    Parametric modeling, anyone?
    45 Posts 14 Posters 4.6k Views 14 Watching
    • N Offline
      numerobis
      πŸ’š
      • jolranJ Offline
        jolran
        Hi Tom.
        Regarding getting a better user experience than the Grasshopper - Rhino interaction, it might be difficult 😒
        I'm working a bit with that right now, and it's quite disturbing how entities get's lost sporadically after edits. So referencing existing Sketchup Geometry is not a piece of cake.
        I'm guessing this is due to Sketchup being a "meshmodeler" and Sketchup has to create new faces all the time to fill in geometry. (Try creating a cylinder and rotate the top around center you will see faces triangulate. A reference to a face on that surface will get lost)
        Using object id's, caching the selection, or using attributes is all the same....
        • tt_suT Offline
          tt_su
          You could generate the mesh triangulated while you do live deformation.
          And you might have better luck with manipulating the vertices instead - using Entities.transform_by_vectors. (That's what I'm doing with SUbD: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57480)
          • jolranJ Offline
            jolran
            That would generate new faces, you mean. ? Getting a nice deformation result is not what I'm talking about.
            We might be dependent on information gathered from a particular face further in the node-chain. Like planes and stuff..
            This must go hand in hand with user doing standard modeling tools, which is out of reach of the plugin, normally.
            I did noticed though, getting information from vertices is more predictable.
            And edgeloops. All in all collecting data from containers is safer.
            It might be a workaround using vertices to collect data for a face, but not as straightforward.
            It involves doing more lookups than should be necissary.
            Subd:
            Ah, nice! So CEXT is doing stuff externaly then ? πŸ˜„
            • tt_suT Offline
              tt_su
              Right. In SUbD I store all data in attributes in the definition. Currently, when the mesh is subdivided the control mesh is recreated entirely in attributes - even nested attributes. At the moment each limit-mesh entity has a unique ID that reference the ID of the control mesh so I can look up control mesh data. (I think that if a face is triangulated by autofold each new face will get a copy of the attributes.)
              I do wish we could have a more generic way to create parametric tools in SketchUp though. A framework that could be used to kick start new creations easily without everyone reinventing the low level stuff all the time. But generic high performance frameworks are challenging to get right.
              @jolran said:
              Ah, nice! So CEXT is doing stuff externally then ? πŸ˜„
              CEXT in that last screenshot just reference the Ruby C++ Extension that does the calculations. I'm not sure if you refer to that as "external"..?
              • jolranJ Offline
                jolran
                Sounds sofisticated. This gives me some ideas, thanks.
                Yeah, that would be ultimate. Have you started yet ? πŸ˜„
                Yes I was refering to a C-extension.
                • tt_suT Offline
                  tt_su
                  haha!
                  Well, one first need to understand the problem. Working on SUbD gives me some insight to that. Keeping an eye on this thread is also a good source of information.
                  These types of extensions haven't been so in a great extent for SketchUp. So finding a good design pattern isn't easy. Will need some experimentation and trials and errors.
                  I first started using C extensions for Vertex Tools - in order to implement the soft selection feature with any reasonable performance. Scripted languages are usually slow for calculations - Ruby especially so.
                  • jolranJ Offline
                    jolran
                    Yeah I have the impression Ruby works fine for a while, but when you hit a wall it slows down exponentionally..
                    I'm looking into the C-stuff. Got some help now..
                    • I Offline
                      ivreich
                      Have to say, this would be a dream come true for me. I've also been asking for something like this for quite a while, particularly for doing complex panelisation operations.
                      @jolran - I remember you telling me once that you were working on something off the back of hatchfaces; is that the propject that you are referring to in this topic? I can't seem to find any link to it though...Care to share?? πŸ˜‰
                      Best of luck to you all!!
                      Joel
                      • jolranJ Offline
                        jolran
                        Hi Joel.
                        No, this is a different thing than the one I was working on back then.
                        There are no release yet, and no date set.
                        You can PM me for specific questions/suggestions, should you wish to πŸ˜„
                        • 2 / 3
