    [Plugin] GKWare Door Maker
    46 Posts 10 Posters 11.5k Views 10 Watching
    • B
      BdhSdfCr
      @garry k said:
      Can you start a new session and run be ruby console prior to running the door maker? Also, I do write information to the gkware_doormaker\config folder - so you need to have rights to that folder.
      I don't have mavericks - I run Windows 7 OS. I can give you a stripped down version that just pops up a web dialog box if that will help figure out the problem.
      Here is what the Ruby Console reports when I click on DoorMaker...
      Error: #<ArgumentError: wrong number of arguments (2 for 4..5)>
      /users/b-d-hayes/library/application support/sketchup 2014/sketchup/plugins/gkware_doormaker/license.rbs:34:in activate_license' /users/b-d-hayes/library/application support/sketchup 2014/sketchup/plugins/gkware_doormaker/doormaker.rbs:90:in activate'
      /users/b-d-hayes/library/application support/sketchup 2014/sketchup/plugins/gkware_doormaker/doormaker.rbs:609:in select_tool' /users/b-d-hayes/library/application support/sketchup 2014/sketchup/plugins/gkware_doormaker/doormaker.rbs:609:in block in module:DoorMaker'
      -e:1:in `call'
      I'm logged in as administrator so I should have permissions for everything.
      • G
        Garry K
        Version 1.0.30 went out with 1 wrong package.
        I have a new version 1.0.31 which corrects this.
        Please try it and tell me if it solves your problem.
        • B
          BdhSdfCr
          Thank you Gary, 1.0.31 worked.
          • G
            Garry K
            I have a new version 1.0.33 that contains a number of new features.
            1. Half Width Stiles - Make either the right or left stile half the width. Good for Bifolds
            2. Second Handle - Places a mirrored copy of the handle on the back side of the door. Good for passage doors.
            3. Wood Grain - Allows you to manage the direction of the grain for door and drawer panels.
            4. Save and retrieve Named Style Sheets. Allows you to name any number of style sheets with specific door settings. For instance you could have a list such as
            Bifold Doors
            Passage Doors
            Panel Raised Portland
            Choices are virtually endless
            This version will be available by Thursday Sep 4th
            • G
              Garry K
              New Door Maker plugin just about ready.
              Added mitered doors. User defines their own frame profile.
              You can optionally select the back edge of the groove at the same time as selecting the profile face.
              Door Maker will use the information to build your doors.
              Mitered Door Profile
              Mitered Door
              • KrisidiousK
                Krisidious
                Is there an option to configure the number of vertices in the curves? on the door profiles?
                By: Kristoff Rand
                • G
                  Garry K
                  You have complete control over your own profiles. Make them however you wish.
                  • KrisidiousK
                    Krisidious
                    Excellent...
                    By: Kristoff Rand
                    • G
                      Garry K
                      Version 1.0.34 of Door Maker plugin is now available.
                      • yorik1984Y
                        yorik1984
                        How to use free version 1.0.39?
                        • G
                          Garry K
                          Sorry Yorik - Free version is no longer supported.
                          • G
                            Garry K
                            Version 1.0.39 is now available
                            • G
                              Garry K
                              New version 1.0.49 now available for download
                              • Version number now shows up on title bar of web dialog
                              • Now uses same License strategy as cabmaker
                              • Check license now first deletes old license and then updates license
                              • Has preferred setting for users who have license issues
                              • 3 / 3
