    Sketchup to autocad
    15 Posts 7 Posters 3.3k Views 7 Watching
    • W Offline
      wwms
      An insights on some best practices for exporting those shapes?
      Here is an example of the first file I exported from what I thought was just a flat shape in sketchup. But this is what I was told came out skewed.
        Robert Lang
        I've only done minimal amounts of 3D work in AutoCAD, so I'm not sure how well SketchUp and AutoCAD get along in three dimensions. It will likely be much easier if you export a 2D view, like one of the standard views in parallel projection. And it sounds like that may be all you need.
        When you do a 2D export, you'll find lines stacked on top of each other and cut into segments in AutoCAD or Illustrator.
        Bob Lang
        • W Offline
          wwms
          What is strange to me is that I have exported some without any issue and other with many issues. But it sounds as though 2D is the way to go and probably I should learn autocad regardless.
            Robert Lang
            Just took a look at your dwg file. Don't have autoCAD here but I opened it in Illustrator and imported it into SketchUp. It appears to be a flat surface, but there is some wackiness to it. The arc has both an arc and a series of line segments next to each other. If I remove a line segment in SketchUp the face disappears, and doesn't want to come back.
            My best guess is that somehow, somewhere part of it is slightly off-axis. I would suggest redrawing the part on the ground in SketchUp and trying the export again. I can't think of any good reason to take it through Illustrator on the way to AutoCAD. When it is opened in Illustrator the curve will explode into the line segments.
            Bob Lang
              driven
              yep, that file was a little screwy...
              I just tidied up the old dxf_export.rb plugin to make sure it runs on mac and it retains, arcs and circles, if drawn flat on the ground plane...
              if you instal solidworks edrawing's app you can test them yourself, no need for illustrator...
              I'll PM a copy when I've done some more tests.
              so draw flat on ground plane [ in 2d ]
              and before export,
              top view, parallel projection, zoom extents
              export
              gives the cleanest results
                JGA
                If it is an autocad solid, I think you need to turn it into a surface before saving as an older version of DWG (r14 ?), then try to import it into SKUP. Make sure the various parts are blocks - they are imported as components into ACAD.
                Regards,
                JGA
                  driven
                  hi marina,
                  further testing showed the old plugin won't do what it should...
                  it doesn't export the ellipse, so fails even on your simple table...
                  • E Offline
                    emorgan
                    One thing i know. Dynamic blocks do not export nicely to other software. Even when you explode them. for work that is to be exported, i use designspark (free version of spaceclaim) which exports nicely to sketchup or Autodesk Fusion (also free) that has similar pushpull modeling and exports to STEP/Iges/DWG/Parasolid. Either software could easily model and ellipsoid. and both open sketchup. but dynamic blocks get mashedup a little.
                      mac1
                      table_base.dxf
                      You can also export as obj file, I used mesh lab here ,but it does not have dwg export. I also exported stl to Meshlab and imported stl back to SU ok.
                      • W Offline
                        wwms
                        Thanks. I did finally get this figured out but encountered another issue with a very simple drawing today. I drew it on what I thought was the "ground" and was told they could only see the side view. I had opened the dwg in solidworks edrawing and illustrator and it looked great in each. So what camera view is the correct view? I wish there was just a simple step-by-step with specific rules to follow. I rotated it so that I could see it in SU from the Front. Maybe I interpreted "ground" incorrectly?
                        • wilsonbuilt78W Offline
                          wilsonbuilt78
                          Hi Marina
                          I do this type of work all the time, design in sketchup and then have parts lasercut or CNC routered -I can give you a few pointers.
                          The first thing you need to know and understand is that sketchup does not create true arcs,circles elipses etc. All of these geometric entities are broken into segments. Sketchup is especially poor at exporting solid 3d models for this reason and there are very few instances where exporting a 3d is useful in other software packages especially where one intends using the model for any type of CNC cutting.
                          However I get very good results using one particular plugin for getting machines to cut stuff for me its called- Tak2hata: Create Section Drawing. Install it by searching for it with the sketchucation tools- a plugin you must install if you havent already
                          How it works is: a)you create a section through the part you want to cut b)right click on the section you have created c)create section drawing
                          This exports a 2D dxf of the section you want cut as well as skp model of the 2D section. It eliminates all kinds of problems you may experience getting goemetry or faces on the right planes and really solves a lot of headaches for me.
                          Note though: As I explained earlier- sketchup does not export true arcs or ellipses and you would therefore get very staggered unatractive arcs if you did this with the model you have uploaded. My solution is to increase the number of segments SU uses to describe an arc or elipse. This has to be done with the geometry BEFORE you extrude it.
                          Method as follows a) draw arc/ellipse b)right click on it and select [entity info] c)you are then allowed to increase the number of segments in the entity info dialog box. This will give you something which comes much closer to the geometry you really want cut.
                          Please note: after you have extruded an arc or ellipse you cannot edit the number of segments which describe it.
                          Hope this helps
                          Stephen
