    Monochrome Floor Plans
    24 Posts 9 Posters 2.9k Views 9 Watching
    • RichardR Offline
      Richard
      Mate I think everyone covered the points I'd raise. But I'll throw them up again, shadows are a bit dark and the windows are, as Peter suggests, too detailed to break from the walls.
      Personally I'm not a lover of plans attempting to gain that 3rd dimension. After all that is what they are, a PLAN! One of the things I find when shadows are cast is the closure of the space. I think it is essential to furnish a plan to allow the reader to recognise function quickly, and to see how spaces and circulation have been addressed. However casting shadow from furniture makes it difficult for the reader to differentiate built in from furnished.
      One other thing about shadows is when it comes to printing, nice clean linework from vector is lost and all becomes hazy!
      Peter is right that the floor plan Cotty linked to is done direct in Layout. Again I don't like this style of representation AT ALL! It was a clients demand and for a sign! Plus the shadows are added via Indesign so to keep the file as a vector for clean reproduction.
      I think in the end we have to balance our desire of want to showcase our skill v's that of what is most legible for the reader!
      As far as colour goes or even that of greyscale. I do like the use of colour to allow quick recognition of room function. Though again would reiterate that solid furnishing will visually diminish the size of spaces.
      This style of plan is probably my preference for ease of reading. Remember that although many of us can read your great work, we've all had YEARS of experience at reading plans! The random viewer may not! BTW this is developed directly in Layout, actually I use layout for all design planning not just the presentation. I know many would find the double dealing of doing up a separate works in layout just for the presentation as time wasted, but to trace your plan in LayOut might take 30 min.
      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
      • ccaponigroC Offline
        ccaponigro
        I'm obsessed with this program. I would almost do it for free. Let's keep that just between us.
        First pass animation
        cfcaia.com
          ccaponigro
          Ok that didn't work.
          cfcaia.com
          • pbacotP Offline
            Wow, you're going to town with all the framing and so forth. Nice little video.
            • massimoM Offline
              massimo Moderator
              Totally agree with Richard.
              The same for 2d sections of a 3d model. Why obtaining plans and sections from a 3d model? Shouldn't be the opposite? Both plans and sections are "symbolic"and "conventional" representations and not "real". They have representation rules that are not close to reality and should give much information as possible in a clear way. An example: plans and sections must always show at least a door and a window for every room even if there is no window or door in the point of the cut.
                ccaponigro
                Hope this isn't to abrupt but I say nonsense. It's time to let go of those old ways of thinking and working and the tools available demand it of us.
                cfcaia.com
                • massimoM Offline
                  massimo Moderator
                  Call it nonsense if you like. I don't mind. The concept is that a plan or a section done with whatever you like and in whatever way you like, should be clear and respect some rules. If not, you'll have some useless graphic more or less pleasant depending on your ability.
                  • DanielD Offline
                    Daniel
                    "plans and sections must always show at least a door and a window for every room even if there is no window or door in the point of the cut."
                    That's news to me. In all my years (decades, now) of architectural drawing, I've never heard that rule. I've never drawn a section through something that the section line didn't pass through; Doing otherwise would be confusing. I have, however, jogged the section line. Unless unavoidable, I tend to miss on purpose interior doors - I'll have separate door type and door detail drawings anyway. At the right scale and the right amount of detail, sections can be very real (well, as real as a drawing can be). If a person models something complete enough to derive their section from it, more power to 'em; why recreate something twice? Any way someone can save time and effort by incorporating SU into their work flow is a plus.
                    My avatar is an anachronism.
                    • massimoM Offline
                      massimo Moderator
                      Yes that is what I meant. Most of the time you can not work with straight section planes since you have to place the cuts on openings.
                      At the right scale and the right amount of detail... If a person models something complete enough to derive their section from it, more power to 'em; why recreate something twice?
                      This is indeed the problem. Look at ccaponigro's plans for example. He probably modeled the windows very well and quite detailed. The result is that they seem walls at that scale. Also, for example, indicating the axes of openings/glass panels really would help to understand.
                      I still think that 2d drawings (plans & sections basically) and 3d representations should tell different stories and require different approaches. An example: as you surely know there are several "conventions" to represent the stairs in plans. Just to name one: the steps can not end against a wall. That's mainly because you have to tell to the viewer how he will move into the building. Another one: often is useful in plans to indicate with dashed lines what is above the section cut or under the floor. I could go on forever.
                      You simply can't do those things just by cutting a 3d model.
                      Maybe I indeed have an "old way of thinking" like ccaponigro said, but after all I grew up with a pencil and not a mouse in my hand. πŸ˜‰
                        ccaponigro
                        First things first. I am enjoying this thread and the friendly and constructive discourse. The first plans where more for presentation and are in their infancy. Trust me the construction document version would be much cleaner with no shadows etc. And I'm working on things like line weight. I am also working on the sections. My only goal here is to dismiss the idea that you can't have offset sections.
                        As a matter of fact plan views are in fact horizontal sections and have always been. I too held a pencil and am a classically trained draftsman.
                        Anyway it's quite simple you create two sections in SU import to layout, clip and align and bingo. If you look at the second floor plan I used a similar technic to keep the lower roofs from being cut. I simply used a section cut higher hide what I didn't want and placed it over the second floor plan (horizontal section).
                        PS add to wish list backside clipping.
                        section with offset
                        cfcaia.com
                        • pbacotP Offline
                          Yes with enough information the 3d model can generate orthograhic images as needed. Rendered sections and elevations actually can be quite informative for the feel of a space, if not the details for construction. I find that plans are more symbolic than representational and still find 2d approach is the straighter path to a finished product. Sections are similar for me, but mostly because I don't usually complete the model to show enough detail. I sometimes use the model cut image (dwg) to begin drawing the section.
                          • RichardR Offline
                            Richard
                            I think you hit it on the head!!!! "construction document version would be much cleaner with no shadows". So let me get this right? For the construction guys (who read plans every day) you will make the plans clearer. But for the buyer (who rarely reads a plan) you are going to make the plan less legible? Hmmm!
                            I said this before, it is only those new too these tools adapting their use to this style of presentation. If you ever correspond with a high end architectural publisher their guidelines will clearly state that all plans must be clear B&W linework with no shadows - why? For clear legibility.
                            Do some searching around the internet, you will find 3D or shadowed plans used "only" by the very low end of the market, with the exception of where in print material the plan might occur on the same page as full colour renders or photographs, and even in this instance it will be for sales, not in the demonstration of the design. AND even if presented this way they the shadows will be added via illustrator so as to have far better softness control. Big Heavy shadows and colour visually reduce room size, this is the VERY last thing a marketeer wants!
                            Also shadows (not so much colour) tend to reduce the viewers ability to recognise rationalisation of the planning (alignment and justification of doors, windows and walls) that the architect has achieved to create harmony and calm rather than chaos and discourse. The reader will unconsciously pick this up in the simplicity or READ! Without it the reader is left hunting. The result is that the reader is less appreciative of these attributes.
                            • RichardR Offline
                              Richard
                              Try Fog!
                              • 2 / 2
