๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[REQ] Plugin to Select Area and Remove Rest of Model
12 Posts 7 Posters 575 Views 7 Watching
    slinggg
    Hi All,
    I've been a member of this forum for a long time, but this is my first post.
    I've been looking for a plugin that can select an area in a model (via geometry such as a cube) and delete anything else outside the geometry/boundary. The reason being I have a huge landscape model of a city but I want to zoom into a certain area and delete the rest of the model as the file is too huge. The entire model is really huge with lots of layers and blocks.
    The closest thing I could find was Zorro but even this didnt work as expected. And I had to do a few section lines to delete the rest of the model.
    Any plugins available that does this? Or anyone keen on developing a plugin with this idea?
      Krisidious
      With native tools you can accomplish this...
      Make your cube a component and then right click and save as. This will give you a sketchup file of just your cube.
      By: Kristoff Rand
        slinggg
        Thanks for your reply! But unless I misunderstood you, I don't think you got what I meant. Sorry, maybe I didn't phrase my question properly. I've attached an image below to better explain what I was trying to say.
        http://i62.tinypic.com/30v0x8x.jpg
        I was hoping to find a plugin that deletes everything outside the box in RED, and leaves whatever is inside the box. This is almost like several section cuts that deletes everything behind it - doesn't matter if the model has groups/components/etc etc, the plugin would automate this for you and delete everything outside the box.
        Is there such a plugin?
        Thanks for your time!
          Edit;Wrote this as you posted, but will post anyway.
          Kris that won't work if your "cube" in intersecting a group. The terrain for example may be one group and your selection cube won't cut through it.
          You could select all then use shift to deselect a section then hit delete, but again that doesn't work if you have a group extending outside the selection.
          Ideally you want Zorro to use the selection fence as a cutting plane. Would be a very handy tool.
            slinggg
            Oh and I tried using the native tools such as intersect with model, or plugins like zorro2, etc etc. But its just too tedious. I was hoping there was a plugin that would automate it with just the click of a button.
              rv1974
              architect tools-> crop selection to the boundary
              2nd option:
              slice model at section (4 times)
                Krisidious
                You could explode said groups and intersect with a cube. or bomb all of it then select what you want to take out. Be interesting if someone can make something to do that.
                By: Kristoff Rand
                  slinggg
                  Box,
                  [highlight=#ffffbf:2tbwvd69]"Ideally you want Zorro to use the selection fence as a cutting plane. Would be a very handy tool."[/highlight:2tbwvd69]
                  I couldn't have described it better. With all the groups and components and layers, any native tools or existing plugins just doesn't do it. Even zorro2 when I cut through the model leaves some elements behind, not sure why.
                  rv1974,
                  Thank you for your suggestions I will definitely look into it ๐Ÿ˜„
                    srx
                    try su4you slice plugin x4. http://sketchucation.com/pluginstore?pln=s4u_Slice
                    www.saurus.rs
                      rv1974
                      @slinggg said:
                      Box,
                      [highlight=#ffffbf:zeo9zqn7]"Ideally you want Zorro to use the selection fence as a cutting plane. Would be a very handy tool."[/highlight:zeo9zqn7]
                      rv1974,
                      I'd prefer the 2nd one ('slice model at section' ruby),- it's rock-solid in 99%
                        sdmitch
                        @slinggg said:
                        Hi All,
                        Don't think you need a plugin. Just select Top View, use the Selection Tool to select the area you want to keep, paste and execute this one liner in the Ruby Console
                        Sketchup.active_model.selection.toggle(Sketchup.active_model.active_entities.to_a)
                        This will reverse the selection so that everything outside the area to keep is selected and delete.
                        http://sdmitch.blogspot.com/
                          driven
                          It won't drill down through all the layers, groups, components...
                          If used with 'Outliner' and a 4 walled locked guide group, it certainly speeds up a manual split...
