    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 193.7k Views 13 Watching
    • JQLJ
      JQL
      Thanks Pilou
      I also seen you post that one. It seems very good for components that you can model independently from your sketchup model. However I really have to model most stuff inside SU as my models are architectural. It's another one wich feels like having all the right modelling tools but lack all the juice one needs.
      It might be worth the look as it's got a very inteligent push/pull tool. I don't understand why sketchup developers don't put a greater effort towards developing existing tools. It's not that pushpull is not a cool 3D starting method, it's just that the only advanced thing you can do with it is duplicating a face (wich gets a lot of reversed face errors by the way).
      MOI and that one really are examples to follow and I do believe that if they'd have half the popularity of Sketchup... Maybe Trimble won't let it Tremble.
      www.casca.pt
      Visit us on facebook!
        Function Split by Max Smirnov
        http://s6.postimg.org/7dyja993l/gag.gif
          by Ed Ferguson
          http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=e3358757e8569e8c7300d00c02fefb0c&filename=boombox4.png
          http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=f10df25f6686331be0a0ab0ad734347a&filename=boombox1.png
            New function Scale and Split accepts Ngons !
            By Max Smirnov
            A trick for the sSplit : don't select only the volume, but select the volume then use the Browser for select faces!
            http://s6.postimg.org/5ssg9xdn5/split2.gif
              Teasing! πŸ˜„
                Split edges releaded πŸ˜‰
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/323333_orig.gif
                Knife is implicite!
                A simple Boolean Diff make the trick πŸ˜„
                http://s6.postimg.org/kp06903td/knife.gif
                http://s6.postimg.org/krk1vu7gx/knife1.gif
                  new version sSplit β˜€
                    By James Elliott
                    http://moi3d.com/gallery/images/JamesElliotRichardIIITomb2_sized.jpg
                    http://moi3d.com/gallery/images/JamesElliotRichardIIITomb3_sized.jpg
                    http://moi3d.com/gallery/images/JamesElliotRichardIIITomb1_sized.jpg
                      UI & model modèle by Chippwalters
                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/947054949.jpg
                      This render inside Sketchup with free Visualizer 1.3!
                      http://dl.dropboxusercontent.com/u/3788438/3D/VIZ_0016a.jpg
                      http://dl.dropboxusercontent.com/u/3788438/3D/Env2-01.8.jpg
                      http://dl.dropboxusercontent.com/u/3788438/3D/ProductRender03.55.jpg
                        Shoes Tutorial
                        by Lawrence
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/5595950_orig.jpg
                        Mannequin By Chippwalters
                        File 3DM File SKP linked! πŸ˜‰
                        http://s6.postimg.org/916pwfx3l/mannequin_su.jpg
                        https://dl.dropboxusercontent.com/u/3788438/MoIGUIdownloads/MOI-PAT/MOI-PAT.001.jpg
                        mannequin.skp
                          • JQLJ
                            JQL
                            Pilou,
                            Seems like we need an Onshape thread...
                            This one does have Layout alike functionality and it seems good! Have you seen architectural examples?
                            www.casca.pt
                              It's a CAD program. It will be perfect for mechanical pieces. Or design object like bicycles, cars, furnitures etc...
                              For big complex architectural project that will be more hard but very cool for "architectural structure" or small houses and details concepts.
                              The only "real limitation" for free use is the 5 gigas hosting! (see video above)
                              And big advantage it has a very cool new concept of animation!
                              Minute 0.42
                              • JQLJ
                                JQL
                                Is that cool or what?
                                Autocad started as mechancal cad too.
                                www.casca.pt
                                  This is very coll for any Makers !!! πŸ˜„
                                  How many generations of users have some pills used for manage it ? πŸ’š
                                    By Mauro
                                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/249844393_orig.jpg
                                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/260338028.jpg
                                      For use the animation functions of Onshape just export from Moi in Step format! πŸ˜„
                                      (you can of course animate in SU after export in SKP fromat from Moi , but that will be not Nurbs format ! )
                                      Upload the .step file, Translate in Onshape format et voilΓ ! πŸ€“ πŸ˜„
                                      http://s6.postimg.org/71pduduxd/moi_onshape.jpg
                                        New automatic function for close surface,volume
                                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/455616_orig.gif
                                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9593946_orig.gif
                                          Tutorial very detailed Car's Ed (here in French πŸ˜‰ )
                                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1909184_orig.jpg
                                            Max Smirnov + Dinos has made a Volume/Mass Calculator! πŸ˜„
                                            • 11
                                            • 4 / 11
