    SketchyPhysics 3.3 (Unofficial Release)
    43 Posts 17 Posters 28.6k Views 17 Watching
      Anton_S
      @werner_hundt said:
      What great news, thank you so much for the update, Chris!
      Just one issue: Exporting a Sketchy Replay animation does not seem to work (see screenshot).
      Any idea how to resolve this? Many thanks & greetings from Cologne!
      Thanks for reporting! This will be fixed in the next update. Meantime the export animation feature works in SU2013 and below only.
      • W Offline
        Werner_Hundt
        Thanks for the swift reply, Anton!
        • F Offline
          faust07
          Mr.K. has posted working solutions for camera recording and Sketchy Replay in this forum. Maybe you can integrate them in to your improved version of SP. Thank you for bringing Sketchy Physics back to life! πŸ‘
            Anton_S
            No probs! Already fixed it. Will see in next update πŸ˜„
            Great! I found the post: http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=36029%26amp;p=341925#p317654
            Will investigate
              Mister K
              Oh that old mod I made... wouldn't use it as more then a reference point(i.e. which SP parts govern recordings), but what I made was all one shot working in very specific conditions code.
                PituPhysics
                This amazing!!!!! Thanks Anton. Regrettable it does not work Mr.K. mouse script. But it is super that extension.
                I had almost forgotten this plugin....
                Thank you again! 😍
                • Z Offline
                  ZoltanSpin
                  Hello,
                  I am using Sketchup 14.1.1282 and Windows 8, all 64bits.
                  I guess I'm supposed to download/extract into Google/Google Sketchup 8/ plugins and then find there :
                  Sketchyphysics (directory)
                  SketchyPhysics.rb (file)
                  and... just launch Sketchup ?
                  What else if SU doesn't see Sketchyphysics ?
                  Maybe I missed something ?
                  Thank you all for your help, and Anton for his labor.
                  Zoltan
                    Anton_S
                    You say you have SU 2014, but posted in SU8 plugins folder. SU2014 has its ow plugins folder: C:\Users\UserName\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                    Keep in mind this release works on Windows only and has some bugs that I created while rewriting the code. Next release will be better.
                      tallbridgeguy
                      Hi Anton, great stuff. Any chance you can enhance the output so that it can be rendered in a program like Kerkythea or Thea or .....
                      I had a long work around to get it into to Kerkythea but it was a pain to do long animations.
                      Here is a quick render from Kerkythea using SKPH.
                      s
                      Nielsen
                      http://www.tallbridgeguy.com/
                        Anton_S
                        I'll look into, but can't promise anything.
                          ArturM
                          @anton_s said:
                          I need some people to test this on Mac OS X.
                          Hi, I would like to test on OSX.
                          Downloaded plugin, and copied to:
                          /Users/arturmaciag/Library/Application Support/SketchUp 2013/SketchUp/Plugins/
                          and
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/
                          In Sketchup 2013 after start:
                          Error Loading File /Users/arturmaciag/Library/Application Support/SketchUp 2013/SketchUp/Plugins/SketchyPhysics/main.rb
                          no such file to load -- /Users/arturmaciag/Library/Application Support/SketchUp 2013/SketchUp/Plugins/SketchyPhysics/lib/dl
                          Error Loading File SketchyPhysics.rb
                          Ruby console is empty.
                          In Sketchup 2014 Make after start:
                          Error Loading File /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb
                          Error; #<RuntimeError; An error occurred while trying to load Ruby FFI!
                          cannot load such file -- /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/2.0/ffi_c.so
                          /Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb;45;in `require'
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb;7;in `<top (required)>'>
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb;10;in `rescue in <top (required)>'
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb;6;in `<top (required)>'
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/newton.rb;8;in `<top (required)>'
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb;23;in `<top (required)>'
                          /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
                          /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb;217;in `register_extension'
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb;217;in `<module;MSketchyPhysics3>'
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb;199;in `<top (required)>'
                          in Ruby console:
                          (eval);1; warning; already initialized constant Traductor;;SU_MAJOR_VERSION
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;40; warning; previous definition of SU_MAJOR_VERSION was here
                          (eval);1; warning; already initialized constant Traductor;;RUN_ON_MAC
                          /Users/arturmaciag/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb;39; warning; previous definition of RUN_ON_MAC was here
                          MacBookPro 2013, OSX Yosemite (developer preview (i have also 10.9 Maverick on another machine - can test if that helps)).
                            Anton_S
                            Thank you
                              RobiBue
                              Hi, I'm on Win7 and have SketchUp 14 (free). I downloaded the SketchyPhysics_3.3.0.zip file, installed the files in C:\Users*UserName\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins* and can't get it to work 😞
                              One reason - I think - is that I have no "Plugins" menu:
                              https://upload.wikimedia.org/wikipedia/commons/6/67/SketchUp_14_menu.jpg
                              but the main reason stems from the following Load Errors:
                              [pre:38j7kzib]Error Loading File C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb
                              Error: #<RuntimeError: An error occurred while trying to load Ruby FFI!
                              5: Access is denied. - C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/2.0/ffi_c.so
                              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                              C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:7:in <top (required)>'> C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:10:in rescue in <top (required)>'
                              C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/ffi.rb:6:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/newton.rb:8:in <top (required)>'
                              C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/main.rb:23:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:217:in register_extension'
                              C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:217:in <module:MSketchyPhysics3>' C:/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics.rb:199:in <top (required)>'[/pre:38j7kzib]
                              can anybody shed some light on this?
                              • F Offline
                                Fred_Flintstones
                                Seems awkward that you’d start trying to update SP when you were working on a full rewrite…You must have hit a snag (or got bored). Tho I do see how working directly with SP would help, so no complaining here…But you should have posted you were going to do this on the other thread πŸ˜‰
                                  Anton_S
                                  New update will come today, and well see if it works. Sorry for inconvenience.
                                    RobiBue
                                    No inconvenience at all πŸ˜„ really glad that SP is being worked on for the newer SU versions. 😍
                                    Thank you.
                                      Anton_S
                                      @RobiBlue According to your log, you have your name as 'UserName' but you should change it to your actual name. If you install SU2014 this path should be automatically created. SU2014 plugins are located in %appdata%
                                        RobiBue
                                        @Anton_S yeah, I changed the name when I posted the log. Assume that the UserName is correct.
                                        I just realized the following entries in the log:
                                        5; Access is denied.   - C;/Users/UserName/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SketchyPhysics/lib/2.0/ffi_c.so
                                        and therein lied the problem 😞 Norton AV has some weird "insight WS.Reputation.1" score, which quarantines files it thinks are not safe because not many users have reported it as safe, or the developer didn't submit it to their safe-list https://submit.symantec.com/dispute/insight/ which I have done now.
                                        Sometimes these AV are a PITA but more than that, they save one from a lot of trouble πŸ˜‰
                                        so far I got SP3.3 working now. πŸ˜„
                                        Thank you!
                                          Anton_S
                                          Very well, although you might want to transfer to SP3.4 : http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=58936
                                          • 2 / 3
