    Any smokers here? Wanna quit?
    822 Posts 42 Posters 307.7k Views 42 Watching
    • olisheaO Offline
      olishea
      So what's the deal with cartomisers?
      I remember Biebel and others discussing them...the reason I ask is because the EVOD coils are becoming quite terrible.
      I like to use the EVOD out and about but the coils only last a couple of days now, some just taste burnt straight out the box.
      So do I need to get pre punched cartomisers? Are they essentially a tube with a dual-coil inside?
      What's the difference between pre-punched and regular? I know one has a ready-made hole but what are the implications of buying one over the other?
      Getting tired of "clearomisers"! haha
      oli
      • F Offline
        Futurepast
        This is the one I use (2.5 ohm)....
        http://www.myvaporstore.com/SMOKTech_510_Dual_Coil_Tank_Cartomizer_5_Pack_p/510dctc.htm
        On my ProVari they last about a week to a week and a half at a power setting of 4. But with this setup, if they get dropped they leak. But, I find I can clean the base, threads, and retighten everything and keep going. Just a hassle at times lol
        • olisheaO Offline
          olishea
          thanks. i'm just looking for a good alternative to the EVOD for out and about. Kayfun still working like a charm, now I've found this very convenient filling valve:
          http://www.cloud9vaping.co.uk/epages/yxve46fvrnud.sf/en_GB/?ObjectPath=/Shops/yxve46fvrnud/Products/MF-K-GR
          oli
          • F Offline
            Futurepast
            Well I think I'm going to mix my own juice 🎉
            Anyone seen this site? http://e-liquid-recipes.com/
            I found these suppliers here in the states:
            http://shop.perfumersapprentice.com
            http://www.ecigexpress.com
            • olisheaO Offline
              olishea
              Recipe site looks good. Only thing you have to work out is the concentration of nicotine. For example, I use Neat 54 nicotine liquid which is 54mg....so if someone is using say 100mg nicotine for example you'll just have to work that out and adjust your recipe.
              My nicotine is PG based, by choice, so that also goes into your calculation for PG/VG ratio. Some people's recipes use 100mg nicotine with a 50/50 base so again, your values would change slightly.
              Here are my recipes. My final nicotine level is 12mg and I'm using Neat 54 PG based nicotine (easier to syringe).
              Before I mix anything I make some AG (Aqueous Glycerol) which is 85% VG and 15% De-ionised water. I make a 100ml batch of this every now and then and just keep it aside for when I need to mix. So basically 85ml VG to 15ml De-ionised water. So wherever you see AG, this is what I mean! It helps to make the liquid less viscous.
              All figures are in ml (millilitres).
              All flavourings are PG based.
              All nicotine is PG based.
              If you want to add more flavouring, you just take that away from the PG value. So if you want 2ml more flavouring, just put 2ml less PG in. This will keep the ratios in check. If you want more nicotine, again, just add more nicotine and remove this value from your PG. Say for example you want to add 5ml more nicotine, just take 5ml of PG away. Your AG level should always stay the same (unless you use VG based flavouring or nicotine).
              **12mg Nicotine - 60/40 PG/VG - 10% Flavour - 50ml batch - My special mix
              11.1 Nicotine
              13.9 PG
              20 AG
              2 blackberry flavouring
              1.5 cantaloupe flavouring
              1.5 peach flavouring
              12mg Nicotine - 60/40 PG/VG - 10% Flavour - 50ml batch - Juicy Fruit (or whatever flavour you like)
              11.1 Nicotine
              13.9 PG
              20 AG
              5 Juicy Fruit Flavouring......change this to whatever flavouring you like.
              12mg Nicotine - 60/40 PG/VG - 15% Flavour - 50ml batch
              11.1 Nicotine
              11.4 PG
              20 AG
              7.5 flavouring of your choice**
              oli
              • F Offline
                Futurepast
                thanks for the info! 😄
                • olisheaO Offline
                  olishea
                  No worries. Mixing your own is easy.
                  I gave up using my EVOD for out and about. Kanger have changed the coils and as a result they are very inconsistent, don't last as long and are costing too much to replace.
                  Anyway, after not using my Kayfun for a month or so, I recoiled it and was blown away!! I see why I fell in love with it; it's just so consistent and loads of creamy vapour. The Kayfun Version 4 is coming out soon too, wonder what that will be like. My Kayfun 3.1 has been discontinued now, I guess it's because the fill-up valve is easy to block; I just unscrew mine and fill up from the top, so much easier and quicker.
                  oli
                    kwistenbiebel
                    I always fill my Kayfuns (clones) from the top. It's indeed as easy as filling a clearomiser. I take it you are familiar with the 'hold your finger on the airhole' trick to avoid leaking.
