    That plugin for adding elevation data....?
    22 Posts 8 Posters 2.8k Views 8 Watching
    • G
      glro
      @utiler said:
      Thanks fellas, as you can see below in this case they were random points on a site so not bounded my a perimeter line.
      Quite often I get spot levels given to me on a hardcopy of a plan so I want a simple way to turn elevation data into a reasonable terrain mesh. 👍
      so maybe you shouldn't focus on the perimeter; instead, build a set of 3d points (boundaries AND inside points)
      run TIG-points cloud triangulation
      http://sketchucation.com/forums/viewtopic.php?t=34232
      i am not sure about the result with as few points as in your example
      • utilerU
        utiler
        Thanks glro, that's what I've done.
        Just Curious...
        • 2 / 2
