    Exporting SketchUp groundplanes to use in Photoshop
    Scheduled Pinned Locked Moved Post Processing
    15 Posts 10 Posters 13.6k Views 10 Watching
    • EdsonE Offline
      Edson
      great tut, chris! thanks for sharing.
      http://www.mahfuz.arq.br
      • pbacotP Offline
        Chris,
        Thanks for this. Great tutorial! A couple of questions:
        You say at Image #7: "This is ... when I lay my groundplane into the model." I thought by then we were looking at Photoshop.
        Can you say a few words on line overlay in PS. Output resolution, AA, cleanup and blending method. Every time I do this I seem to reinvent it and sometimes get artifacts, struggle with resolution etc.
        Wouldn't it be nice if we could just export from SU with no background and not have to erase everything in PS?
        Why don't you use Match Photo for this, even just for the purposes of alignment (and use the exports the same way?)
        Peter
        • Chris FullmerC Offline
          Thanks Peter!
          • Yup, you're right, at image 7 I'm in photoshop and I misspoke. That should not say "model"
          • Hard to say just a few words about all those topics. But in a model like this, I'll often export the color layer and the linework layer a few times at varying resolutions. Sometimes I want the lines to be thick and a little chunky in my photoshop image so I'll export them at screen resolution from SU. Typically when I do screen resolution, I'll turn AA (anti-aliasing) on when I export it so the lines are thick, but also fairly smooth. I'll also export linework in the 6000x 80000 pixel range so I get VERY fine lines, which I typically prefer. But sometimes they are just too fine and don't stand out. In the end on this one I used linework exported at screen resolution and I smoothly erased it (big fat brush, 30% opacity, smooth edge on the brush) towards the back of the linework where it was converging into a black mess.
          • For blending on this, I set the SketchUp color layer to "soft light" and then played around with the Hue/Brightness (ctrl-L) and the olor balance (ctrl-b) to try and get it softer and into the same tone range as my example photo. I think I even had to do a "replace color" to control the yellower bricks separately.
          • Not sure what to say about artifacts and such though. I guess I'd have to see an example of what you mean.
          • It would be nice if SU exported with transparent backgrounds (I think it does on a Mac?). Seems like Thomthom might have a plugin that helps with that as well? But typically erasing it in PS isn't that big of a problem for me. Maybe I use simpler models than you πŸ˜„
          • I don't use photomatch very much because I'm horrible at setting it up. That's about the only reason. I probably just need to go through the tutorials on it again. I do often have photos without vanishing lines though, so it wouldn't help me there, so I like to be able to figure it out well enough on my own.
          ok, that's it. Thanks!
          • soloS Offline
            Great stuff, need to bookmark this tip. Thanks.
            • pbacotP Offline
              Chris,
              Thanks for the notes! I'll refer back to this post next time.
               Peter
              • W Offline
                wyatt
                This is great, Chris. Thanks for sharing. Missed you at Basecamp, but at least you were getting some good things done in the meantime.
                • ElibjrE Offline
                  Elibjr
                  Thanks Chris! Love your plugins btw. How did you pick the colors for the pattern? Was the first image just used as a reference for your final or was that used to get your colors correct? This is seamless by the way. Really nice work. Thanks for the tip.
                    The first image was given to me as a reference of what the client was looking for (or maybe it was just what we wanted to present the client?). But either way, I was given that image as a reference to try to match approximately.
                      Couper90
                      Chris, may I ask where you got your shrub images? I am looking for some good ones and find them hard to come by! Any advice, help or direction would be greatly appreciated!
                        I cut most of those out by hand. The rest were cut out by other people in the office by hand.
                        I would do a photoshop tutorial for people in the office, and one of the final projects to work on would be to cut out a person or a shrub. Then when they were done, we'd have another 20 cutouts for our library πŸ˜„
                        • alexjoA Offline
                          alexjo
                          Thanks, that was very helpful
                          ...........Though does not look easy at all.
