    SU 2014 Validtiy Check issues
    16 Posts 5 Posters 1.7k Views 5 Watching
    • T
      tomot
      @adamb said:
      tomot, its telling you what the problem is.
      Can you not locate the invalid characters you have in the layer name and rename it?
      Adam
      That's precisely what I have been struggling with. Doing a search for CLayer in the ruby code turns up nothing. (175) I thought, refers to a line number, but it is not a line number issue. I'm wondering if these validity check statements are part of some undocumented API reference?
      my plugins
      tomot
      • tt_suT
        tt_su
        Adam
        CLayer is the internal C++ class name in SketchUp. 175 would be the ID number of the layer. The specifics of these messages are for debugging by us. For API developers they can give clues - in this case it would mean looking at code that deal with layers. For users it's very little use - except report to developers.
        The Validity Check is not a API feature - it's a SketchUp core feature that is performed every time the model is saved.
        Does this happen in any model? Or specific model?
        You say it's after the use of one or more extensions. Have you pinpointed which ones? Which actions?
        The message says the layer name is invalid - so a good place to look would be any code that sets the layer name. All though, the API shouldn't allow invalid names to be entered. There is also a chance this could be as a result of using an old corrupt model - such as importing a component with an invalid layer.
        Do you have a sample model - before the layer name is fixed?
        • Dan RathbunD
          Dan Rathbun
          I remember that the layer name of 0 was changed from language localized names to "Layer0" for all language editions at some point. (We would think the validity check would fix this, in newer SketchUp versions.)
          Perhaps unicode characters are causing issues in layer names ?
          I'm not here much anymore.
          • tt_suT
            tt_su
            True, could be a result of that bug.
            Also very likely, I haven't checked the source code though.
            Another possibility that there are some unexpected byte sequences, true.
            • Chris FullmerC
              Here is a little snippet that will recreate the error.
              m = Sketchup.active_model m.start_operation("painful", true) ls=m.layers 500.times do |i| ls.add("" << i) end m.commit_operation
              That creates 500 layers with various UTF8 characters. One of them is invalid, I'm not sure which. But if you run that snippet, then run the Fix Model, it will pop up that error.
              Point is, it is very possible to add characters via Ruby that SketchUp considers invalid and does not reject, but will notice them and fix them in a validity test.
              • Chris FullmerC
                Hmm, looking again though, I don't think I recreated your issue. I managed to create a validity error that could not be fixed, while yours was fixable. So maybe that is not the exact problem 😞
                • tt_suT
                  tt_su
                  Oh great - now we got two bugs... thanks Chris...
                  • Dan RathbunD
                    Dan Rathbun
                    Look it's "Grumpy Cat" !
                    • Dan RathbunD
                      Dan Rathbun
                      Yea...
                      ... the add layer method allows, but should not :
                      • control characters 00h (0dec) thru 19h (31dec)
                      • zero width characters \u2000 thru \u200F
                      • perhaps any of the many punctuation characters
                      • perhaps replacement characters \uFFFC and \uFFFD
                      It ( add layer,) also should not allow 20h or A0h space as the first character (IMHO).
                      Validity check could replace them with an underscore.
                      And what about bracket characters, should they be allowed ?
                      • T
                        tomot
                        I'm wondering if the following code I'm using might be the cause?
                              layers=model.layers
                              layers.add (@frame)
                              activelayer=model.active_layer=layers[@frame]
                        #code that places stuff on layer frame
                        #goes here
                        #at the end of this routine I reset layer
                        # Reset layer back to default layer [0]
                               layers = model.layers
                               activelayer = model.active_layer=layers[0]
                        my plugins
                        tomot
