    Get MAC Address
    55 Posts 8 Posters 7.8k Views 8 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @chris fullmer said:
      ... but if they double click on a skp model file, or double click on the SU icon, then it does not work. Are you seeing it work in both scenarios?
      NO neither.
      I see now, I either have used a pinned shortcut copy (of the desktop icon,) on the taskbar, or a copy on the StartMenu, or from a popup menu of the Desktop taskbar.
      These are all single-click ways of launching SketchUp. I usually start SU this way because the Desktop is covered up.
      I'm not here much anymore.
      • jaimedaJ Offline
        jaimeda
        I think this works in 2014 and earlier
        <span class="syntaxdefault">IO</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">popen</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"ipconfig/all >temp.txt"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">fd</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> fd</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">readlines</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">lines </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> open</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"temp.txt"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">readlines<br />puts</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">lines</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
          Garry K
          Does this code work with Mac OS.
          With windows the tempfile goes to desktop and gets discarded when finished.
          Where does the file go for Mac OS and do we have rights?
                # do this for testing on a mac
                @@windows = false
                # do this for testing on windows
                # @@windows = false
                mac_addr = []
                cmd = @@windows ? 'ipconfig /all' ; 'ifconfig'
                # choose lines that have only six pairs of 2 char hex values
                # separated by either a ; or -
                regex = Regexp.compile('(..[;-]){5}..')
                tempfile = "temp.txt"
                `#{cmd} > #{tempfile}`
                File.open(tempfile, 'r') do |file|
                  lines = file.grep(regex)
                  lines.each { |line| mac_addr << (line.strip[-17, 17]).upcase().gsub(/-/, ';') }
                File.unlink(tempfile)
                # if windows and we have more than 1 mac address
                # then use the second one otherwise use the first
                # if not windows then use the first address
                index = @@windows && mac_addr.length > 1 ? 1 ; 0
                @@mac_address = mac_addr[index]
            Dan Rathbun
            The temp file only goes to the desktop by chance that your current working directory is pointing at the desktop directory.
            WIN = RUBY_PLATFORM !~ /darwin/i OSX =( not WIN ) desktop_dir = WIN ? "#{ENV['USERPROFILE']}/Desktop" : "~/Desktop"
            Assuming that the name of the directory is not language localized, but it likely IS.
            You should not ever assume some other script has not changed the working directory.
            All older SketchUp versions attempted to set it to the user's home directory.
            SketchUp 2014 (on my machine,) has left me in "#{ENV['SystemRoot']}/System32" (why I do not know, but have asked.)
            To see what the current working directory is, use:
            Dir::getwd
            or, it's alias:
            Dir::pwd
            To temporarily change the working directory (and have it change back to whatever it was,) use the blockform of the Dir::chdir class method.
            Dir;;chdir( RUBY_PLATFORM !~ /darwin/i ? "#{ENV['USERPROFILE']}/Desktop" ; "~/Desktop" ) {
                  @@windows = false
                  # @@windows = false
                  mac_addr = []
            } # chdir block
            To test for access rights:
            File::directory?( dirname ) && File::writable?( dirname )
            See the File class for other class query methods to determine access info: executable?(), executable_real?(), readable?(), readable_real?(), writable_real?, etc.
            Be aware that path strings with unicode characters will not work well under Ruby 1.8.x on PC. (Mac OSX does not have these problems.)
              Garry K
              Thanks Dan. I should have thought about the whole issue of current working directory. This has been true since the beginning of DOS.
              I'm going to put a config folder in my own plugin folder. I can put the temp.txt file there. I can also use the folder to put user custom settings so that updates don't overwrite user settings.
              • tt_suT Offline
                tt_su
                For SketchUp versions older than SU2014 that might cause problems if the user doesn't have full permissions to the Plugins folder since Windows locks down Program Files quite tight. Ruby will in many cases not have write access.
                  Garry K
                  OK - then what do you suggest. I will need to find a location to temporarily write a file. This will be for Windows and Mac.
                  I suppose I could use one strategy for SU 2014 and another for older versions.
                  • tt_suT Offline
                    tt_su
                    For temporary files in SketchUp < 2014 I would write to the temp folder based on that the ENV variable gives you:
                    temp_path = File.expand_path(ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'])
                    For settings and persistent preferences, if you want to write that to file it will get tricky in older SketchUp. I stick with using Sketchup.write_default/read_default.
                    This is one of those areas where you probably would end up with code branching for the different ruby interpreters.
                      Dan Rathbun
                      But... the TMP/TEMP directory is in the user path, and IF the username has unicode characters, then older versions on PC have problems.
