Sketchup crashes when I press SketchyPhysics' Play button.
Yes, SU7, and all versions are still available!
You can download SU7 Pro at SketchUp Home or standard version at FileHippo. -
IT WORKED!!!! Thanks for the help!
@anton_s said:
Hello Dad Zookeper,
Sketchy Physics has a bit of bugs to be fixed, and so, for now it only works good enough on SU7, poorly on SU8, and as you said, it will crash on SU2013. I love SketchyPhysics too, and await until Mr.CPhillips releases a new version with improvements and no bugs. You might wan't to stick around this forum and wait until the new release. Maybe it will be updated soon, who knows?
I keep hoping as well.
Can he be motivated with cookies or coffee or beer?
A cool trick is use SketchyPhysics "alone" inside the Plugin folder !
So just make a special "Plugin" folder for iself!
So no incompatibilities with other plugins!
Does anybody know what other plug-ins are incompatible with SP?
Hi Pilou,
How do you do this? Can SU have more than one Plugin file at the same time or do you give it a different name?
Thanks,
Tom -
did you instal SketchUp v7 or did you have it?
if so,- rename the 'Plugins' Folder by adding to it's name e.g. 'Plugins!' , then
- make a new Folder name 'Plugins' and move only Sketchy Physics files into it.
otherwise just do step 2
Thanks, John,
I'm in the middle of building a model of a pendulum clock in SU8. I do have SU7 on my machine, but if I use it, I'd have to start over from scratch. I'll try turning off all the other plugins and see if that works. All these crashes are getting to be a bore.
Tom
@twharvey said:
... but if I use it, I'd have to start over from scratch.
you can run v7 and v8 on the same mac[at the same time even], just use save as v7 or copy paste between the 2 versions.
john -
I have tried all of the above: installed SU7 with sketchyphysics plugin, saved the file in 7-format and tried to run it in 7. No other plugins installed in this version. But it crashed.
So I started to design again from scratch in 8.0, started a new file and when I start to run the simulation, it crashes. It does not happen in other projects so I guess it has something to do with the way I designed the object.
https://drive.google.com/file/d/0BzgoaQHxd3uRdnE5Z2pYR21KSDQ/edit?usp=sharing
I am trying to design a simple Torggler-door with one rod: http://torggler.co.at/main/systems.html
