    Minimize WebDialog from code?
    5 Posts 4 Posters 414 Views 4 Watching
      maricanis
      Is there some way to minimize/restore WebDialog programmatically from code?
      In my plugin, after user enter all data in the dialog and press Start, model is exported and some simulations are started. I do not close dialog, because it may be needed after calculation is finished, so it would be good that dialog is minimized while simulation is running.
      I haven't found in API appropriate function for that and no info on the forum too.
      Thanks in advance,
      Marija
        Gábor
        You can resize it, you can position it off-screen but I do not know any method for minimizing it unless you somehow manage to trigger a mouse-click on the minimize button.
          maricanis
          Thanks, it seems like good solution for now.
          Resize it to really small value (so only title bar is visible), and then when calculation is finished resize it back to original size.
          Only problem is that if I want to restore original size while calculation is running, minimize/restore button restores to small window size (and not original one).
          Other ideas are welcome too,
          Marija
          • tt_suT Offline
            tt_su
            The current API is lacking in good control over the WebDialog windows.
            Under Windows you can use the Win32API if you are familiar with the Win32 API.
              driven
              maybe I'm missing the point...
                 @dlg.set_size(100,100)
                 @dlg.set_position(100,100)
                 @dlg.set_size(1000,1000)
              can switch between 2 sizes at the same position...