                      We would need to employ tricks like in TIG's PCFIleTools.
                      http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=43007%26amp;p=385472
                      • tt_suT Offline
                        tt_su
                        On the machines I tested this on the ENV variable would return DOS 8.3 short filepaths for the temp paths - and that works for Ruby 1.8 since they call the ASCII versions of the Windows file functions that can handle that.
                        That said, there's always a change that ENV variables might be altered by someone, but it has worked fine for several years.
                        In theory you could use Win32 API calls under Ruby 1.8 to get short 8.3 filepaths and pass that to the Ruby File methods.
                          Garry K
                          Then branching it is.
                                mac_addr = []
                                # choose lines that have only six pairs of 2 char hex values separated by either a ; or -
                                if (RUBY_VERSION[0..2] == '1.8')
                                  lines = %x[#{cmd}].split("\n").grep(regex)
                                else
                                  tempfile = File.join(temp_path, 'temp.txt')
                            Dan Rathbun
                            similar:
                            ipa = %x[ipconfig /all].split("\n").grep /\A\s*(Physical Address)/
                            The regular expression means:
                            \A start of line
                            \s* one or more space characters
                            and the parens group the string
                            returns:
                              "   Physical Address. . . . . . . . . ; XX-XX-XX-ED-C2-XX",
                              "   Physical Address. . . . . . . . . ; 00-XX-XX-ED-C2-XX",
                              "   Physical Address. . . . . . . . . ; XX-XX-XX-E5-20-XX",
                              "   Physical Address. . . . . . . . . ; 00-00-00-00-00-00-00-E0",
                            The first 2 are the Wireless:
                            1. Microsoft Virtual Miniport Adapter
                            2. the actual 802.11b/g/n Adaptor
                            The third is the Ethernet port.
                            The last 2 are virtual tunneling ports.
                              Dan Rathbun
                              DUh... I just stumbled upon GetMAC.exe on my Win 7 machine. (It is in the "%WINDIW%/System32" directory.)
                              Ironic given the title of the topic.
                              Win 7 comes with it installed.
                              It is installed on XP Pro, but other editions need to install the Resource Kit or Support Tools. (They are separate installers on the install CD.)
                              Documentation page: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/getmac.mspx?mfr=true
                              Output looks like: %(#008080)[C:\Users\Dan>getmac]
                              Physical Address    Transport Name
                              XX-XX-XX-2B-E5-XX   \Device\Tcpip_{<a GUID is output here>}
                              XX-XX-XX-C2-1B-96   Media disconnected
                                Garry K
                                A fellow in Russian has been testing this and ends up with this error when running SU 2014.
                                Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                The line of code that is fails on is
                                So the next thing we did was change the prior line to but had the same error.
                                File.open(tempfile, 'r', :encoding => 'iso-8859-1') do |file|
                                What is interesting and confusing is that when we ran this code from the web-console it worked
                                mac_addr = []
                                cmd = 'ipconfig /all'
                                else
                                  File.open(tempfile, 'r', ;encoding => 'iso-8859-1') do |file|
                                mac_addr[1]
                                  Dan Rathbun
                                  Encoding::default_internal has not been set correctly in the first release of SU2014.
                                  SO try:
                                  File.open(tempfile, 'r', :encoding => 'iso-8859-1:utf-8') do |file|
                                    Garry K
                                    My mistake this does work.
                                    We got our versions crossed up.
                                    Thanks anyway Dan
                                      Dan Rathbun
                                      OH he is in Russia, so he's likely running a different codepage.
                                      Get his default system Encoding:
                                      Encoding::find("filesystem") >> an encoding
                                      (On my machine it returns the #<Encoding:Windows-1252> object reference.)
                                      or
                                      Encoding::locale_charmap >> returns a name for the encoding.
                                      (On my machine it returns the string "CP1252".)
                                        Garry K
                                        For me it just returns an error.
                                        (eval):5:in `run': uninitialized constant JF::WebConsole::Encoding
                                          Garry K
                                          Sorry - I see this only works in SU 2014
                                            Garry K
                                            I've run into issues with taking the fist or second Mac Address out of ifconfig or ipconfig /all.
                                            I've changed the code to look at the entire file and then to step through it line by line and treat it as a bit of a state machine.
                                            Thanks to pgarmyn and Driven I think I've got some code that will work. They both helped with files as have a handful of other people.
                                            With windows I've tested files in English, French, Russian and some with VMWare set up.
                                            With OSX I've just tested in English.
                                            Mac Address
                                            • 3 / 3