                    I totally get what you mean with the Evods, I am not using them either any more, they are loud, they don't last long and eventually they either taste burnt or leak. I only like them for their stealthy form factor.
                    My daily stealth and bring-to-work gear consists of Iclear16's. They are fabulous when you know how to work them. It's a warm tasty little vape with not too much vapor (stealth) and a good throat hit. Trick is to fill regular so you're always more than half filled and use the lowest voltage you can. Then they last a really long time.
                    As to Kayfuns and at-home-vape-gear in general , Kayfuns are good.... however I am totally in love with the Taifun GT at this stage. My Kayfuns are in the cupboard as I see myself taking the Taifun over anything else 😄
                    As to cartomizers (your earlier post), I suggest only going for double punched cartos.
                    Boge LR really are the best performing ones. In general, cartos give a very consistent vape, no leaking. The draw is tight because the juice is typically soaked in filler material, so you really need the double punched or slotted ones. The flavour is very 'typical', a bit muted but fine. It is considered the old fashioned way of vaping, however a lot of people still consider it as the best all day vape with the least hassle.
                    • olisheaO Offline
                      olishea
                      Yeah I always put thumb over the airhole but it still floods a bit. Do you have to hold it upside down when you screw it back up or something? Only floods a tiny bit but it's still wasted E-liquid.
                      I found a place that does really cheap E-Liquid in the UK...at bulk and wholesale prices. I ordered 200ml of Vimto flavour (which is AMAZING), should be here on tuesday or wednesday.
                      You can buy liquid up to 25 litres in capacity!! It basically works out to be nearly 10 times cheaper than buying premixed 10ml bottles. Basically it works out to be 50 pence per bottle instead of £5 and it gets cheaper the more you buy.
                      I do like mixing my own liquids but the flavourings are expensive for what they are. The liquid is so cheap from this website that it negates the money saved by mixing my own. So hopefully I've found a good place to get cheap liquid in nice flavours.
                      http://bluestar-eliquid.co.uk
                      oli
                        kwistenbiebel
                        Hi Oli,
                        To fill the Kayfun from the top, I always cover the airhole while filling.
                        When screwing on the cap, only screw it on a couple of threads and then turn the kayfun upside down. Once the liquid has settled down, you can release your thumb from the airhole and screw the top cap fully tight. It never leaks for me that way.
                        • olisheaO Offline
                          olishea
                          Hi Oli,
                          Thanks Chris! I was holding it upside down but not for long enough. I was trying to do it as quick as possible.
                          Do you use a stainless wick with your Taifun? I was looking into buying one but I'm gonna wait to see what the Kayfun V4 looks like.
                          Hope everyone is getting on well with vaping!
                          oli
                          • soloS Offline
                            Just switched to the Aspire nautilus tank and atomizers, what an amazing vape experience, love the adjustable airflow.
                            I recommend highly.
                            • olisheaO Offline
                              olishea
                              Looks great Pete. My vape shop has started selling them but I wanted to know what they were like first.
                              Which coil do you use? 1.6 or 1.8?
                              How long are the coils lasting compared to your Vivi?
                              My mother got the Kanger Protank 3 which now has dual coils....I have to say the flavour is much improved and it looks like the coils are lasting longer too. You can also buy an adjustable airflow ring for the Protank 3 which pretty much turns it into the Aerotank.
                              http://www.cloud9vaping.co.uk/epages/yxve46fvrnud.sf/en_GB/?ObjectPath=/Shops/yxve46fvrnud/Products/KN-PRO3
                              Kanger also do the Aerotank which has adjustable airflow as standard:
                              http://www.cloud9vaping.co.uk/epages/yxve46fvrnud.sf/en_GB/?ObjectPath=/Shops/yxve46fvrnud/Products/KN-AERO
                              It's still nowhere near as nice as my kayfun though! 😄
                              oli
                              • soloS Offline
                                I am using the 1.8 @ 4.2
                                It has been a week today and still on same coil, still strong.
                                • quimQ Offline
                                  quim
                                  i did it "cold Turkey" 6.5 years now
                                  WEBSITE http://www.q-prodesigns.co.za
                                  • soloS Offline
                                    Ja-nee boet, jy is n grooter man as ek. 👍 😄
                                    • olisheaO Offline
                                      olishea
                                      Well done! I just can't do cold turkey haha
                                      oli
                                      • olisheaO Offline
                                        olishea
                                        Cheers, please let me know how long they last on average when you've been using it for a while. 👍
                                        The adjustable airflow should help the coils last longer 👍
                                        oli
                                        • GarethG Offline
                                          Gareth
                                          Pete,
                                          Are you using the Nautillus on your Provari..?
                                          • soloS Offline
                                            @gareth said:
                                            Pete,
                                            Yes I am.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 41
                                            • 42
                                            • 29 / 42
