    Sweet New Plugin from Garry Kernan is in the pipe.
    38 Posts 9 Posters 4.3k Views 9 Watching
    • jujuJ Offline
      juju
      I cant' wait to see the finished product!
        Garry K
        Testers found a few bugs that I am working through. I've also learned a bit and I believe that I will be able to handle opening and closing of bifolds.
        The dowel is just to show you where the pivot point is.
        Bifold with half jamb closed - using pivot point of 35 mm
        Bifold with half jamb opened - same pivot point
          Garry K
          Here is a working version of a pair of bifold doors.
          Pair of Bifolds
          • KrisidiousK Offline
            Krisidious
            It has a construction guide in it... But very nice.
            By: Kristoff Rand
              Garry K
              Yes - the construction guide was temporarily added along with the circles. Shows that the pivot point works as expected.
                Krisidious
                yes, works well...
                By: Kristoff Rand
                  Garry K
                  New DoorMaker Gold is now in testing.
                  Should be available for general download within a few days.
                  Version 1.0.36 – Dec 17, 2014
                  1. Added door jambs and half jambs for passage doors and bifolds.
                  2. Added Swing Layer for 2D house plans.
                  3. Added pivot point for passage doors and astragals for double doors.
                  4. Re organized door maker input form.
                  5. Added Top Rail Height.
                  6. Added a number of new fields to support door jambs.
                  7. Dropped "Schlage Modern Handle Left" and changed the name of "Schlage Modern Handle Right" to "Schlage Modern". Door maker now flips RH handles for LH doors.
                  8. Finished dynamic movement for bifold doors.
                  9. You can now have 0 to 3 mullions for square panel sections.
                  • jujuJ Offline
                    juju
                    Excellent! Just as I am about to go on holiday. Will have to check it out at a later stage then.
                      Garry K
                      The new version is now available from my website
                      cabmaker32.com
                      You need to register and then you can download a trial.
                        AcesHigh
                        @olishea said:
                        @garry k said:
                        I can put a direction symbol like an arc and an arrow for 2D plans.
                        You are suggesting to put the direction information on a user defined named layer.
                        Please provide an example of what you would like to see for a direction symbol
                        That pivot hinge looks interesting. Looks like the door will complete clear the casings and can open 180 degrees.
                        This pivot hinge allows a door to open both directions.
                        [attachment=0:3d200ecp]<!-- ia0 -->both way pivot hinge.PNG<!-- ia0 -->[/attachment:3d200ecp]
                        Just thought it would be a nice addition to your plugin. People tend to use pivot hinges on very large external doors (>1000mm wide) although you do see them internally from time to time. I believe there is also another pivot hinge that just acts as an axle directly though the door, might be wrong but the type you have posted looks a bit more intricate than the ones I have seen, unless I have misunderstood the mechanism.
                        http://1.design-milk.com/images/2013/05/pivot-door-Graux-Baeyens-Architecten-600x900.jpg
                        this photo makes me dizzy. Depth, wideness, size of door, corridor. Nothing matches.
                          Garry K
                          I have added a simple pivot hinge to any door - you choose.
                          You provide a value for the pivot point.
                          I use that value to move the rotation point precisely the value you picked from the end of the door.
                          Then I center it by simply dividing the door thickness by 2
                          I know some pivot hinges use offsets - this one currently does not.
                          With your input, this post could be even better šŸ’—
                          • 2 / 2
