    [Plugin] Team Edit - synchronised modelling v0.1.5 (alpha)
    19 Posts 6 Posters 8.9k Views 6 Watching
    • JQLJ Offline
      JQL
      Tommy,
      I'm confortable on the plugin changing the display style temporarly IF it doen't save/applies the changes. Maybe this could be an option on a plugin definition because I would mind to work on a TeamEdit style. I have all my models setup with styles that are saved on scenes and styles I set while working for faster display. This working style is applied using a plugin "Trog_Styles" (or similar name) and a shortcut.
      I really like the idea that the background changes because I always set it to transparent on Layout wich wouldn't be affected by the color change.
      However if we are working on a component that is indoors there's no way to see the background that visual indication would be lost. What about allowing us to set the style warning of our choice. I, for instance, would gladly have my style being changed to Red/Orange lines along with the background as it's way more important for me to be careful when editing than to be conservative on changes to the visual style. (Specially if this changes wouldn't be saved on model.)
      www.casca.pt
      Visit us on facebook!
        driven
        @tommy
        have you got a dropbox model that people can test against???
        we could all play with different bits and you 'overlord' it...
        • TommyKT Offline
          TommyK
          @driven said:
          @tommy
          Here you go:
          https://www.dropbox.com/sh/kn7zbev4ypffolu/AADO0wm43jj1FgvFjgjBOP3Ia?dl=0
          I can't find an option to allow anyone to edit the folder, so it wouldn't quite work in the same way. I will be happy for anyone to PM with their email, and I will invite you to the Dropbox folder.
          • TommyKT Offline
            TommyK
            @jql said:
            Tommy,
            I think you have some good points there, JQL. So good in fact, that it has been implemented in the latest release.
            Team Edit update v0.1.3 with what JQL said
            • JQLJ Offline
              JQL
              Thanks Tommy!
              www.casca.pt
              • N Offline
                Near2010
                Hi Tommy,
                Me and my team are very excited about this plugins, we also trying it, but it doesn't work as your explanation on usage. First, We have synchronize our files on google drive and it synchronized properly. When enabled team edit, component folder was created, but every time we save the component model, changes made by other users wont be reloaded on my main model. Is there any wrong action we take? We'll very appreciate if you could share the step how to use it properly.
                Thanks πŸ˜„
                • TommyKT Offline
                  TommyK
                  @near2010 said:
                  Hi Tommy,
                  Thanks πŸ˜„
                  I'm sorry to hear that, and thank you for trying the plugin out and reporting back.
                  Firstly, please confirm the following:
                  • that the plugin is installed on all computers that are editing those components
                  Two possible things come to mind:
                  • changes are reloaded on your main model when you save the main model.
                  • I haven't tried it with Google Drive before, but it should work like Dropbox. With large components, it can take some time for the component files (.skp files) to be synced on Google Drive/Dropbox. There can be a situation where TeamEdit can't find the new component, in which case it assumes it hasn't been synced yet, and waits until the next save operation to have another go at reloading it.
                  If the above doesn't help, I would very much appreciate it if you could send me the folder called "Network Files" (within your "XXX_Components" folder. You can PM me. Also please let me know what platform you are on (PC/Mac, Win version, SU version etc).
                  • TommyKT Offline
                    TommyK
                    Team Edit updated to v0.1.4. It now works on PC!
                    (funny no one told me until now - thanks to Near 2010 for the report)
                    • N Offline
                      Near2010
                      Thanks Tommy, now it works on our PC πŸ‘
                      We'll do some test and give you some feedback if you don't mind πŸ˜„
                      • JQLJ Offline
                        JQL
                        I feel a bit ashamed here, but I haven't tried Team Edit yet. I'm just in the middle of a project and can't change the procedure now. I guess a simple example would be interesting... As soon as I have some time I will try it as fully as I can.
                        www.casca.pt
                        • TommyKT Offline
                          TommyK
                          Don't worry! Try it out at your pleasure. It shouldn't be used in a production environment yet anyway. Simply put, the more feedback I get, the more reliable it will get.
