    Multiple flip in component red axis
    5 Posts 3 Posters 614 Views 3 Watching
    • alexandre skA
      alexandre sk
      Hello people. Trying to make a simple plug-in for a specific purpose but cant find the command.
      When I right click a component it appears Flip>Flip component red axis, but when I selected multiple it flip all together not individually. I am clear? I think not. Anyway, if someone can point me the command line that do that maybe I can make the simple plug-in.
      Or maybe already exist one.
      The use, is: If I have a LOT of cars ( components ), with different rotations and i just want to reverse the cars direction, i have to do individually.
      Thanks.
      • sdmitchS
        sdmitch
        Thanks.
        Perhaps this one-liner will do what you want. It will flip the x for all selected.
        Sketchup.active_model.selection.grep(Sketchup;;ComponentInstance).each{|c|xa=c.transformation.xaxis.reverse;t=c.transformation.to_a;t[0]=xa.x;t[1]=xa.y;t[2]=xa.z;c.transformation=c.transformation.set!(t);}
        http://sdmitch.blogspot.com/
          slbaumgartner
          This will flip the components around their origin without moving the origin. If you want to emulate what the GUI's "flip around component axis" does you will need to also move the components after flipping.
            slbaumgartner
            If you load the attached Ruby and then type flip_all_x in the Ruby Console, it will replicate the action of flip along component's red axis for every ComponentInstance or Group in the current selection. This is just an extension of sdmitch's code unwrapped as a file and fixed for the origin shift.
            flip_all_x.rb
            • alexandre skA
              alexandre sk
              fantastic as always. Thank you slbaumgartner and sdmitch. The flip all x works perfectly! The sdmitch code already was great. This forum is always great.
              I will make a simple free plug-in to help road build, and share here when it is ready.
