    How to judge whether a 3D point is visible or not
    6 Posts 3 Posters 552 Views 3 Watching
    • lbsswuL Offline
      lbsswu
      Hi everyone,
      Suppose I have opened the Sketchup software, I want to know whether a 3D point is visible or not in current view.
      For example, the 3D point may locate on the back of a person, thus we can't see it when the person facing to us.
      This should be done by Sketchup ruby code.Could anyone help me?
      • sdmitchS Offline
        sdmitch
        @lbsswu said:
        Hi everyone,
        I placed a construction point, the little black dot just below the horizon, and "Nancy" in the model. I then used the following code to test if the point was visible.
        mod = Sketchup.active_model
        ent = mod.active_entities
        sel = mod.selection
        vue = mod.active_view
        eye = vue.camera.eye
        cp = ent.grep(Sketchup;;ConstructionPoint)[0]
        pt = cp.position
        vec = pt.vector_to(eye)
        hit = mod.raytest([pt,vec])
        if hit
         puts "pt is not visible"
        else
         puts "pt is visible"
        http://sdmitch.blogspot.com/
          slbaumgartner
          @sdmitch, is the logic reversed in your test on hit? I think raytest returns nil if the point is not visible.
          OK, I'm confused...unfortunately, the Ruby API site is not responding right now (server issues?) so I can't look at the documentation for raytest.
          • sdmitchS Offline
            sdmitch
            if the ray "hits" something then that means that that object must be between the point and the camera. If there are no obstructions then raytest will return nil.
              slbaumgartner
              Yeah, I figured that out by experimentation since I can't get to the docs. Thanks!
              • lbsswuL Offline
                lbsswu
                @sdmitch said:
                @lbsswu said:
                Hi everyone,
                > sel = mod.selection
                > pt = cp.position
                > if hit
                > else
                > end
                Hi, sdmitch. Thank you very much. It works!
