VIZ_0016a.jpg
                        http://dl.dropboxusercontent.com/u/3788438/3D/Env2-01.8.jpg
                        http://dl.dropboxusercontent.com/u/3788438/3D/ProductRender03.55.jpg
                          Shoes Tutorial
                          by Lawrence
                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/5595950_orig.jpg
                          Mannequin By Chippwalters
                          File 3DM File SKP linked! ๐Ÿ˜‰
                          http://s6.postimg.org/916pwfx3l/mannequin_su.jpg
                          https://dl.dropboxusercontent.com/u/3788438/MoIGUIdownloads/MOI-PAT/MOI-PAT.001.jpg
                          mannequin.skp
                            • JQLJ Offline
                              JQL
                              Pilou,
                              Seems like we need an Onshape thread...
                              This one does have Layout alike functionality and it seems good! Have you seen architectural examples?
                              www.casca.pt
                                It's a CAD program. It will be perfect for mechanical pieces. Or design object like bicycles, cars, furnitures etc...
                                For big complex architectural project that will be more hard but very cool for "architectural structure" or small houses and details concepts.
                                The only "real limitation" for free use is the 5 gigas hosting! (see video above)
                                And big advantage it has a very cool new concept of animation!
                                Minute 0.42
                                • JQLJ Offline
                                  JQL
                                  Is that cool or what?
                                  Autocad started as mechancal cad too.
                                  www.casca.pt
                                    This is very coll for any Makers !!! ๐Ÿ˜„
                                    How many generations of users have some pills used for manage it ? ๐Ÿ’š
                                      By Mauro
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/249844393_orig.jpg
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/260338028.jpg
                                        For use the animation functions of Onshape just export from Moi in Step format! ๐Ÿ˜„
                                        (you can of course animate in SU after export in SKP fromat from Moi , but that will be not Nurbs format ! )
                                        Upload the .step file, Translate in Onshape format et voilร ! ๐Ÿค“ ๐Ÿ˜„
                                        http://s6.postimg.org/71pduduxd/moi_onshape.jpg
                                          New automatic function for close surface,volume
                                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/455616_orig.gif
                                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9593946_orig.gif
                                            Tutorial very detailed Car's Ed (here in French ๐Ÿ˜‰ )
                                            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1909184_orig.jpg
                                            • 11
                                            • 8 / 11
