    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Get MAC Address
    55 Posts 8 Posters 5.6k Views 8 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @tt_su said:
      For temporary files in SketchUp < 2014 I would write to the temp folder based on that the ENV variable gives you:
      But... the TMP/TEMP directory is in the user path, and IF the username has unicode characters, then older versions on PC have problems.
      We would need to employ tricks like in TIG's PCFIleTools.
      http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=43007%26amp;p=385472
      I'm not here much anymore.
      • tt_suT Offline
        tt_su
        On the machines I tested this on the ENV variable would return DOS 8.3 short filepaths for the temp paths - and that works for Ruby 1.8 since they call the ASCII versions of the Windows file functions that can handle that.
        That said, there's always a change that ENV variables might be altered by someone, but it has worked fine for several years.
        In theory you could use Win32 API calls under Ruby 1.8 to get short 8.3 filepaths and pass that to the Ruby File methods.
          Garry K
          @tt_su said:
          This is one of those areas where you probably would end up with code branching for the different ruby interpreters.
          Then branching it is.
                mac_addr = []
                cmd = @@windows ? 'ipconfig /all' ; 'ifconfig'
                # choose lines that have only six pairs of 2 char hex values separated by either a ; or -
                regex = Regexp.compile('(..[;-]){5}..')
                if (RUBY_VERSION[0..2] == '1.8')
                  lines = %x[#{cmd}].split("\n").grep(regex)
                  lines.each { |line| mac_addr << (line.strip[-17, 17]).upcase().gsub(/-/, ';') }
                else
                  temp_path = File.expand_path(ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'])
                  tempfile = File.join(temp_path, 'temp.txt')
                  `#{cmd} > #{tempfile}`
                  File.open(tempfile, 'r') do |file|
                    lines = file.grep(regex)
                  File.unlink(tempfile)
            Dan Rathbun
            similar:
            ipa = %x[ipconfig /all].split("\n").grep /\A\s*(Physical Address)/
            The regular expression means:
            \A start of line
            \s* one or more space characters
            and the parens group the string
            returns:
              "   Physical Address. . . . . . . . . ; XX-XX-XX-ED-C2-XX",
              "   Physical Address. . . . . . . . . ; 00-XX-XX-ED-C2-XX",
              "   Physical Address. . . . . . . . . ; XX-XX-XX-E5-20-XX",
              "   Physical Address. . . . . . . . . ; 00-00-00-00-00-00-00-E0",
            The first 2 are the Wireless:
            1. Microsoft Virtual Miniport Adapter
            2. the actual 802.11b/g/n Adaptor
            The third is the Ethernet port.
            The last 2 are virtual tunneling ports.
              Dan Rathbun
              DUh... I just stumbled upon GetMAC.exe on my Win 7 machine. (It is in the "%WINDIW%/System32" directory.)
              Ironic given the title of the topic.
              Win 7 comes with it installed.
              It is installed on XP Pro, but other editions need to install the Resource Kit or Support Tools. (They are separate installers on the install CD.)
              Documentation page: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/getmac.mspx?mfr=true
              Output looks like: %(#008080)[C:\Users\Dan>getmac]
              Physical Address    Transport Name
              XX-XX-XX-2B-E5-XX   \Device\Tcpip_{<a GUID is output here>}
              XX-XX-XX-C2-1B-96   Media disconnected
              šŸ’­
                Garry K
                A fellow in Russian has been testing this and ends up with this error when running SU 2014.
                Error: #<ArgumentError: invalid byte sequence in UTF-8>
                The line of code that is fails on is
                So the next thing we did was change the prior line to but had the same error.
                File.open(tempfile, 'r', :encoding => 'iso-8859-1') do |file|
                What is interesting and confusing is that when we ran this code from the web-console it worked
                mac_addr = []
                cmd = 'ipconfig /all'
                else
                  File.open(tempfile, 'r', ;encoding => 'iso-8859-1') do |file|
                mac_addr[1]
                  Dan Rathbun
                  Encoding::default_internal has not been set correctly in the first release of SU2014.
                  SO try:
                  File.open(tempfile, 'r', :encoding => 'iso-8859-1:utf-8') do |file|
                    Garry K
                    My mistake this does work.
                    We got our versions crossed up.
                    Thanks anyway Dan
                      Dan Rathbun
                      OH he is in Russia, so he's likely running a different codepage.
                      Get his default system Encoding:
                      Encoding::find("filesystem") >> an encoding
                      (On my machine it returns the #<Encoding:Windows-1252> object reference.)
                      or
                      Encoding::locale_charmap >> returns a name for the encoding.
                      (On my machine it returns the string "CP1252".)
                      šŸ’­
                        Garry K
                        For me it just returns an error.
                        (eval):5:in `run': uninitialized constant JF::WebConsole::Encoding
                          Garry K
                          Sorry - I see this only works in SU 2014
                            Garry K
                            I've run into issues with taking the fist or second Mac Address out of ifconfig or ipconfig /all.
                            I've changed the code to look at the entire file and then to step through it line by line and treat it as a bit of a state machine.
                            Thanks to pgarmyn and Driven I think I've got some code that will work. They both helped with files as have a handful of other people.
                            With windows I've tested files in English, French, Russian and some with VMWare set up.
                            With OSX I've just tested in English.
                            Mac Address
                            • 2 / 3
