    How does material color multiplication works?
    7 Posts 4 Posters 1.7k Views 4 Watching
    • fuzzybroF
      fuzzybro
      When material has a texture and color the result is really weird. It is not just texture and color multiplication as commonly seen in computer graphics. How does it work in Sketchup so I can reproduce it in other renderer?
      OctaneRender for SketchUp Overview and Demo Version
      Latest updates, tutorials and artwork
      facebook.com/octane4sketchup
      • tt_suT
        tt_su
        Material color multiplication? What do you mean?
          Aerilius
          SketchUp's UI has two ways to modify the color of a textured material: You can color-shift the texture image (it still preserves color differences, but with an emphasis at a different Sketchup::Color)
          and you can colorize the texture image (boolean, preserves only the brightness, sets the hue and saturation to a specific color).
          The API does not differentiate between the two, so when you read color from a color-shifted material and set the same value again, it will be not just be color-shifted but colorized. It's better not to use these properties in Ruby scripts.
          You can however "bake" the color-shift/colorization into a texture when exporting textures with the Sketchup::TextureWriter.
          • tt_suT
            tt_su
            Ah! That color adjustment features.
            The Colorize function just converts it to a grayscale and maps that to the selected color.
            I'll look into the color shifting. I have always thought it was a blend going on - but I'll see if I can dig into the code and see what actually happens.
            • tt_suT
              tt_su
              It does a HSL shift.
              • nikusknxN
                nikusknx
                If we have the original rgb texture, and the hls or rgb color of the texture, what is the opertion to do to each pixel to create the new material with color like the Sketchup texture writer???
                thanks
                • tt_suT
                  tt_su
                  I would need the deltas, and know whether the material is HSL shifted or tinted - something the Ruby API doesn't expose right now. But we have an issue open to address that.
